i recently bought esp32-c3 . Already have esp32 and ESP-IDF for esp32 in my laptop.
Can i place esp32-c3's ESP-IDF together in the same directory as for ESP-IDF for esp32 ?
Since there is only 1 IDF_PATH for 2 different modules, how should i arrange it?
Looked thru yr documentation, can't find any on that issue.
Thanks.
esp32-c3 >> 2 ESP-IDF for 2 different modules
Re: esp32-c3 >> 2 ESP-IDF for 2 different modules
There is no 'ESP-IDF for the C3' specifically: if you have a recent enough ESP-IDF, it will support both chips. Unless you need to hang on to an older ESP-IDF, it's likely easiest to simply make sure your current directory has an ESP-IDF new enough to support the C3, and upgrade if it does not.
Noted. thanks for the explanation.
have already done the upgrading
on going learning continues ...
学习中找战友。
Users browsing this forum: Baidu [Spider] and 87 guests
