Esp-prog doesn't want to work anymore
Samuele
Postby Samuele » Mon Feb 07, 2022 4:16 pm
Hello guys
I work with esp32 and esp-prog jtag debugger on Visual Studio Code (1.64.0) and esp-idf (v1.3.0) for a few months without big problema ... but at the enad of dicember i no be able to go in debug mode with esp-prog, i was checked all pin on board and debugger, checked driver on windows (with zadig) and at the and i was install all on other pc, but the comunication not not works ...
I'm desperate enough to accept any suggestions
follow the comuniucation log
tahks in advance
Open On-Chip Debugger  v0.10.0-esp32-20210401 (2021-04-01-15:46)
Licensed under GNU GPL v2
For bug reports, read
debug_level: 2
adapter speed: 20000 kHz
❌ Error: libusb_open() failed with LIBUSB_ERROR_NOT_SUPPORTED
Info : ftdi: if you experience problems at higher adapter clocks, try the command "ftdi_tdo_sample_edge falling"
Info : clock speed 20000 kHz
Info : esp32.cpu0: Debug controller was reset.
Info : esp32.cpu0: Core was reset.
Info : esp32.cpu1: Debug controller was reset.
Info : esp32.cpu1: Core was reset.
Info : accepting 'tcl' connection on tcp/6666
Info : dropped 'tcl' connection
Time-is-life
Re: Esp-prog doesn't want to work anymore
Postby Time-is-life » Tue Feb 08, 2022 3:33 am
1. Does using F1 "ESP-IDF: Flash (with JTag)" succeed in programming the ESP32?
2. Does reverting the ESP-IDF VSCode Extension from v1.3 to v1.2, then launching the debugger, succeed?
The following thread may be related.
https://www.esp32.com/viewtopic.php?f=40&t=25838#p91227
Samuele
Postby Samuele » Tue Feb 08, 2022 8:35 am
No flashing not works.
The problem was the Espressif IDF version 1.3 not works with jtag and the 1.2 instead yes.
Many many thanks!!
Time-is-life
Postby Time-is-life » Thu Feb 17, 2022 5:22 am
Users browsing this forum: No registered users and 15 guests
