ESP-PROG Flash stalls using JTAG
Time-is-life
Postby Time-is-life » Fri Jan 28, 2022 4:21 am
Hardware: (ESP-PROG with ESP32 DEVKITV1 ((ESP-WROOM-32).
This hardware I've previously verified to compile, flash and debug as guided by the popular Yuri R Youtube videos.
Then I noticed that there was an the official tool (VSCode ESP-IDF extension),
Quick User Guide for the ESP-IDF VS Code Extension https://www.youtube.com/watch?v=Lc6ausiKvQM
However, after studying that video, and the related pages
(including https://github.com/espressif/vscode-esp ... install.md
https://github.com/espressif/vscode-esp ... leshooting
https://github.com/espressif/openocd-es ... ooting-FAQ
and installing (first I removed all Yuri R video's related setup),
I can compile an example project but not JTAG flash it.
The Output window for OpenOCD reports:
Open On-Chip Debugger v0.10.0-esp32-20211111 (2021-11-10-21:40)
Licensed under GNU GPL v2
For bug reports, read
debug_level: 2
adapter speed: 20000 kHz
Info : ftdi: if you experience problems at higher adapter clocks, try the command "ftdi_tdo_sample_edge falling"
Info : clock speed 20000 kHz
Info : accepting 'tcl' connection on tcp/6666
Info : dropped 'tcl' connection
In VSCode Command Pallete, esp-idf, if I set "OpenOCD Server debug level" to 3,
a lot of detail is added to the above, but the final lines are again as above.
So in summary, flashing this hardware succeeded in my previous setup,
but not with the ESP-IDF VSCode extension.
Curiously, if I hit F5 to debug, that succeeds!
Please advise.
Time-is-life
Re: ESP-PROG Flash stalls using JTAG
Postby Time-is-life » Tue Feb 01, 2022 3:48 am
Today I've found that using the older version (v1.2) of the ESP-IDF VSCode Extension,
instead of the latest (v1.3),
fixes this.
Has anyone else tried "ESP-IDF Flash (with JTag)" with v1.3 of the VSCode extension?
How did it work for you?
Time-is-life
Postby Time-is-life » Thu Feb 17, 2022 5:20 am
Users browsing this forum: No registered users and 7 guests
