Upgrading from IDF 4.0.0 to 4.3.1 breaks build
miniwin
Postby miniwin » Thu Jan 27, 2022 3:25 pm
I have a project that isn't too complex. It has a main component and 2 other components. It's been building fine in IDF version 4.0.0. Upgrading to 4.3.1 and it fails to build with some unresolved externals when linking which are in my source code. The source files that contain the functions that are not found are being compiled - I tried putting deliberate errors in them and the compiler noticed. I can't figure out why the link is not including the correct object files, or finding the functions if they are.
I've tried removing the components and putting everything into a single main component - and everything builds, so I don't think there's anything wrong with the code.
The project is in github here...
https://github.com/miniwinwm/miniwinwm/ ... iWinSimple
Anyone any ideas?
ESP_Mahavir
Re: Upgrading from IDF 4.0.0 to 4.3.1 breaks build
Postby ESP_Mahavir » Wed Feb 09, 2022 10:05 am
Hello @miniwin,
It is possible that you are running into circular dependency issue here. Could you please check if section at https://docs.espressif.com/projects/esp ... pendencies helps you in this context?
Users browsing this forum: biterror, Emanuel Martins and 70 guests
