ESP32 C3下载后提示SHA256校验失败
学学ESP32
Postby 学学ESP32 » Fri Jan 07, 2022 11:19 am
下载后反复重启,提示SHA256校验失败
错误日志:
I (113) boot: 2 factory factory app 00 00 00010000 00100000
I (120) boot: End of partition table
I (124) esp_image: segment 0: paddr=00010020 vaddr=3c020020 size=08f18h ( 36632) map
I (139) esp_image: segment 1: paddr=00018f40 vaddr=3fc8be00 size=01cb4h ( 7348) load
I (143) esp_image: segment 2: paddr=0001abfc vaddr=40380000 size=0541ch ( 21532) load
I (154) esp_image: segment 3: paddr=00020020 vaddr=42000020 size=189a8h (100776) map
I (173) esp_image: segment 4: paddr=000389d0 vaddr=4038541c size=06858h ( 26712) load
I (179) esp_image: segment 5: paddr=0003f230 vaddr=50000000 size=00010h ( 16) load
I (183) boot: Loaded app from partition at offset 0x10000
I (185) boot: Disabling RNG early entropy source...
I (202) cpu_start: Pro cpu up.
I (850) cpu_start: Pro cpu start user code
I (850) cpu_start: cpu freq: 160000000
I (850) cpu_start: Application information:
I (853) cpu_start: Project name: template-app
I (858) cpu_start: App version: 1
I (863) cpu_start: Compile time: Jan 7 2022 17:52:36
I (869) cpu_start: ELF file SHA256: 6fb4adea717aa9a7...
I (875) cpu_start: ESP-IDF: v4.3.2
I (880) heap_init: Initializing. RAM available for dynamic allocation:
I (887) heap_init: At 3FC8EAF0 len 00031510 (197 KiB): DRAM
I (893) heap_init: At 3FCC0000 len 0001F060 (124 KiB): STACK/DRAM
I (900) heap_init: At 50000010 len 00001FF0 (7 KiB): RTCRAM
I (906) spi_flash: detected chip: generic
I (911) spi_flash: flash io: dio
I (915) sleep: Configure to isolate all GPIO pins in sleep state
I (922) sleep: Enable automatic switching of GPIO sleep configuration
I (929) cpu_start: Starting scheduler.
ESP-ROM:esp32c3-api1-20210207
Build:Feb 7 2021
rst:0x7 (TG0WDT_SYS_RST),boot:0xc (SPI_FAST_FLASH_BOOT)
Saved PC:0x40380082
0x40380082: _panic_handler at vectors.S.obj:?
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fcd6100,len:0x1920
load:0x403ce000,len:0x8d4
load:0x403d0000,len:0x2dc0
SHA-256 comparison failed:
Calculated: 5b22f2c8671e99063e16d07d5df3b67838f61966e56775c48551f0b5f27d28b4
Expected: fd47b58dc5c833512bf854099d0c65303c396b06e85e012c609efc23ead39b67
Attempting to boot anyway...
entry 0x403ce000
I (53) boot: ESP-IDF v4.3.2 2nd stage bootloader
I (53) boot: compile time 17:52:45
I (54) boot: chip revision: 3
I (55) boot.esp32c3: SPI Speed : 80MHz
I (60) boot.esp32c3: SPI Mode : DIO
I (65) boot.esp32c3: SPI Flash Size : 4MB
W (69) boot.esp32c3: PRO CPU has been reset by WDT.
E (75) boot.esp32c3: WDT reset info dump is not supported yet
I (81) boot: Enabling RNG early entropy source...
I (87) boot: Partition Table:
I (90) boot: ## Label Usage Type ST Offset Length
I (98) boot: 0 nvs WiFi data 01 02 00009000 00006000
I (105) boot: 1 phy_init RF data 01 01 0000f000 00001000
Users browsing this forum: No registered users and 42 guests
