Problem to get the ip address on this example.
Pyshco
Postby Pyshco » Mon Jul 24, 2017 1:58 pm
When i tried this example at home it perfectly works, now at my office didn't work... Here is the output:
ets Jun 8 2016 00:22:57
rst:0x1 (POWERON_RESET),boot:0x12 (SPI_FAST_FLASH_BOOT)
rst:0x10 (RTCWDT_RTC_RESET),boot:0x12 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0x00
mode:DIO, clock div:1
load:0x3fff0008,len:8
load:0x3fff0010,len:160
load:0x40078000,len:10632
load:0x40080000,len:252
entry 0x40080034
Connecting to NETWORK_NAME
And stay there for ever, Can you guys help me?
Code here :
#include <WiFi.h>
const char* ssid     = "CLAROQNK37";
const char* password = "9j98g4NuEaq496Yk";
WiFiServer server(80);
void setup()
    pinMode(5, OUTPUT);      // set the LED pin mode
    delay(10);
    // We start by connecting to a WiFi network
    Serial.println();
    Serial.println();
    Serial.print("Connecting to ");
    Serial.println(ssid);
    WiFi.begin(ssid, password);
        delay(500);
        Serial.print(".");
    Serial.println("");
    Serial.println("WiFi connected.");
    Serial.println("IP address: ");
    server.begin();
int value = 0;
void loop(){
 WiFiClient client = server.available();   // listen for incoming clients
  if (client) {                             // if you get a client,
    Serial.println("New Client.");           // print a message out the serial port
    String currentLine = "";                // make a String to hold incoming data from the client
    while (client.connected()) {            // loop while the client's connected
      if (client.available()) {             // if there's bytes to read from the client,
        char c = client.read();             // read a byte, then
        Serial.write(c);                    // print it out the serial monitor
        if (c == '\n') {                    // if the byte is a newline character
          // if the current line is blank, you got two newline characters in a row.
          // that's the end of the client HTTP request, so send a response:
          if (currentLine.length() == 0) {
            // HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
            // and a content-type so the client knows what's coming, then a blank line:
            client.println("HTTP/1.1 200 OK");
            client.println("Content-type:text/html");
            client.println();
            // the content of the HTTP response follows the header:
            client.print("Click <a href=\"/H\">here</a> to turn the LED on pin 5 on.<br>");
            client.print("Click <a href=\"/L\">here</a> to turn the LED on pin 5 off.<br>");
            // The HTTP response ends with another blank line:
            client.println();
            // break out of the while loop:
          } else {    // if you got a newline, then clear currentLine:
            currentLine = "";
        } else if (c != '\r') {  // if you got anything else but a carriage return character,
          currentLine += c;      // add it to the end of the currentLine
        // Check to see if the client request was "GET /H" or "GET /L":
        if (currentLine.endsWith("GET /H")) {
          digitalWrite(5, HIGH);               // GET /H turns the LED on
        if (currentLine.endsWith("GET /L")) {
          digitalWrite(5, LOW);                // GET /L turns the LED off
    // close the connection:
    client.stop();
    Serial.println("Client Disconnected.");
tele_player
Re: Problem to get the ip address on this example.
Postby tele_player » Tue Jul 25, 2017 5:21 am
Just to be clear - are you saying it isn't getting to the loop checking WiFi status?
Works at home, not at office? Different make/model of WiFi access points?
Pyshco
Postby Pyshco » Tue Jul 25, 2017 1:15 pm
Now it's working... thanks!!
Davitronix
Postby Davitronix » Fri Sep 10, 2021 3:41 pm
Please I'm having an issue on accessing my esp32 ip address for a project on IOT based Humidity and Rainfall Monitoring system. In the project, the results will be logged in an sd card and also it should be access through the IP address on browser.
Here is my issue, I'm able to get the result on my sd card but entering the Gotten IP, it's not going on browser
ESP_Sprite
Postby ESP_Sprite » Sat Sep 11, 2021 2:55 am
Suggest you don't kick a four-year old topic for that, but put it in your own post. Make sure to post the source code there as well, we can't help you debug if you don't.
Users browsing this forum: No registered users and 125 guests
