The mesh network is not working ... although it should!
viboxjuwin
Postby viboxjuwin » Wed Dec 15, 2021 9:16 pm
Hello! I open the topic, because after a week of painstaking work, the result was not achieved.
Libraries tried different versions: early and latest. I load the code for deploying the mesh network on two ESP32-CAM boards (I attach the code - basic.ino). Both boards are from Aliexpress (manufacturer not identified). Both are powered by 5 volts. One of them is connected to the port monitor. No messaging takes place.
What could be wrong: in the code or in the hardware? Please give me some good advice: which way to dig. Could someone upload this code to their boards to test if it works?
basic.zip
(1.04 KiB) Downloaded 268 times
Port Monitor Message.png (72.23 KiB) Viewed 4948 times
MikesProjects
Re: The mesh network is not working ... although it should!
Postby MikesProjects » Tue Dec 21, 2021 3:37 pm
Not sure what was painstaking about loading/running this demo code. I successfully tried this demonstration code in a 5 node mesh (2xESP32 dev boards, 2xESP8266 dev boards, ESP32-CAM.
I assume the code compiled and downloaded on your ESP's without error, and your Serial Monitor baud rate is set to 115200. You might want to enable the full debugging:
Uncomment this line:
mesh.setDebugMsgTypes( ERROR | MESH_STATUS | CONNECTION | SYNC | COMMUNICATION | GENERAL | MSG_TYPES | REMOTE ); // all types on
Comment this line:
// mesh.setDebugMsgTypes( ERROR | STARTUP ); // set before init() so that you can see startup messages
If still nothing, add a message inside the loop to see if the program is running:
Serial.printf("Loop Test\n");
... which will (should) give you plenty of this:
10:28:56.249 -> Loop Test
Painless Screenshot.jpg (2 MiB) Viewed 4891 times
viboxjuwin
Postby viboxjuwin » Wed Dec 22, 2021 6:46 am
Thank you very much for checking the code! You were absolutely right - the code works fine! As it turned out, during Wi-Fi initialization, there was a peak load with a current greater than the USB port on the computer can supply. Therefore, the module was rebooted cyclically. Connecting the ESP32 to a self-contained 5V power supply solved the problem!
Users browsing this forum: No registered users and 63 guests
