Error addinf ESP-NOW peer info
alanmasutti
Postby alanmasutti » Wed Dec 08, 2021 5:21 pm
Hi guys,
I'm working whit ESP-NOW protocol to communicate the status of hardware buttons attached to the one board to controll the second one than is in a score point display in the gym attached to the wall.
Ok, I try to add the peer in a separate function that declare a new variable of esp_now_peer_info_t type:
void initESPNOW(){
  WiFi.mode(WIFI_STA);
  pinMode(CONNECTION_LED, OUTPUT);
  // Init ESP-NOW
  if (esp_now_init() != ESP_OK) {
    Serial.println("Error initializing ESP-NOW");
    return;
  esp_now_register_send_cb(OnDataSent);
  esp_now_peer_info_t peerInfo;
  memcpy(peerInfo.peer_addr, broadcastAddress, 6);
  peerInfo.channel = 0;
  peerInfo.encrypt = false;
  if (esp_now_add_peer(&peerInfo) != ESP_OK){
    Serial.println("Failed to add peer");
    return;
//  esp_now_register_recv_cb(OnDataRecv);
when I call this function the output in the serial is about an error as "(...) ESPNOW peer interface is invalid".
I've solve this problem passing by copy one variable of the same type as argument.
void initESPNOW(esp_now_peer_info_t peerInfo) {
  // Init ESP-NOW
    ESP_NOWState = false;
    return;
    return;
    return;
  ESP_NOWState = true;
Is this a problem? In case there a solution to this? Is also known?
Thanks in advance,
Alan
Users browsing this forum: No registered users and 39 guests
