device address ble eddystone tlm
yemred
Postby yemred » Thu Dec 02, 2021 12:37 pm
Hello, i am using exactly same example of ble eddystone. there is a function
esp_log_buffer_hex("EDDYSTONE_DEMO: Device address:", scan_result->scan_rst.bda, ESP_BD_ADDR_LEN);
for printing device address but i want to assign device address to a variable. are there any one else who can show me the way. because i tried lots of ways.
this function doesnt works for me,
esp_bt_dev_get_address(void)
there must be an other way to get it.
thanks a lot for reading
yemred
Re: device address ble eddystone tlm
Postby yemred » Fri Dec 03, 2021 6:01 am
i wanna ansver my own question instead of admins (:
if you wanna get all advertised data in hex combination then code is this
uint8_t adv_data_len  = scan_result->scan_rst.adv_data_len;
uint8_t *adv_data     = scan_result->scan_rst.ble_adv;
for(int i = 0; i < ESP_BD_ADDR_LEN; ++i){
    printf("%02X ", adv_addr[i]);
if you wanna get advertiser device address then code is this
uint8_t *adv_addr     = scan_result->scan_rst.bda;
for(int i = 0; i < ESP_BD_ADDR_LEN; ++i){     //ESP_BD_ADDR_LEN = 6 and given by example ble_eddystone
all code where to placed is this
//esp_eddystone_demo.c
case ESP_GAP_SEARCH_INQ_RES_EVT: {
                    esp_eddystone_result_t eddystone_res;
                    memset(&eddystone_res, 0, sizeof(eddystone_res));
                    esp_err_t ret = esp_eddystone_decode(scan_result->scan_rst.ble_adv, scan_result->scan_rst.adv_data_len, &eddystone_res);
                    if (ret) {
                        // error:The received data is not an eddystone frame packet or a correct eddystone frame packet.
                        // just return
                        return;
                        // The received adv data is a correct eddystone frame packet.
                        // Here, we get the eddystone infomation in eddystone_res, we can use the data in res to do other things.
                        // For example, just print them:
                        ESP_LOGI(TAG, "--------Eddystone Found----------");
                        //esp_log_buffer_hex("EDDYSTONE_DEMO: Device address", scan_result->scan_rst.bda, ESP_BD_ADDR_LEN);
                        for(int i = 0; i < adv_data_len; ++i){
                            printf("%02X ", adv_data[i]);
                        ESP_LOGI(TAG, "RSSI of packet:%d dbm", scan_result->scan_rst.rssi);
                        esp_eddystone_show_inform(&eddystone_res);
i love you all who read my post.
666hjk
Postby 666hjk » Tue Nov 08, 2022 2:55 am
                    if (ret) {
                        // just return
                        return;
thanks for sharing this, and enhancing my understanding. :)
学习中找战友。
Users browsing this forum: Kuralmozhi and 74 guests
