配网时出现一些数据,这些数据影响了其他任务
Moderator: ESP_Bob
fst202130609
Postby fst202130609 » Tue Nov 30, 2021 4:06 am
看不懂这些数据,想找到这些数据在哪里打印,找不到,是不是封装了???
I (11227) wifi:new:<4,0>, old:<1,0>, ap:<255,255>, sta:<4,0>, prof:1
I (11807) wifi:state: init -> auth (b0)
I (11867) wifi:state: auth -> assoc (0)
I (11877) wifi:state: assoc -> run (10)
W (11947) wifi:<ba-add>idx:0 (ifx:0, 04:d4:c4:3b:7e:70), tid:0, ssn:0, winSize:64
I (12017) wifi:connected with xxxxxxxxx, aid = 12, channel 4, BW20, bssid = 255.。。。。。。。。。
I (12017) wifi:security: WPA2-PSK, phy: bgn, rssi: -41
I (12027) wifi:pm start, type: 1
I (12027) wifi:set rx beacon pti, rx_bcn_pti: 0, bcn_timeout: 0, mt_pti: 25000, mt_time: 10000
I (12037) wifi:BcnInt:102400, DTIM:3
ESP_ICY
Re: 配网时出现一些数据,这些数据影响了其他任务
Postby ESP_ICY » Fri Dec 03, 2021 3:56 am
你这边具体是想看什么数据
fst202130609
Postby fst202130609 » Fri Dec 03, 2021 6:16 am
官方的WiFi/smart_config例程有bug,我在这个例程添加了定时器和灯,在esptouch开始配网时让灯以100ms闪烁,在这个过程中,大概660ms灯没闪烁,不懂是怎么哪里出问题。
/* Esptouch example
#include <string.h>
#include <stdlib.h>
#include "freertos/task.h"
#include "esp_wifi.h"
#include "esp_wpa2.h"
#include "esp_event.h"
#include "esp_log.h"
#include "esp_system.h"
#include "nvs_flash.h"
#include "esp_netif.h"
#include "esp_smartconfig.h"
#include "freertos/queue.h"
#include "driver/gpio.h"
#include "driver/timer.h"
#include "esp_timer.h"
/* FreeRTOS event group to signal when we are connected & ready to make a request */
static EventGroupHandle_t s_wifi_event_group;
/* The event group allows multiple bits for each event,
but we only care about one event - are we connected
to the AP with an IP? */
static const int CONNECTED_BIT = BIT0;
static const int ESPTOUCH_DONE_BIT = BIT1;
static const char *TAG = "smartconfig_example";
static void smartconfig_example_task(void * parm);
typedef enum
Led_off = 0,
Config_led,
Connect_led,
mqtt_connet
}smartLedMode_t;
smartLedMode_t led_mode =Led_off;
#define led 19
#define ledon gpio_set_level(led, 0)
#define ledoff gpio_set_level(led, 1)
void led_Init(void);
void test_timer_periodic_cb(void *arg);
void led_Init(void)
gpio_reset_pin(led);
gpio_set_direction(led, GPIO_MODE_OUTPUT);
ledoff;
esp_timer_handle_t test_p_handle = 0;
esp_timer_handle_t motor_tim = 0;
//定义一个周期重复运行的定时器结构体
esp_timer_create_args_t test_periodic_arg = {
.callback =
&test_timer_periodic_cb, //设置回调函数
.arg = NULL, //不携带参数
.name = "TestPeriodicTimer" //定时器名字
uint8_t ledcnt =0;
uint8_t ledtrun =0;
ledcnt++;
if((led_mode ==Config_led)&&(ledcnt >1)) //0不成功
ledtrun =!ledtrun;
ledcnt = 0;
gpio_set_level(led, ledtrun);
static void event_handler(void* arg, esp_event_base_t event_base,
int32_t event_id, void* event_data)
if (event_base == WIFI_EVENT && event_id == WIFI_EVENT_STA_START) {
xTaskCreate(smartconfig_example_task, "smartconfig_example_task", 4096, NULL, 3, NULL);
} else if (event_base == WIFI_EVENT && event_id == WIFI_EVENT_STA_DISCONNECTED) {
esp_wifi_connect();
led_mode =Led_off;
ledoff;
xEventGroupClearBits(s_wifi_event_group, CONNECTED_BIT);
} else if (event_base == IP_EVENT && event_id == IP_EVENT_STA_GOT_IP) {
xEventGroupSetBits(s_wifi_event_group, CONNECTED_BIT);
} else if (event_base == SC_EVENT && event_id == SC_EVENT_SCAN_DONE) {
ESP_LOGI(TAG, "Scan done");
} else if (event_base == SC_EVENT && event_id == SC_EVENT_FOUND_CHANNEL) {
ESP_LOGI(TAG, "Found channel");
} else if (event_base == SC_EVENT && event_id == SC_EVENT_GOT_SSID_PSWD) {
ESP_LOGI(TAG, "Got SSID and password");
smartconfig_event_got_ssid_pswd_t *evt = (smartconfig_event_got_ssid_pswd_t *)event_data;
wifi_config_t wifi_config;
uint8_t ssid[33] = { 0 };
uint8_t password[65] = { 0 };
uint8_t rvd_data[33] = { 0 };
bzero(&wifi_config, sizeof(wifi_config_t));
memcpy(wifi_config.sta.ssid, evt->ssid, sizeof(wifi_config.sta.ssid));
memcpy(wifi_config.sta.password, evt->password, sizeof(wifi_config.sta.password));
wifi_config.sta.bssid_set = evt->bssid_set;
if (wifi_config.sta.bssid_set == true) {
memcpy(wifi_config.sta.bssid, evt->bssid, sizeof(wifi_config.sta.bssid));
memcpy(ssid, evt->ssid, sizeof(evt->ssid));
memcpy(password, evt->password, sizeof(evt->password));
ESP_LOGI(TAG, "SSID:%s", ssid);
ESP_LOGI(TAG, "PASSWORD:%s", password);
if (evt->type == SC_TYPE_ESPTOUCH_V2) {
ESP_ERROR_CHECK( esp_smartconfig_get_rvd_data(rvd_data, sizeof(rvd_data)) );
ESP_LOGI(TAG, "RVD_DATA:");
for (int i=0; i<33; i++) {
printf("%02x ", rvd_data);
printf("\n");
ESP_ERROR_CHECK( esp_wifi_disconnect() );
ESP_ERROR_CHECK( esp_wifi_set_config(WIFI_IF_STA, &wifi_config) );
esp_wifi_connect();
} else if (event_base == SC_EVENT && event_id == SC_EVENT_SEND_ACK_DONE) {
xEventGroupSetBits(s_wifi_event_group, ESPTOUCH_DONE_BIT);
static void initialise_wifi(void)
s_wifi_event_group = xEventGroupCreate();
esp_netif_t *sta_netif = esp_netif_create_default_wifi_sta();
assert(sta_netif);
ESP_ERROR_CHECK( esp_event_handler_register(WIFI_EVENT, ESP_EVENT_ANY_ID, &event_handler, NULL) );
ESP_ERROR_CHECK( esp_event_handler_register(IP_EVENT, IP_EVENT_STA_GOT_IP, &event_handler, NULL) );
ESP_ERROR_CHECK( esp_event_handler_register(SC_EVENT, ESP_EVENT_ANY_ID, &event_handler, NULL) );
ESP_ERROR_CHECK( esp_wifi_set_mode(WIFI_MODE_STA) );
led_mode =Config_led;
EventBits_t uxBits;
ESP_ERROR_CHECK( esp_smartconfig_set_type(SC_TYPE_ESPTOUCH) );
smartconfig_start_config_t cfg = SMARTCONFIG_START_CONFIG_DEFAULT();
ESP_ERROR_CHECK( esp_smartconfig_start(&cfg) );
while (1) {
uxBits = xEventGroupWaitBits(s_wifi_event_group, CONNECTED_BIT | ESPTOUCH_DONE_BIT, true, false, portMAX_DELAY);
if(uxBits & CONNECTED_BIT) {
ESP_LOGI(TAG, "WiFi Connected to ap");
if(uxBits & ESPTOUCH_DONE_BIT) {
led_mode =Connect_led;
ESP_LOGI(TAG, "smartconfig over");
esp_smartconfig_stop();
vTaskDelete(NULL);
void app_main(void)
led_Init();
esp_err_t time_err = esp_timer_create(&test_periodic_arg, &test_p_handle);
time_err = esp_timer_start_periodic(test_p_handle, 50* 1000);
ESP_ERROR_CHECK( nvs_flash_init() );
initialise_wifi();
Users browsing this forum: No registered users and 16 guests
