ESP32_Devkit-V4 try to change/reduce transmitting power
bithalver
Postby bithalver » Sat Nov 27, 2021 10:05 pm
with VSC /PlatformIO / esp_wifi.h I'm trying to reduce the transmitting power. esp_wifi_set_max_tx_power(20) results in no difference to esp_wifi_set_max_tx_power(2). The current consumption of the board shows no change. What am I doing wrong?
tnx
boarchuz
Re: ESP32_Devkit-V4 try to change/reduce transmitting power
Postby boarchuz » Mon Nov 29, 2021 6:38 am
https://github.com/espressif/esp-idf/bl ... #L897-L915
Param power unit is 0.25dBm, range is [8, 84] corresponding to 2dBm - 20dBm.
2 is invalid. Check your return values.
bithalver
Postby bithalver » Thu Dec 02, 2021 7:42 am
I had not understood it that way!
Thanks a lot
Users browsing this forum: No registered users and 13 guests
