ESP32-S3 DevKitC-1安裝失敗
Walter51234
Postby Walter51234 » Sat Nov 27, 2021 5:27 pm
使用ESP32-S3-DevKitC-1開發板,與window 11作業系統,依照入門指南進行軟件設置,當連接開發板到電腦並執行到 idf.py -p com3 flash monitor程序時,發生以下錯誤訊息,請問如何解決?
Executing action: flash
Running ninja in directory c:\esp\esp-idf\examples\get-started\hello_world\build
Executing "ninja flash"...
[1/4] Performing build step for 'bootloader'
ninja: no work to do.
[1/2] cmd.exe /C "cd /D C:\esp\esp-idf\components\esptool_...:/esp/esp-idf/components/esptool_py/run_serial_tool.cmake"
esptool.py esp32 -p com3 -b 460800 --before=default_reset --after=hard_reset write_flash --flash_mode dio --flash_freq 40m --flash_size 2MB 0x8000 partition_table/partition-table.bin 0x1000 bootloader/bootloader.bin 0x10000 hello-world.bin
esptool.py v3.1-dev
Serial port com3
Connecting........_____....._____....._____....._____....._____....._____....._____
CMake Error at run_serial_tool.cmake:50 (message):
C:/esp/tools/.espressif/python_env/idf4.3_py3.8_env/Scripts/python.exe
C:/esp/esp-idf/components/esptool_py/esptool/esptool.py --chip esp32 failed
FAILED: CMakeFiles/flash
cmd.exe /C "cd /D C:\esp\esp-idf\components\esptool_py && C:\esp\tools\.espressif\tools\cmake\3.16.4\bin\cmake.exe -D IDF_PATH="C:/esp/esp-idf" -D SERIAL_TOOL="C:/esp/tools/.espressif/python_env/idf4.3_py3.8_env/Scripts/python.exe C:/esp/esp-idf/components/esptool_py/esptool/esptool.py --chip esp32" -D SERIAL_TOOL_ARGS="--before=default_reset --after=hard_reset write_flash @flash_args" -D WORKING_DIRECTORY="C:/esp/esp-idf/examples/get-started/hello_world/build" -P C:/esp/esp-idf/components/esptool_py/run_serial_tool.cmake"
ninja failed with exit code 1
PS C:\esp\esp-idf\examples\get-started\hello_world>
fland@126.com
Re: ESP32-S3 DevKitC-1安裝失敗
Postby fland@126.com » Mon Nov 29, 2021 1:27 am
新手出现这个问题。
是串口驱动能力不足导致。
不是有两个按键吗?用按键也可以下载。
下载逻辑需要在BOOT=0, EN这个复位才能进入下载状态。
ESP_ICY
Postby ESP_ICY » Mon Nov 29, 2021 9:41 am
你的GPIO口有无连着其他东西
Walter51234
Postby Walter51234 » Tue Nov 30, 2021 7:19 am
除了開發板,沒有接任何裝置。
Walter51234
Postby Walter51234 » Tue Nov 30, 2021 7:23 am
新手出现这个问题。
是串口驱动能力不足导致。
不是有两个按键吗?用按键也可以下载。
如何操作Boot按鍵? 按下Boot按鍵沒有反應。
Walter51234
Postby Walter51234 » Tue Nov 30, 2021 7:25 am
你的GPIO口有无连着其他东西
沒有
Users browsing this forum: No registered users and 30 guests
