Short occurring on UART TX and RX lines
hazelnuts
Postby hazelnuts » Tue Nov 23, 2021 7:09 pm
Hi, I am using a ESP32-WROOM-32D to talk to a PIC microcontroller over a UART communication. In our design we have a battery disconnect meaning we can set a GPIO pin to LOW and all of the PIC controllers will have no power going to them. Then when we want to read from our sensors we can set the GPIO to HIGH and 6v will flow to them. As soon as the power starts going to the PIC controllers there is a short and the power supply supplies 200mA (which is the max we allow). If I take off the TX and RX line on the ESP32 to the PIC microcontrollers then the short DOES NOT occur. It only occurs when the lines our connected specifically the TX line on the ESP to the RX line on the PIC.
I have tried writing a simple test case where I turn on the power wait 3 seconds turn off the power then repeat. I have tried initializing the Serial line and setting it to GPIO and the short still occurs.
  1. #define DSP_DISCONNECT       19 //GPIO pin that controls when 3.3v flows to the LCD
  2. #define BATTERY_DISCONNECT   12  //Battery disconnect pin HIGH for giving power to sensors, LOW for stopping power to sensors
  3.
  4. void setup() {
  5. //  Serial.begin(9600); //Commented the UART1 line out
  6. //  while(!Serial);
  7.
  8.   pinMode(DSP_DISCONNECT, OUTPUT);       //Set 3.3v LCD power supply to output for when we need to power it
  9.   pinMode(BATTERY_DISCONNECT, OUTPUT); //Sets the battery disconnect to output for when we need to read from the sensors
  10.   digitalWrite(BATTERY_DISCONNECT, HIGH); //Sets Sensor power to high to the PIC controllers are getting 6v
  11.   digitalWrite(DSP_DISCONNECT, HIGH);        //Sets the LCD power to high to turn on the LCD
  12. }
  13.
  14. void loop() {
  15.   delay(3000);
  16.   digitalWrite(BATTERY_DISCONNECT, LOW); //Sets Sensor power to low to the PIC controllers are getting 0v
  17.   digitalWrite(DSP_DISCONNECT, LOW);        //Sets the LCD power to low to turn off the LCD
  18.   delay(3000);
  19.   digitalWrite(BATTERY_DISCONNECT, HIGH); //Sets Sensor power to high to the PIC controllers are getting 6v
  20.   digitalWrite(DSP_DISCONNECT, HIGH);        //Sets the LCD power to high to turn on the LCD
  21. }
Let me know if there needs to be any more information to be supplied to assist me on this problem.
Thanks for helping!
ESP_Sprite
Re: Short occurring on UART TX and RX lines
Postby ESP_Sprite » Wed Nov 24, 2021 4:40 am
I'd like to see schematics; I don't think this is a software issue as the GPIOs in the ESP32 generally won't supply 200mA on their own even when shorted.
Users browsing this forum: No registered users and 72 guests
