esp32-C3模组外接了马达和蜂鸣器,灯,按键,程序一上电就一直重启???在esp32c3开发板程序就没问题
Moderator: ESP_Bob
fst202130609
Postby fst202130609 » Fri Nov 12, 2021 3:43 am
是不是电流或者电压所导致的,马达接9v电压,蜂鸣器接5v电压,是不是跟这个有关系?
ESP_ICY
Re: esp32-C3模组外接了马达和蜂鸣器,灯,按键,程序一上电就一直重启???在esp32c3开发板程序就没问题
Postby ESP_ICY » Fri Nov 12, 2021 4:06 am
在开发板没有问题,模组有问题大概率是硬件设计问题,可以提供下重启的log吗
fst202130609
Postby fst202130609 » Mon Nov 15, 2021 6:54 am
connected to ap esp32c3 OK
[0;32mI (3447) subpub: AWS IoT SDK Version 3.0.1-[0m
[0;31mE (3447) subpub: aws_iot_mqtt_init sucessful : 0 [0m
[0;32mI (3457) subpub: Connecting to AWS...[0m
[0;32mI (6247) subpub: Subscribing...[0m
[0;31mE (6757) subpub: An error occurred in the main loop.[0m
abort() was called at PC 0x420072a3 on core 0
Core 0 register dump:
MEPC : 0x403857ae RA : 0x40385f00 SP : 0x3fca6ba0 GP : 0x3fc8e000
TP : 0x3fc8ab54 T0 : 0x37363534 T1 : 0x7271706f T2 : 0x33323130
S0/FP : 0x00000004 S1 : 0x3fca6c04 A0 : 0x3fca6bcc A1 : 0x3fca6c02
A2 : 0x00000000 A3 : 0x3fca6bf9 A4 : 0x00000001 A5 : 0x3fc96000
A6 : 0x7a797877 A7 : 0x76757473 S2 : 0x00001000 S3 : 0x00000000
S4 : 0x00000000 S5 : 0x00000000 S6 : 0x00000000 S7 : 0x00000000
S8 : 0x00000000 S9 : 0x00000000 S10 : 0x00000000 S11 : 0x00000000
T3 : 0x6e6d6c6b T4 : 0x6a696867 T5 : 0x66656463 T6 : 0x62613938
MSTATUS : 0x00001881 MTVEC : 0x40380001 MCAUSE : 0x00000007 MTVAL : 0x00000000
MHARTID : 0x00000000
Stack memory:
3fca6ba0: 0x00000005 0x00000001 0x3fca6c00 0x4038c1ee 0x00000005 0x00000000 0x3fca6cd8 0x3fc90374
3fca6bc0: 0x3fca6c04 0x3fc90390 0x3fca6c00 0x726f6261 0x20292874 0x20736177 0x6c6c6163 0x61206465
3fca6be0: 0x43502074 0x34783020 0x37303032 0x20336132 0x63206e6f 0x2065726f 0x00000030 0x42000000
3fca6c00: 0x00000030 0x30303234 0x33613237 0x00001a00 0x3c0b4900 0x00000000 0xffffffdf 0x420072a6
3fca6c20: 0x3c0c24f4 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0x3fca6950
3fca6c40: 0xa5a5a5a5 0xa5a5a5a5 0x00000001 0x0003a500 0x3fca78ec 0xa5a5a5a5 0x00000000 0xa5a5a500
3fca6c60: 0x3fca78ec 0xa5a5a5a5 0x4354514d 0x00000004 0x3c0b4710 0x000a0007 0x00000001 0x5754514d
3fca6c80: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
3fca6ca0: 0x00000000 0x00000000 0x3fc8dcac 0x000022b3 0x3c0b512d 0x3c0b55d6 0x3c0b5a9f 0x000007d0
3fca6cc0: 0x00004e20 0x00001388 0x00000001 0x42006baa 0x00000000 0x00000000 0x0000024b 0x000003e8
3fca6ce0: 0x0000027e 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000003
3fca6d00: 0xa5a50100 0xa5a50003 0x000007d0 0x00004e20 0xa5a5000a 0xa5a5a5a5 0x00000000 0x00000200
3fca6d20: 0x00000200 0x00000000 0x02001a82 0x6d531500 0x5f656b6f 0x666c6553 0x736e495f 0x74636570
3fca6d40: 0x006e6f69 0x65562643 0x6f697372 0x2e333d6e 0xa5312e30 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5
3fca6d60: 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5
3fca6d80: 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5
3fca6da0: 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5
3fca6dc0: 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5
3fca6de0: 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5
3fca6e00: 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5
3fca6e20: 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5
3fca6e40: 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5
3fca6e60: 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5
3fca6e80: 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5
3fca6ea0: 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5
3fca6ec0: 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5
3fca6ee0: 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5
3fca6f00: 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5
3fca6f20: 0xa5a5a5a5 0xa5a5a5a5 0x02000390 0xa5a5a500 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5
3fca6f40: 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5
3fca6f60: 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5
3fca6f80: 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5
ELF file SHA256: 3ac7178a383ae607
Rebooting...
ESP-ROM:esp32c3-api1-20210207
Build:Feb 7 2021
rst:0xc (RTC_SW_CPU_RST),boot:0xc (SPI_FAST_FLASH_BOOT)
Saved PC:0x40382e6e
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fcd6100,len:0x1730
load:0x403ce000,len:0x8d4
load:0x403d0000,len:0x293c
entry 0x403ce000
[0;32mI (35) boot: ESP-IDF v4.3-dirty 2nd stage bootloader[0m
[0;32mI (35) boot: compile time 14:24:56[0m
[0;32mI (35) boot: chip revision: 3[0m
[0;32mI (37) boot.esp32c3: SPI Speed : 80MHz[0m
[0;32mI (42) boot.esp32c3: SPI Mode : DIO[0m
[0;32mI (47) boot.esp32c3: SPI Flash Size : 2MB[0m
[0;32mI (51) boot: Enabling RNG early entropy source...[0m
[0;32mI (57) boot: Partition Table:[0m
[0;32mI (60) boot: ## Label Usage Type ST Offset Length[0m
[0;32mI (68) boot: 0 nvs WiFi data 01 02 00009000 00006000[0m
[0;32mI (75) boot: 1 phy_init RF data 01 01 0000f000 00001000[0m
[0;32mI (83) boot: 2 factory factory app 00 00 00010000 00100000[0m
[0;32mI (90) boot: End of partition table[0m
[0;32mI (94) esp_image: segment 0: paddr=00010020 vaddr=3c0b0020 size=1cea8h (118440) map[0m
[0;32mI (121) esp_image: segment 1: paddr=0002ced0 vaddr=3fc8d800 size=03148h ( 12616) load[0m
[0;32mI (124) esp_image: segment 2: paddr=00030020 vaddr=42000020 size=a8900h (690432) map[0m
[0;32mI (235) esp_image: segment 3: paddr=000d8928 vaddr=3fc90948 size=003e0h ( 992) load[0m
[0;32mI (235) esp_image: segment 4: paddr=000d8d10 vaddr=40380000 size=0d624h ( 54820) load[0m
[0;32mI (250) esp_image: segment 5: paddr=000e633c vaddr=50000000 size=00010h ( 16) load[0m
[0;32mI (255) boot: Loaded app from partition at offset 0x10000[0m
[0;32mI (255) boot: Disabling RNG early entropy source...[0m
[0;32mI (272) cpu_start: Pro cpu up.[0m
[0;32mI (284) cpu_start: Pro cpu start user code[0m
[0;32mI (284) cpu_start: cpu freq: 160000000[0m
[0;32mI (284) cpu_start: Application information:[0m
[0;32mI (287) cpu_start: Project name: smart_config_aws[0m
[0;32mI (293) cpu_start: App version: 249c573-dirty[0m
[0;32mI (298) cpu_start: Compile time: Nov 15 2021 14:24:30[0m
[0;32mI (304) cpu_start: ELF file SHA256: 3ac7178a383ae607...[0m
[0;32mI (310) cpu_start: ESP-IDF: v4.3-dirty[0m
[0;32mI (316) heap_init: Initializing. RAM available for dynamic allocation:[0m
[0;32mI (323) heap_init: At 3FC95C60 len 0002A3A0 (168 KiB): DRAM[0m
[0;32mI (329) heap_init: At 3FCC0000 len 0001F060 (124 KiB): STACK/DRAM[0m
[0;32mI (336) heap_init: At 50000010 len 00001FF0 (7 KiB): RTCRAM[0m
[0;32mI (342) spi_flash: detected chip: generic[0m
[0;32mI (347) spi_flash: flash io: dio[0m
[0;33mW (351) spi_flash: Detected size(4096k) larger than the size in the binary image header(2048k). Using the size in the binary image header.[0m
[0;32mI (364) sleep: Configure to isolate all GPIO pins in sleep state[0m
[0;32mI (371) sleep: Enable automatic switching of GPIO sleep configuration[0m
[0;32mI (378) cpu_start: Starting scheduler.[0m
[0;32mI (392) gpio: GPIO[19]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0 [0m
[0;32mI (392) gpio: GPIO[4]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0 [0m
[0;32mI (402) gpio: GPIO[3]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0 [0m
[0;32mI (412) gpio: GPIO[7]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0 [0m
[0;32mI (422) gpio: GPIO[6]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0 [0m
[0;32mI (432) gpio: GPIO[2]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0 [0m
[0;32mI (442) gpio: GPIO[5]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:3 [0m
lssssssssssssssssssssss
wifi_cfg needn't to update.
[0;32mI (462) pp: pp rom version: 9387209[0m
[0;32mI (462) net80211: net80211 rom version: 9387209[0m
I (472) wifi:wifi driver task: 3fc9f3b0, prio:23, stack:6656, core=0
[0;32mI (472) system_api: Base MAC address is not set[0m
[0;32mI (472) system_api: read default base MAC address from EFUSE[0m
I (482) wifi:wifi firmware version: c7d0450
I (492) wifi:wifi certification version: v7.0
I (492) wifi:config NVS flash: enabled
I (492) wifi:config nano formating: disabled
I (502) wifi:Init data frame dynamic rx buffer num: 32
I (502) wifi:Init management frame dynamic rx buffer num: 32
I (512) wifi:Init management short buffer num: 32
I (512) wifi:Init dynamic tx buffer num: 32
I (522) wifi:Init static tx FG buffer num: 2
I (522) wifi:Init static rx buffer size: 1600
I (522) wifi:Init static rx buffer num: 10
I (532) wifi:Init dynamic rx buffer num: 32
[0;32mI (532) wifi_init: rx ba win: 6[0m
[0;32mI (532) wifi_init: tcpip mbox: 32[0m
[0;32mI (542) wifi_init: udp mbox: 6[0m
[0;32mI (542) wifi_init: tcp mbox: 6[0m
[0;32mI (552) wifi_init: tcp tx win: 5744[0m
[0;32mI (552) wifi_init: tcp rx win: 5744[0m
[0;32mI (552) wifi_init: tcp mss: 1440[0m
[0;32mI (562) wifi_init: WiFi IRAM OP enabled[0m
[0;32mI (562) wifi_init: WiFi RX IRAM OP enabled[0m
[0;32mI (572) phy_init: phy_version 500,985899c,Apr 19 2021,16:05:08[0m
I (682) wifi:set rx active PTI: 0, rx ack PTI: 0, and default PTI: 0
I (682) wifi:mode : sta (84:f7:03:50:56:4c)
I (692) wifi:enable tsf
wifi_init_sta finished.
I (692) wifi:new:<11,0>, old:<1,0>, ap:<255,255>, sta:<11,0>, prof:1
I (692) wifi:state: init -> auth (b0)
I (702) wifi:state: auth -> init (1c0)
I (702) wifi:new:<11,0>, old:<11,0>, ap:<255,255>, sta:<11,0>, prof:1
wifi err =0
ssid:esp32c3
wifi err =0
ssid:esp32c3
I (2762) wifi:new:<11,0>, old:<11,0>, ap:<255,255>, sta:<11,0>, prof:1
I (2762) wifi:state: init -> auth (b0)
I (2772) wifi:state: auth -> assoc (0)
I (2782) wifi:state: assoc -> run (10)
I (2812) wifi:connected with esp32c3, aid = 14, channel 11, BW20, bssid = c6:ae:9c:a1:bb:ab
I (2812) wifi:security: WPA2-PSK, phy: bgn, rssi: -35
I (2812) wifi:pm start, type: 1
I (2812) wifi:set rx beacon pti, rx_bcn_pti: 0, bcn_timeout: 0, mt_pti: 25000, mt_time: 10000
I (2822) wifi:BcnInt:102400, DTIM:2
W (2832) wifi:<ba-add>idx:0 (ifx:0, c6:ae:9c:a1:bb:ab), tid:0, ssn:0, winSize:64
[0;32mI (3462) esp_netif_handlers: sta ip: 192.168.111.112, mask: 255.255.255.0, gw: 192.168.111.150[0m
got ip:192.168.111.112
[0;32mI (3462) subpub: AWS IoT SDK Version 3.0.1-[0m
[0;31mE (3462) subpub: aws_iot_mqtt_init sucessful : 0 [0m
[0;32mI (3472) subpub: Connecting to AWS...[0m
[0;32mI (6302) subpub: Subscribing...[0m
[0;31mE (6812) subpub: An error occurred in the main loop.[0m
Stack memory:
3fca6cc0: 0x00004e20 0x00001388 0x00000001 0x42006baa 0x00000000 0x00000000 0x00000250 0x000003e8
3fca6ce0: 0x00000283 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000003
Rebooting...
Build:Feb 7 2021
Saved PC:0x40382e6e
SPIWP:0xee
entry 0x403ce000
[0;32mI (382) gpio: GPIO[19]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0 [0m
I (482) wifi:wifi certification version: v7.0
I (512) wifi:Init static tx FG buffer num: 2
wifi err =0
ssid:esp32c3
wifi err =0
ssid:esp32c3
I (2822) wifi:connected with esp32c3, aid = 15, channel 11, BW20, bssid = c6:ae:9c:a1:bb:ab
I (2822) wifi:security: WPA2-PSK, phy: bgn, rssi: -35
I (2822) wifi:pm start, type: 1
I (2822) wifi:set rx beacon pti, rx_bcn_pti: 0, bcn_timeout: 0, mt_pti: 25000, mt_time: 10000
W (2842) wifi:<ba-add>idx:0 (ifx:0, c6:ae:9c:a1:bb:ab), tid:0, ssn:0, winSize:64
I (2912) wifi:BcnInt:102400, DTIM:2
Users browsing this forum: No registered users and 19 guests
