switch from Station to Accesspoint, if can't connect to router
Dansen
Postby Dansen » Mon Nov 08, 2021 3:44 pm
Hello guys!
I'm using my ESP32-S2-WROVER-I and I try to implement both station and accesspoint mode. Default should be stationmode and after a certain amount of connection attempts with default SSID and password I want my stationmode to turn off and turn on accesspointmode. In accesspointmode i want to provide a html page in which you can determine SSID and password
after defining SSID and password it suppose to switch back to stationmode and repeat my procedure if SSID and password still do not match any nearby routers.
Now I'm not sure how I can implement this procedure. I'm using the https "simple" example as a template. my init function for my station mode looks like this:
void init_Wifi(void)
    static httpd_handle_t server = NULL;
    ESP_ERROR_CHECK(nvs_flash_init());
    /* Register event handlers to start server when Wi-Fi or Ethernet is connected,
     * and stop server when disconnection happens.
#ifdef CONFIG_EXAMPLE_CONNECT_WIFI
    ESP_ERROR_CHECK(esp_event_handler_register(IP_EVENT, IP_EVENT_STA_GOT_IP, &connect_handler, &server));
    ESP_ERROR_CHECK(esp_event_handler_register(WIFI_EVENT, WIFI_EVENT_STA_DISCONNECTED, &disconnect_handler, &server));
#endif // CONFIG_EXAMPLE_CONNECT_WIFI
#ifdef CONFIG_EXAMPLE_CONNECT_ETHERNET
    ESP_ERROR_CHECK(esp_event_handler_register(IP_EVENT, IP_EVENT_ETH_GOT_IP, &connect_handler, &server));
    ESP_ERROR_CHECK(esp_event_handler_register(ETH_EVENT, ETHERNET_EVENT_DISCONNECTED, &disconnect_handler, &server));
#endif // CONFIG_EXAMPLE_CONNECT_ETHERNET
    /* This helper function configures Wi-Fi or Ethernet, as selected in menuconfig.
     * Read "Establishing Wi-Fi or Ethernet Connection" section in
     * examples/protocols/README.md for more information about this function.
    ESP_ERROR_CHECK(example_connect());
I tried to analyze how the example is establishing router connection and after some research i encoutered the connect.c file in which the whole connection-managemend was implemented.
connect.c content:
/* Common functions for protocol examples, to establish Wi-Fi or Ethernet connection.
#include <string.h>
#include "protocol_examples_common.h"
#include "sdkconfig.h"
#include "esp_event.h"
#include "esp_wifi.h"
#include "esp_wifi_default.h"
#if CONFIG_EXAMPLE_CONNECT_ETHERNET
#include "esp_eth.h"
#if CONFIG_ETH_USE_SPI_ETHERNET
#include "driver/spi_master.h"
#endif // CONFIG_ETH_USE_SPI_ETHERNET
#include "esp_log.h"
#include "esp_netif.h"
#include "driver/gpio.h"
#include "freertos/task.h"
#include "lwip/err.h"
#include "lwip/sys.h"
#ifdef CONFIG_EXAMPLE_CONNECT_IPV6
#define MAX_IP6_ADDRS_PER_NETIF (5)
#define NR_OF_IP_ADDRESSES_TO_WAIT_FOR (s_active_interfaces*2)
#if defined(CONFIG_EXAMPLE_CONNECT_IPV6_PREF_LOCAL_LINK)
#define EXAMPLE_CONNECT_PREFERRED_IPV6_TYPE ESP_IP6_ADDR_IS_LINK_LOCAL
#elif defined(CONFIG_EXAMPLE_CONNECT_IPV6_PREF_GLOBAL)
#define EXAMPLE_CONNECT_PREFERRED_IPV6_TYPE ESP_IP6_ADDR_IS_GLOBAL
#elif defined(CONFIG_EXAMPLE_CONNECT_IPV6_PREF_SITE_LOCAL)
#define EXAMPLE_CONNECT_PREFERRED_IPV6_TYPE ESP_IP6_ADDR_IS_SITE_LOCAL
#elif defined(CONFIG_EXAMPLE_CONNECT_IPV6_PREF_UNIQUE_LOCAL)
#define EXAMPLE_CONNECT_PREFERRED_IPV6_TYPE ESP_IP6_ADDR_IS_UNIQUE_LOCAL
#endif // if-elif CONFIG_EXAMPLE_CONNECT_IPV6_PREF_...
#else
#define NR_OF_IP_ADDRESSES_TO_WAIT_FOR (s_active_interfaces)
#endif
#define EXAMPLE_DO_CONNECT CONFIG_EXAMPLE_CONNECT_WIFI || CONFIG_EXAMPLE_CONNECT_ETHERNET
static int s_active_interfaces = 0;
static xSemaphoreHandle s_semph_get_ip_addrs;
static esp_netif_t *s_example_esp_netif = NULL;
static esp_ip6_addr_t s_ipv6_addr;
int connectingcounter = 0;
/* types of ipv6 addresses to be displayed on ipv6 events */
static const char *s_ipv6_addr_types[] = {
    "ESP_IP6_ADDR_IS_UNKNOWN",
    "ESP_IP6_ADDR_IS_GLOBAL",
    "ESP_IP6_ADDR_IS_LINK_LOCAL",
    "ESP_IP6_ADDR_IS_SITE_LOCAL",
    "ESP_IP6_ADDR_IS_UNIQUE_LOCAL",
    "ESP_IP6_ADDR_IS_IPV4_MAPPED_IPV6"
#endif
static const char *TAG = "example_connect";
#if CONFIG_EXAMPLE_CONNECT_WIFI
static esp_netif_t *wifi_start(void);
static void wifi_stop(void);
#endif
static esp_netif_t *eth_start(void);
static void eth_stop(void);
#endif
 * @brief Checks the netif description if it contains specified prefix.
 * All netifs created withing common connect component are prefixed with the module TAG,
 * so it returns true if the specified netif is owned by this module
static bool is_our_netif(const char *prefix, esp_netif_t *netif)
    return strncmp(prefix, esp_netif_get_desc(netif), strlen(prefix) - 1) == 0;
/* set up connection, Wi-Fi and/or Ethernet */
static void start(void)
    s_example_esp_netif = wifi_start();
    s_active_interfaces++;
#endif
    s_example_esp_netif = eth_start();
#endif
#if CONFIG_EXAMPLE_CONNECT_WIFI && CONFIG_EXAMPLE_CONNECT_ETHERNET
    /* if both intefaces at once, clear out to indicate that multiple netifs are active */
#endif
#if EXAMPLE_DO_CONNECT
    /* create semaphore if at least one interface is active */
    s_semph_get_ip_addrs = xSemaphoreCreateCounting(NR_OF_IP_ADDRESSES_TO_WAIT_FOR, 0);
#endif
/* tear down connection, release resources */
static void stop(void)
    wifi_stop();
    s_active_interfaces--;
#endif
    eth_stop();
#endif
static esp_ip4_addr_t s_ip_addr;
static void on_got_ip(void *arg, esp_event_base_t event_base,
                      int32_t event_id, void *event_data)
    ip_event_got_ip_t *event = (ip_event_got_ip_t *)event_data;
    if (!is_our_netif(TAG, event->esp_netif)) {
        ESP_LOGW(TAG, "Got IPv4 from another interface \"%s\": ignored", esp_netif_get_desc(event->esp_netif));
        return;
    ESP_LOGI(TAG, "Got IPv4 event: Interface \"%s\" address: " IPSTR, esp_netif_get_desc(event->esp_netif), IP2STR(&event->ip_info.ip));
    memcpy(&s_ip_addr, &event->ip_info.ip, sizeof(s_ip_addr));
    xSemaphoreGive(s_semph_get_ip_addrs);
#endif
static void on_got_ipv6(void *arg, esp_event_base_t event_base,
    ip_event_got_ip6_t *event = (ip_event_got_ip6_t *)event_data;
        ESP_LOGW(TAG, "Got IPv6 from another netif: ignored");
        return;
    esp_ip6_addr_type_t ipv6_type = esp_netif_ip6_get_addr_type(&event->ip6_info.ip);
    ESP_LOGI(TAG, "Got IPv6 event: Interface \"%s\" address: " IPV6STR ", type: %s", esp_netif_get_desc(event->esp_netif),
             IPV62STR(event->ip6_info.ip), s_ipv6_addr_types[ipv6_type]);
    if (ipv6_type == EXAMPLE_CONNECT_PREFERRED_IPV6_TYPE) {
        memcpy(&s_ipv6_addr, &event->ip6_info.ip, sizeof(s_ipv6_addr));
#endif // CONFIG_EXAMPLE_CONNECT_IPV6
esp_err_t example_connect(void)
    if (s_semph_get_ip_addrs != NULL) {
        return ESP_ERR_INVALID_STATE;
#endif
    start();
    ESP_ERROR_CHECK(esp_register_shutdown_handler(&stop));
    ESP_LOGI(TAG, "Waiting for IP(s)");
    for (int i = 0; i < NR_OF_IP_ADDRESSES_TO_WAIT_FOR; ++i) {
        xSemaphoreTake(s_semph_get_ip_addrs, portMAX_DELAY);
    // iterate over active interfaces, and print out IPs of "our" netifs
    esp_netif_t *netif = NULL;
    esp_netif_ip_info_t ip;
    for (int i = 0; i < esp_netif_get_nr_of_ifs(); ++i) {
        netif = esp_netif_next(netif);
        if (is_our_netif(TAG, netif)) {
            ESP_LOGI(TAG, "Connected to %s", esp_netif_get_desc(netif));
            ESP_ERROR_CHECK(esp_netif_get_ip_info(netif, &ip));
            ESP_LOGI(TAG, "- IPv4 address: " IPSTR, IP2STR(&ip.ip));
            esp_ip6_addr_t ip6[MAX_IP6_ADDRS_PER_NETIF];
            int ip6_addrs = esp_netif_get_all_ip6(netif, ip6);
            for (int j = 0; j < ip6_addrs; ++j) {
                esp_ip6_addr_type_t ipv6_type = esp_netif_ip6_get_addr_type(&(ip6[j]));
                ESP_LOGI(TAG, "- IPv6 address: " IPV6STR ", type: %s", IPV62STR(ip6[j]), s_ipv6_addr_types[ipv6_type]);
#endif
    return ESP_OK;
esp_err_t example_disconnect(void)
    if (s_semph_get_ip_addrs == NULL) {
    vSemaphoreDelete(s_semph_get_ip_addrs);
    s_semph_get_ip_addrs = NULL;
    stop();
    ESP_ERROR_CHECK(esp_unregister_shutdown_handler(&stop));
    return ESP_OK;
static void on_wifi_disconnect(void *arg, esp_event_base_t event_base,
    ESP_LOGI(TAG, "Wi-Fi disconnected, trying to reconnect...");
    connectingcounter +=1;
    if(connectingcounter == 10)
        return;
    esp_err_t err = esp_wifi_connect();
    if (err == ESP_ERR_WIFI_NOT_STARTED) {
        return;
    ESP_ERROR_CHECK(err);
static void on_wifi_connect(void *esp_netif, esp_event_base_t event_base,
    esp_netif_create_ip6_linklocal(esp_netif);
    char *desc;
    esp_netif_inherent_config_t esp_netif_config = ESP_NETIF_INHERENT_DEFAULT_WIFI_STA();
    // Prefix the interface description with the module TAG
    // Warning: the interface desc is used in tests to capture actual connection details (IP, gw, mask)
    asprintf(&desc, "%s: %s", TAG, esp_netif_config.if_desc);
    esp_netif_config.if_desc = desc;
    esp_netif_config.route_prio = 128;
    esp_netif_t *netif = esp_netif_create_wifi(WIFI_IF_STA, &esp_netif_config);
    free(desc);
    esp_wifi_set_default_wifi_sta_handlers();
    ESP_ERROR_CHECK(esp_event_handler_register(WIFI_EVENT, WIFI_EVENT_STA_DISCONNECTED, &on_wifi_disconnect, NULL));
    ESP_ERROR_CHECK(esp_event_handler_register(IP_EVENT, IP_EVENT_STA_GOT_IP, &on_got_ip, NULL));
    ESP_ERROR_CHECK(esp_event_handler_register(WIFI_EVENT, WIFI_EVENT_STA_CONNECTED, &on_wifi_connect, netif));
    ESP_ERROR_CHECK(esp_event_handler_register(IP_EVENT, IP_EVENT_GOT_IP6, &on_got_ipv6, NULL));
#endif
    ESP_ERROR_CHECK(esp_wifi_set_storage(WIFI_STORAGE_RAM));
    wifi_config_t wifi_config = {
        .sta = {
            .ssid = CONFIG_EXAMPLE_WIFI_SSID,
            .password = CONFIG_EXAMPLE_WIFI_PASSWORD,
            .scan_method = WIFI_ALL_CHANNEL_SCAN,
    ESP_LOGI(TAG, "Connectinggggggggg to %s...", wifi_config.sta.ssid);
    ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_STA));
    ESP_ERROR_CHECK(esp_wifi_set_config(WIFI_IF_STA, &wifi_config));
    ESP_ERROR_CHECK(esp_wifi_start());
    esp_wifi_connect();
    return netif;
    esp_netif_t *wifi_netif = get_example_netif_from_desc("sta");
    ESP_ERROR_CHECK(esp_event_handler_unregister(WIFI_EVENT, WIFI_EVENT_STA_DISCONNECTED, &on_wifi_disconnect));
    ESP_ERROR_CHECK(esp_event_handler_unregister(IP_EVENT, IP_EVENT_STA_GOT_IP, &on_got_ip));
    ESP_ERROR_CHECK(esp_event_handler_unregister(IP_EVENT, IP_EVENT_GOT_IP6, &on_got_ipv6));
    ESP_ERROR_CHECK(esp_event_handler_unregister(WIFI_EVENT, WIFI_EVENT_STA_CONNECTED, &on_wifi_connect));
#endif
    esp_err_t err = esp_wifi_stop();
    if (err == ESP_ERR_WIFI_NOT_INIT) {
        return;
    ESP_ERROR_CHECK(esp_wifi_deinit());
    ESP_ERROR_CHECK(esp_wifi_clear_default_wifi_driver_and_handlers(wifi_netif));
    esp_netif_destroy(wifi_netif);
/** Event handler for Ethernet events */
static void on_eth_event(void *esp_netif, esp_event_base_t event_base,
    switch (event_id) {
    case ETHERNET_EVENT_CONNECTED:
        ESP_LOGI(TAG, "Ethernet Link Up");
    default:
static esp_eth_handle_t s_eth_handle = NULL;
static esp_eth_mac_t *s_mac = NULL;
static esp_eth_phy_t *s_phy = NULL;
static void *s_eth_glue = NULL;
    char *desc;
    esp_netif_inherent_config_t esp_netif_config = ESP_NETIF_INHERENT_DEFAULT_ETH();
    esp_netif_config.route_prio = 64;
    esp_netif_config_t netif_config = {
        .base = &esp_netif_config,
        .stack = ESP_NETIF_NETSTACK_DEFAULT_ETH
    esp_netif_t *netif = esp_netif_new(&netif_config);
    assert(netif);
    free(desc);
    // Set default handlers to process TCP/IP stuffs
    ESP_ERROR_CHECK(esp_eth_set_default_handlers(netif));
    // Register user defined event handers
    ESP_ERROR_CHECK(esp_event_handler_register(IP_EVENT, IP_EVENT_ETH_GOT_IP, &on_got_ip, NULL));
    ESP_ERROR_CHECK(esp_event_handler_register(ETH_EVENT, ETHERNET_EVENT_CONNECTED, &on_eth_event, netif));
#endif
    eth_mac_config_t mac_config = ETH_MAC_DEFAULT_CONFIG();
    eth_phy_config_t phy_config = ETH_PHY_DEFAULT_CONFIG();
    phy_config.phy_addr = CONFIG_EXAMPLE_ETH_PHY_ADDR;
    phy_config.reset_gpio_num = CONFIG_EXAMPLE_ETH_PHY_RST_GPIO;
#if CONFIG_EXAMPLE_USE_INTERNAL_ETHERNET
    mac_config.smi_mdc_gpio_num = CONFIG_EXAMPLE_ETH_MDC_GPIO;
    mac_config.smi_mdio_gpio_num = CONFIG_EXAMPLE_ETH_MDIO_GPIO;
    s_mac = esp_eth_mac_new_esp32(&mac_config);
#if CONFIG_EXAMPLE_ETH_PHY_IP101
    s_phy = esp_eth_phy_new_ip101(&phy_config);
#elif CONFIG_EXAMPLE_ETH_PHY_RTL8201
    s_phy = esp_eth_phy_new_rtl8201(&phy_config);
#elif CONFIG_EXAMPLE_ETH_PHY_LAN8720
    s_phy = esp_eth_phy_new_lan8720(&phy_config);
#elif CONFIG_EXAMPLE_ETH_PHY_DP83848
    s_phy = esp_eth_phy_new_dp83848(&phy_config);
#endif
#elif CONFIG_ETH_USE_SPI_ETHERNET
    gpio_install_isr_service(0);
    spi_device_handle_t spi_handle = NULL;
    spi_bus_config_t buscfg = {
        .miso_io_num = CONFIG_EXAMPLE_ETH_SPI_MISO_GPIO,
        .mosi_io_num = CONFIG_EXAMPLE_ETH_SPI_MOSI_GPIO,
        .sclk_io_num = CONFIG_EXAMPLE_ETH_SPI_SCLK_GPIO,
        .quadwp_io_num = -1,
        .quadhd_io_num = -1,
    ESP_ERROR_CHECK(spi_bus_initialize(CONFIG_EXAMPLE_ETH_SPI_HOST, &buscfg, 1));
#if CONFIG_EXAMPLE_USE_DM9051
    spi_device_interface_config_t devcfg = {
        .command_bits = 1,
        .address_bits = 7,
        .mode = 0,
        .clock_speed_hz = CONFIG_EXAMPLE_ETH_SPI_CLOCK_MHZ * 1000 * 1000,
        .spics_io_num = CONFIG_EXAMPLE_ETH_SPI_CS_GPIO,
        .queue_size = 20
    ESP_ERROR_CHECK(spi_bus_add_device(CONFIG_EXAMPLE_ETH_SPI_HOST, &devcfg, &spi_handle));
    /* dm9051 ethernet driver is based on spi driver */
    eth_dm9051_config_t dm9051_config = ETH_DM9051_DEFAULT_CONFIG(spi_handle);
    dm9051_config.int_gpio_num = CONFIG_EXAMPLE_ETH_SPI_INT_GPIO;
    s_mac = esp_eth_mac_new_dm9051(&dm9051_config, &mac_config);
    s_phy = esp_eth_phy_new_dm9051(&phy_config);
#elif CONFIG_EXAMPLE_USE_W5500
        .command_bits = 16, // Actually it's the address phase in W5500 SPI frame
        .address_bits = 8,  // Actually it's the control phase in W5500 SPI frame
        .mode = 0,
        .queue_size = 20
    /* w5500 ethernet driver is based on spi driver */
    eth_w5500_config_t w5500_config = ETH_W5500_DEFAULT_CONFIG(spi_handle);
    w5500_config.int_gpio_num = CONFIG_EXAMPLE_ETH_SPI_INT_GPIO;
    s_mac = esp_eth_mac_new_w5500(&w5500_config, &mac_config);
    s_phy = esp_eth_phy_new_w5500(&phy_config);
#endif
#elif CONFIG_EXAMPLE_USE_OPENETH
    phy_config.autonego_timeout_ms = 100;
    s_mac = esp_eth_mac_new_openeth(&mac_config);
#endif
    // Install Ethernet driver
    esp_eth_config_t config = ETH_DEFAULT_CONFIG(s_mac, s_phy);
    ESP_ERROR_CHECK(esp_eth_driver_install(&config, &s_eth_handle));
#if !CONFIG_EXAMPLE_USE_INTERNAL_ETHERNET
    /* The SPI Ethernet module might doesn't have a burned factory MAC address, we cat to set it manually.
       02:00:00 is a Locally Administered OUI range so should not be used except when testing on a LAN under your control.
    ESP_ERROR_CHECK(esp_eth_ioctl(s_eth_handle, ETH_CMD_S_MAC_ADDR, (uint8_t[]) {
        0x02, 0x00, 0x00, 0x12, 0x34, 0x56
#endif
    // combine driver with netif
    s_eth_glue = esp_eth_new_netif_glue(s_eth_handle);
    esp_netif_attach(netif, s_eth_glue);
    esp_eth_start(s_eth_handle);
    return netif;
    esp_netif_t *eth_netif = get_example_netif_from_desc("eth");
    ESP_ERROR_CHECK(esp_event_handler_unregister(IP_EVENT, IP_EVENT_ETH_GOT_IP, &on_got_ip));
    ESP_ERROR_CHECK(esp_event_handler_unregister(ETH_EVENT, ETHERNET_EVENT_CONNECTED, &on_eth_event));
#endif
    ESP_ERROR_CHECK(esp_eth_stop(s_eth_handle));
    ESP_ERROR_CHECK(esp_eth_del_netif_glue(s_eth_glue));
    ESP_ERROR_CHECK(esp_eth_clear_default_handlers(eth_netif));
    ESP_ERROR_CHECK(esp_eth_driver_uninstall(s_eth_handle));
    ESP_ERROR_CHECK(s_phy->del(s_phy));
    ESP_ERROR_CHECK(s_mac->del(s_mac));
    esp_netif_destroy(eth_netif);
esp_netif_t *get_example_netif(void)
    return s_example_esp_netif;
esp_netif_t *get_example_netif_from_desc(const char *desc)
    char *expected_desc;
    asprintf(&expected_desc, "%s: %s", TAG, desc);
    while ((netif = esp_netif_next(netif)) != NULL) {
        if (strcmp(esp_netif_get_desc(netif), expected_desc) == 0) {
            free(expected_desc);
            return netif;
    return netif;
My approach was to add a variable which counts the connection attemps in this function
    if(connectingcounter == 10)		// I added this part
        return;					//
        return;
after 10 attempts my accesspoint suppose to start. so i thought of adding my init_acces_point function.
void init_access_point(void)
        static httpd_handle_t serverap = NULL;
    //Initialize NVS
    if (ret == ESP_ERR_NVS_NO_FREE_PAGES || ret == ESP_ERR_NVS_NEW_VERSION_FOUND)
    ESP_ERROR_CHECK(ret);
    ESP_LOGI(APTAG, "ESP_WIFI_MODE_AP");
    wifi_init_softap();
    ESP_ERROR_CHECK(esp_event_handler_register(IP_EVENT, IP_EVENT_AP_STAIPASSIGNED, &connect_aphandler, &serverap));
  //  ESP_ERROR_CHECK(esp_event_handler_register(WIFI_EVENT, WIFI_EVENT_STA_DISCONNECTED, &disconnect_handler, &serverap));
which is included in my main.c file
Now 2 Questions arose.
1: How can i include my main.c file within the connect.c file ?
#include"main.c" didn't work.
2: Is this approach even a good approach? im not really sure. It feels like a provisionally solution for my problem. Does someone else got a more efficient approach ?
thanks in advance!
Users browsing this forum: Google [Bot] and 74 guests
