Cannot connect to WIFI from bare ESP32 board
dt4350
Postby dt4350 » Thu Nov 04, 2021 5:25 pm
Hello, I am using a bare ESP32 WROOM 32D module for prototyping: https://www.amazon.com/dp/B08XXH9RMT
I am using a simple breakout like this for uploading code/accessing the pins: https://www.amazon.com/dp/B08PNR6H1C
I am using the arduino IDE (v1.8.16) to upload code, and have successfully uploaded the blink sketch.
When I attempt to upload example sketches that use WIFI, the WIFI does not engage. The code uploads but it hangs on connecting to my WIFI network. This same code uploads and works properly on my Heltec ESP32 WIFI kit. I am including it at the end of my post for reference.
Might I need to make any config changes on the board that I haven't accounted for? Might I need to make any WIFI network changes? I successfully ran a network scan using the board, proving that it does in fact see my network.
Does anyone have any suggestions for troubleshooting? Thank you.
Code:
#include <WiFi.h>
#include "arduino_secrets.h"
//Provide your own WiFi credentials
const char* ssid = SECRET_SSID;
const char* password = SECRET_PASS;
  initializeWifi();
void initializeWifi() {
  //First, set the Wi-Fi mode. If the ESP32 will connected
  //to another network (access point/hotspot) it must be in station mode.
  WiFi.mode(WIFI_STA);
  //Then, use WiFi.begin() to connect to a network.
  //You must pass as arguments the network SSID and its password:
  WiFi.begin(ssid, password);
  //WiFi.setSleep(false);// this code solves my problem
  Serial.print("Connecting to WiFi ..");
  //Connecting to a Wi-Fi network can take a while, so we usually add
  //a while loop that keeps checking if the connection was already established
  //by using WiFi.status(). When the connection is successfully established,
  //it returns WL_CONNECTED.
    Serial.print('.');
    delay(1000);
  Serial.print("RRSI: ");
  Serial.println(WiFi.RSSI());
username
Re: Cannot connect to WIFI from bare ESP32 board
Postby username » Fri Nov 05, 2021 4:54 am
try WiFi.begin(ssid.c_str(), password.c_str());
dt4350
Postby dt4350 » Fri Nov 05, 2021 7:09 am
Thanks for your reply. That didn't work, unfortunately. It did prompt me to try hardcoding my ssid/password but that also didn't work.
ESP_Minatel
Postby ESP_Minatel » Fri Nov 05, 2021 8:02 am
Does your network provides 2.4GHz or it's 5GHz? ESP32 does not work on 5GHz band.
Please take a look at the WiFi API docs here.
dt4350
Postby dt4350 » Fri Nov 05, 2021 7:26 pm
Update: I have soldered a different bare module/breakout board and that one can successfully connect to my wifi network.
Is it possible that I somehow damaged the wifi chip/antenna of the first module during the soldering process?
dt4350
Postby dt4350 » Sat Nov 06, 2021 6:32 pm
Hi, I thought I had replied to your comment but I don't see it now. I'm sorry if it appears twice.
I am trying to connect to a 2.4GHz network. I've since soldered a separate module/breakout board together and successfully connected to my network with that one.
ESP_Minatel
Postby ESP_Minatel » Mon Nov 08, 2021 10:28 am
Everything is possible when hand soldering or working with the bare chip. It's hard to say.
Users browsing this forum: No registered users and 50 guests
