https simple example Error
Dansen
Postby Dansen » Mon Nov 01, 2021 8:06 am
Hello guys!
im facing some problems with my Visual Studio / esp-idf extension.
I was trying Implementing the https example and it worked fine, until Friday, where suddenly this Error appears:
C:/Users/Student/esp/esp-idf/components/esp_https_server/include/esp_https_server.h:91:5: error: expected identifier or '(' before '.' token
.httpd = { \
C:/Users/Student/esp/esp-idf/components/esp_https_server/include/esp_https_server.h:112:5: error: expected identifier or '(' before '.' token
.cacert_pem = NULL, \
[16/299] Building C object esp-idf/expat/CMakeFiles/__idf_expat.dir/expat/expat/lib/xmlparse.c.obj
The terminal process "C:\WINDOWS\System32\WindowsPowerShell\v1.0\powershell.exe -Command cmake --build ." terminated with exit code: 1.
I was very suprised, since i did not touch the headerfile. After trying some stuff i just decided to load a fresh new example and delete my old file.
Now the same problem appears again, without me doing anything on my example-file.
Someone ever got the same problem and can help out?
Thanks in advance!
and here's the example code
/* Simple HTTP + SSL Server Example
#include <esp_wifi.h>
#include <esp_event.h>
#include <esp_log.h>
#include <esp_system.h>
#include <nvs_flash.h>
#include <sys/param.h>
#include "esp_netif.h"
#include "esp_eth.h"
#include "protocol_examples_common.h"
#include <esp_https_server.h>
/* A simple example that demonstrates how to create GET and POST
 * handlers and start an HTTPS server.
static const char *TAG = "example";
/* An HTTP GET handler */
static esp_err_t root_get_handler(httpd_req_t *req)
    httpd_resp_set_type(req, "text/html");
    httpd_resp_send(req, "<h1>Hello Secure World!</h1>", HTTPD_RESP_USE_STRLEN);
    return ESP_OK;
static const httpd_uri_t root = {
    .uri       = "/",
    .method    = HTTP_GET,
    .handler   = root_get_handler
static httpd_handle_t start_webserver(void)
    httpd_handle_t server = NULL;
    // Start the httpd server
    ESP_LOGI(TAG, "Starting server");
    httpd_ssl_config_t conf = HTTPD_SSL_CONFIG_DEFAULT();
    extern const unsigned char cacert_pem_start[] asm("_binary_cacert_pem_start");
    extern const unsigned char cacert_pem_end[]   asm("_binary_cacert_pem_end");
    conf.cacert_pem = cacert_pem_start;
    conf.cacert_len = cacert_pem_end - cacert_pem_start;
    extern const unsigned char prvtkey_pem_start[] asm("_binary_prvtkey_pem_start");
    extern const unsigned char prvtkey_pem_end[]   asm("_binary_prvtkey_pem_end");
    conf.prvtkey_pem = prvtkey_pem_start;
    conf.prvtkey_len = prvtkey_pem_end - prvtkey_pem_start;
    esp_err_t ret = httpd_ssl_start(&server, &conf);
    if (ESP_OK != ret) {
        ESP_LOGI(TAG, "Error starting server!");
        return NULL;
    // Set URI handlers
    ESP_LOGI(TAG, "Registering URI handlers");
    httpd_register_uri_handler(server, &root);
    return server;
static void stop_webserver(httpd_handle_t server)
    // Stop the httpd server
    httpd_ssl_stop(server);
static void disconnect_handler(void* arg, esp_event_base_t event_base,
                               int32_t event_id, void* event_data)
    httpd_handle_t* server = (httpd_handle_t*) arg;
    if (*server) {
        stop_webserver(*server);
        *server = NULL;
static void connect_handler(void* arg, esp_event_base_t event_base,
    if (*server == NULL) {
        *server = start_webserver();
void app_main(void)
    static httpd_handle_t server = NULL;
    ESP_ERROR_CHECK(nvs_flash_init());
    /* Register event handlers to start server when Wi-Fi or Ethernet is connected,
     * and stop server when disconnection happens.
#ifdef CONFIG_EXAMPLE_CONNECT_WIFI
    ESP_ERROR_CHECK(esp_event_handler_register(IP_EVENT, IP_EVENT_STA_GOT_IP, &connect_handler, &server));
    ESP_ERROR_CHECK(esp_event_handler_register(WIFI_EVENT, WIFI_EVENT_STA_DISCONNECTED, &disconnect_handler, &server));
#endif // CONFIG_EXAMPLE_CONNECT_WIFI
#ifdef CONFIG_EXAMPLE_CONNECT_ETHERNET
    ESP_ERROR_CHECK(esp_event_handler_register(IP_EVENT, IP_EVENT_ETH_GOT_IP, &connect_handler, &server));
    ESP_ERROR_CHECK(esp_event_handler_register(ETH_EVENT, ETHERNET_EVENT_DISCONNECTED, &disconnect_handler, &server));
#endif // CONFIG_EXAMPLE_CONNECT_ETHERNET
    /* This helper function configures Wi-Fi or Ethernet, as selected in menuconfig.
     * Read "Establishing Wi-Fi or Ethernet Connection" section in
     * examples/protocols/README.md for more information about this function.
    ESP_ERROR_CHECK(example_connect());
and here is the headerfile I am getting Errors for
// Copyright 2018 Espressif Systems (Shanghai) PTE LTD
// Licensed under the Apache License, Version 2.0 (the "License");
// you may not use this file except in compliance with the License.
// You may obtain a copy of the License at
//     http://www.apache.org/licenses/LICENSE-2.0
// Unless required by applicable law or agreed to in writing, software
// distributed under the License is distributed on an "AS IS" BASIS,
// WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
// See the License for the specific language governing permissions and
// limitations under the License.
#ifndef _ESP_HTTPS_SERVER_H_
#define _ESP_HTTPS_SERVER_H_
#include <stdbool.h>
#include "esp_err.h"
#include "esp_http_server.h"
#ifdef __cplusplus
extern "C" {
#endif
typedef enum {
    HTTPD_SSL_TRANSPORT_SECURE,      // SSL Enabled
    HTTPD_SSL_TRANSPORT_INSECURE     // SSL disabled
} httpd_ssl_transport_mode_t;
 * HTTPS server config struct
 * Please use HTTPD_SSL_CONFIG_DEFAULT() to initialize it.
struct httpd_ssl_config {
     * Underlying HTTPD server config
     * Parameters like task stack size and priority can be adjusted here.
    httpd_config_t httpd;
    /** CA certificate (here it is treated as server cert)
     * Todo: Fix this change in release/v5.0 as it would be a breaking change
     * i.e. Rename the nomenclature of variables holding different certs in https_server component as well as example
     * 1)The cacert variable should hold the CA which is used to authenticate clients (should inherit current role of client_verify_cert_pem var)
     * 2)There should be another variable servercert which whould hold servers own certificate (should inherit current role of cacert var) */
    const uint8_t *cacert_pem;
    /** CA certificate byte length */
    size_t cacert_len;
    /** Client verify authority certificate (CA used to sign clients, or client cert itself */
    const uint8_t *client_verify_cert_pem;
    /** Client verify authority cert len */
    size_t client_verify_cert_len;
    /** Private key */
    const uint8_t *prvtkey_pem;
    /** Private key byte length */
    size_t prvtkey_len;
    /** Transport Mode (default secure) */
    httpd_ssl_transport_mode_t transport_mode;
    /** Port used when transport mode is secure (default 443) */
    uint16_t port_secure;
    /** Port used when transport mode is insecure (default 80) */
    uint16_t port_insecure;
typedef struct httpd_ssl_config httpd_ssl_config_t;
 * Default config struct init
 * (http_server default config had to be copied for customization)
 * Notes:
 * - port is set when starting the server, according to 'transport_mode'
 * - one socket uses ~ 40kB RAM with SSL, we reduce the default socket count to 4
 * - SSL sockets are usually long-lived, closing LRU prevents pool exhaustion DOS
 * - Stack size may need adjustments depending on the user application
#define HTTPD_SSL_CONFIG_DEFAULT() {              \
    .httpd = {                                    \
        .task_priority      = tskIDLE_PRIORITY+5, \
        .stack_size         = 10240,              \
        .core_id            = tskNO_AFFINITY,     \
        .server_port        = 0,                  \
        .ctrl_port          = 32768,              \
        .max_open_sockets   = 4,                  \
        .max_uri_handlers   = 8,                  \
        .max_resp_headers   = 8,                  \
        .backlog_conn       = 5,                  \
        .lru_purge_enable   = true,               \
        .recv_wait_timeout  = 5,                  \
        .send_wait_timeout  = 5,                  \
        .global_user_ctx = NULL,                  \
        .global_user_ctx_free_fn = NULL,          \
        .global_transport_ctx = NULL,             \
        .global_transport_ctx_free_fn = NULL,     \
        .open_fn = NULL,                          \
        .close_fn = NULL,                         \
        .uri_match_fn = NULL                      \
    .cacert_len = 0,                              \
    .client_verify_cert_pem = NULL,               \
    .client_verify_cert_len = 0,                  \
    .prvtkey_pem = NULL,                          \
    .prvtkey_len = 0,                             \
    .transport_mode = HTTPD_SSL_TRANSPORT_SECURE, \
    .port_secure = 443,                           \
    .port_insecure = 80,                          \
 * Create a SSL capable HTTP server (secure mode may be disabled in config)
 * @param[in,out] config - server config, must not be const. Does not have to stay valid after
 *                         calling this function.
 * @param[out] handle - storage for the server handle, must be a valid pointer
 * @return success
esp_err_t httpd_ssl_start(httpd_handle_t *handle, httpd_ssl_config_t *config);
 * Stop the server. Blocks until the server is shut down.
 * @param[in] handle
void httpd_ssl_stop(httpd_handle_t handle);
#ifdef __cplusplus
#endif
#endif // _ESP_HTTPS_SERVER_H_
Users browsing this forum: No registered users and 70 guests
