I use openSUSE Tumbleweed (actual updates) and already working ESP-IDF 4.3.1.
All requirements for the installation of the plugin have been met.
I try to install Eclipse Embedded CDT 2021-09 and the ESP-IDF Eclipse plugin from scratch following instructions at https://github.com/espressif/idf-eclipse-plugin and get the error as seen in the attachment "Install Remediation Page".
If I continue with the installation, the plugin will not be installed!
Is it really incompatible?
Thanks in advance
Michael
ESP-IDF Eclipse Plugin incompatible with Eclipse Embedded CDT IDE 2021-09
- Available Software.png (143.91 KiB) Viewed 6589 times
- Install Remediation Page.png (126.89 KiB) Viewed 6589 times
Nobody is perfect!
My name is NOT Nobody...
Nobody lives forever to correct his mistakes someday in the future, if not right now!
Covid-19 is not responsible for any human failures!
Re: ESP-IDF Eclipse Plugin incompatible with Eclipse Embedded CDT IDE 2021-09
Eclipse Embedded CDT 2021-09 is not supported with IDF Eclipse Plugin 2.2.0 due to OpenOCD plugin conflicting dependencies, Please continue to use Eclipse IDE for C/C++ Developers 2021-06 version
However, you should be able to update third-party plugins within your Eclipse IDE for C/C++ Developers 2021-06 if it's supported.
Users browsing this forum: No registered users and 9 guests
