I2c behaving differently on idf 3.3 and 4.2
Praveen.kullu
Postby Praveen.kullu » Thu Sep 30, 2021 12:39 pm
i have interfaced CPT112S with my esp32. reading from touch data from sensor it reads couple of times but stops reading (in the case of slider). also it is giving TIMEOUT error. this is not in case of idf 3.3. fraction of related logs is attached below.
I have interfaced CPT112S via i2c to my esp32. the sensor gives an interrupt, from this gpio interrupt handler sends a queue to "gpio_task_example" Task, which will then read our touch buffer from sensor. i am giving this buffer data to "cpt112s_parse_event" and "cpt112s_button_event" for processing slider and touch events respectively.
following are related functions:
#define I2C_MASTER_NUM              I2C_NUM_0    //I2C_NUMBER(CONFIG_I2C_MASTER_PORT_NUM) /*!< I2C port number for master dev */
#define I2C_MASTER_FREQ_HZ          100000   /*!< I2C master clock frequency */
#define I2C_MASTER_TX_BUF_DISABLE   0 /*!< I2C master doesn't need buffer */
#define I2C_MASTER_RX_BUF_DISABLE   0 /*!< I2C master doesn't need buffer */
#define CPT112S_ADDRESS             0x09        /*!< ESP32 slave address, you can set any 7bit value */
#define WRITE_BIT                   I2C_MASTER_WRITE /*!< I2C master write */
#define READ_BIT                    I2C_MASTER_READ   /*!< I2C master read */
#define ACK_CHECK_EN                0x1           /*!< I2C master will check ack from slave*/
#define ACK_CHECK_DIS               0x0          /*!< I2C master will not check ack from slave */
#define ACK_VAL                     0x0                /*!< I2C ack value */
#define NACK_VAL                    0x1               /*!< I2C nack value */
#define ESP_INTR_FLAG_DEFAULT       0
#define CPT112S_EVENT_TOUCH         0x00
#define CPT112S_EVENT_TOUCH_RELEASE 0x01
#define CPT112S_EVENT_SLIDER        0x02
#define CPT112S_EVENT_TYPE(x)       (x & 0x0f)
#define CPT112S_EVENT_COUNTER(x)    ((x & 0xf0) >> 4)
#define CPT112S_SLIDER_THRESHOLD    50
#define CPT112S_EVENT_SLIDER_POSITION(x, y) ((x << 8 | y))
static void cpt112s_button_event(uint8_t *event)
    //0x04, 0x05, 0x06, 0x07, 0x08, 0x09,0xa0
    // event [0], event [1] event [2]
    //int validetor =0x00;
    if (event[1] == 0x04)
        if (event[0] % 2 == 1)
            ESP_LOGI(TAG, "gpio release event[1] with value: 0x%02x ", event[1]);
            // switch_value(1);
    else if (event[1] == 0x05)
            // switch_value(2);
    else if (event[1] == 0x06)
            // switch_value(3);
    else if (event[1] == 0x07)
            ESP_LOGI(TAG, "gpio release event  with value: 0x%02x ", event[1]);
            // switch_value(4);
    else if (event[1] == 0x08)
            // switch_value(5);
    else if (event[1] == 0x09)
            // switch_value(6);
    else
static void cpt112s_parse_event(uint8_t *event)
    ESP_LOGI(TAG, "cpt112s_parse_event. ");
    int eventType = CPT112S_EVENT_TYPE(event[0]);
    static int16_t lastSliderPos = -1;
    static uint32_t lastSliderTime = 0;
    uint32_t currtime = xthal_get_ccount();
    uint32_t diff = currtime - lastSliderTime;
    if (CPT112S_EVENT_TOUCH == eventType)
        ESP_LOGI(TAG, "eventType = EVENT_TOUCH ");
    else if (CPT112S_EVENT_TOUCH_RELEASE == eventType)
        ESP_LOGI(TAG, "eventType = EVENT_TOUCH_RELEASE ");
    else if (CPT112S_EVENT_SLIDER == eventType)
        ESP_LOGI(TAG, "eventType = EVENT_SLIDER ");
        int currentPos = CPT112S_EVENT_SLIDER_POSITION(event[1], event[2]);
        if (currentPos == 0xffff)
            ESP_LOGI(TAG, "%s: SLIDER RELEASE", __func__);
            //slider release, skip it
            lastSliderPos = -1;
            return;
        if (lastSliderPos < 0)
            //slider touch
            lastSliderPos = currentPos;
            lastSliderTime = currtime;
            ESP_LOGI(TAG, "%d: SLIDER TOUCH: lastSliderPos %d, lastSliderTime %d", __LINE__, lastSliderPos, lastSliderTime);
            return;
        ESP_LOGI(TAG, "%d: SLIDER0: =====> lastSliderPos %d lastSliderTime  %d", __LINE__, lastSliderPos, lastSliderTime);
        ESP_LOGI(TAG, "%d: SLIDER1: =====> currentPos %d  diff  %d", __LINE__, currentPos, diff / 240000);
        check_value(currentPos);
        if (abs(currentPos - lastSliderPos) < CPT112S_SLIDER_THRESHOLD)
            return;
esp_err_t i2c_master_read_slave(uint8_t addr, uint8_t *buf)
    esp_err_t ret = ESP_OK;
    ESP_LOGD(TAG, "i2c_master_read_slave \n");
    i2c_cmd_handle_t cmd = i2c_cmd_link_create();
    ret = i2c_master_start(cmd);
    if(ret != ESP_OK)
        ESP_LOGI(TAG, "i2c_master_start error %s", esp_err_to_name(ret));
    ret = i2c_master_write_byte(cmd, (CPT112S_ADDRESS << 1) | READ_BIT, ACK_CHECK_EN);
    // ret = i2c_master_write_byte(cmd, (CPT112S_ADDRESS << 1) | READ_BIT, ACK_CHECK_DIS);
    if(ret != ESP_OK)
        ESP_LOGI(TAG, "i2c_master_write_byte error %s", esp_err_to_name(ret));
    ret = i2c_master_read(cmd, buf, 2, ACK_VAL);
    if(ret != ESP_OK)
        ESP_LOGI(TAG, "i2c_master_read error %s", esp_err_to_name(ret));
    ret = i2c_master_read_byte(cmd, &buf[2], NACK_VAL);
    if(ret != ESP_OK)
        ESP_LOGI(TAG, "i2c_master_read_byte error %s", esp_err_to_name(ret));
    i2c_master_stop(cmd);
    ret = i2c_master_cmd_begin(I2C_MASTER_NUM, cmd, 2000 / portTICK_RATE_MS);
    if(ret != ESP_OK)
        ESP_LOGI(TAG, "i2c_master_cmd_begin error %s", esp_err_to_name(ret));
    i2c_cmd_link_delete(cmd);
    return ret;
static void gpio_task_example(void *arg)
    ESP_LOGI(TAG, "gpio_task_example");
    uint32_t io_num;
    esp_err_t ret;
    for (;;)
        if (xQueueReceiveFromISR(gpio_evt_queue, &io_num, portMAX_DELAY))
            ret = i2c_master_read_slave(CPT112S_ADDRESS, &buf);
            if(ret != ESP_OK)
                // ESP_LOGI(TAG, "i2c_master_read_slave error %s", esp_err_to_name(ret));
            }else{
                ESP_LOGI(TAG, "i2c_master_read_slave %s", esp_err_to_name(ret));
                cpt112s_parse_event(buf);
                cpt112s_button_event(buf);
        vTaskDelay(100 / portTICK_RATE_MS);
    vTaskDelete(NULL);
static esp_err_t i2c_master_init()
    ESP_LOGI(TAG, "i2c_master_init");
    int i2c_master_port = I2C_MASTER_NUM;
    i2c_config_t conf;
    conf.mode = I2C_MODE_MASTER;
    conf.sda_io_num = CPT_I2C_SDA;
    conf.sda_pullup_en = GPIO_PULLUP_ENABLE;
    conf.scl_io_num = CPT_I2C_SCL;
    conf.scl_pullup_en = GPIO_PULLUP_ENABLE;
    conf.master.clk_speed = I2C_MASTER_FREQ_HZ;
    i2c_param_config(i2c_master_port, &conf);
    return i2c_driver_install(i2c_master_port, conf.mode,
                              I2C_MASTER_RX_BUF_DISABLE,
                              I2C_MASTER_TX_BUF_DISABLE, 0);
The the i2c settings and functional logic used is same on other idf 3.3 and idf 4.2. on the idf 3.3 i am able to read data from sensor successfully even in the case of slider.
sliderol.txt
idf3.3
(24 KiB) Downloaded 220 times
idf3.3
idf4.4
Users browsing this forum: No registered users and 93 guests
