Problem with "example /protocols/mqtt/tcp" - ESP-WROOM-32
esp32begin
Postby esp32begin » Sat Sep 18, 2021 10:47 am
I have got a problem with the code of the example mqtt/tcp --- espressif /
esp-idf
"https://github.com/espressif/esp-idf/t ... /mqtt/tcp",
the message is:
E (941400) TRANS_TCP: [sock=54] select() timeout
E (941400) MQTT_CLIENT: Error transport connect
I upload the same code....what's the problem?... I know that I'm doing bad. My ESP is ESP-WROOM-32...
Could anyone help me?
Thanks a lot
esp32begin
Re: Problem with "example /protocols/mqtt/tcp" - ESP-WROOM-32
Postby esp32begin » Mon Sep 20, 2021 4:31 pm
I solved it, I was entering the broker address wrong
Lalo_mohedano
Postby Lalo_mohedano » Wed Jun 22, 2022 4:50 am
how did you enter the URI?
I am having the same issue, I am trying to connect to a local mosquitto broker connected on the same wifi network. I am doing this
esp_mqtt_client_config_t mqtt_cfg = {
.uri = "mqtt://10.0.2.15:1883",
//.port = 1883
noweare
Postby noweare » Fri Sep 09, 2022 2:18 pm
What is the error msg you recieve.
If you have any type of security you need to pass that to the broker i.e. username and password
Users browsing this forum: No registered users and 20 guests
