Hi
When running idf.py menuconfig from a IDF terminal I get a nice view with a lot of options. (see attachement)
Unfourtnatly I cant move the cursor so I am unable to configure my project. (Maybe I am misunderstanding something here)
( IDF terminal is a PowerShell )
How do I configure my project. Is there other ways to go ?
Unable to run menuConfig
- Configuration
- Config.PNG (39.3 KiB) Viewed 7933 times
Re: Unable to run menuConfig
You are running the menuconfig from the terminal will not give the cursor access to it. For you to move in it use the arrow keys
If you want to use the cursor you can try our extension and use the SDK Configuration editor command for a GUI version of this menuconfig.
Ahh.. sorry,, my mistake. Running menuconfig worked fine, when starting it using vscode commands.
At least, it have been working for a long while. Now it suddenly stopped to work. It hangs on "loading initial values".
What can it be now ??
This is my doctor file:
---------------------------------------------- ESP-IDF Extension for Visual Studio Code report ---------------------------------------------
OS win32 x64 10.0.19043
System environment variable IDF_PYTHON_ENV_PATH
undefined
System environment variable PATH
C:\Program Files (x86)\Common Files\Oracle\Java\javapath;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\iCLS\;C:\Program Files\Intel\Intel(R) Management Engine Components\iCLS\;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\ProgramData\flutter\bin;C:\WINDOWS\System32\OpenSSH\;C:\Program Files\Intel\WiFi\bin\;C:\Program Files\Common Files\Intel\WirelessCommon\;C:\Program Files (x86)\Bitvise SSH Client;C:\Program Files\dotnet\;C:\Program Files\Git\cmd;C:\Program Files\Java\jdk1.8.0_301\bin;;C:\Program Files\Docker\Docker\resources\bin;C:\ProgramData\DockerDesktop\version-bin;C:\Users\lglin\AppData\Local\Programs\Python\Python39\Scripts\;C:\Users\lglin\AppData\Local\Programs\Python\Python39\;C:\Users\lglin\AppData\Local\Microsoft\WindowsApps;;C:\Program Files\Inkscape\bin;C:\Users\lglin\AppData\Local\Programs\Microsoft VS Code\bin
System environment variable PYTHON
undefined
Visual Studio Code version 1.60.2
Visual Studio Code language en
Visual Studio Code shell C:\WINDOWS\System32\WindowsPowerShell\v1.0\powershell.exe
ESP-IDF Extension version 1.2.0
---------------------------------------------------- Extension configuration settings ------------------------------------------------------
ESP-ADF Path (idf.espAdfPath) ${env:ADF_PATH}
ESP-IDF Path (idf.espIdfPath) C:\Users\lglin\esp\esp-idf
ESP-MDF Path (idf.espMdfPath) ${env:MDF_PATH}
Custom extra paths (idf.customExtraPaths) C:\Users\lglin\.espressif\tools\xtensa-esp32-elf\esp-2021r1-8.4.0\xtensa-esp32-elf\bin;C:\Users\lglin\.espressif\tools\xtensa-esp32s2-elf\esp-2021r1-8.4.0\xtensa-esp32s2-elf\bin;C:\Users\lglin\.espressif\tools\xtensa-esp32s3-elf\esp-2021r1-8.4.0\xtensa-esp32s3-elf\bin;C:\Users\lglin\.espressif\tools\riscv32-esp-elf\esp-2021r1-8.4.0\riscv32-esp-elf\bin;C:\Users\lglin\.espressif\tools\esp32ulp-elf\2.28.51-esp-20191205\esp32ulp-elf-binutils\bin;C:\Users\lglin\.espressif\tools\esp32s2ulp-elf\2.28.51-esp-20191205\esp32s2ulp-elf-binutils\bin;C:\Users\lglin\.espressif\tools\cmake\3.16.4\bin;C:\Users\lglin\.espressif\tools\openocd-esp32\v0.10.0-esp32-20210401\openocd-esp32\bin;C:\Users\lglin\.espressif\tools\ninja\1.10.2;C:\Users\lglin\.espressif\tools\idf-exe\1.0.1;C:\Users\lglin\.espressif\tools\ccache\3.7;C:\Users\lglin\.espressif\tools\dfu-util\0.9\dfu-util-0.9-win64
Custom extra vars (idf.customExtraVars) {"OPENOCD_SCRIPTS":"C:\\Users\\lglin\\.espressif\\tools\\openocd-esp32\\v0.10.0-esp32-20210401/openocd-esp32/share/openocd/scripts","IDF_CCACHE_ENABLE":"1"}
Virtual env Python Path (idf.pythonBinPath) C:\Users\lglin\.espressif\python_env\idf4.3_py3.8_env\Scripts\python.exe
Serial port (idf.port) COM3
OpenOCD Configs (idf.openOcdConfigs) boards/esp32-wrover-kit-3.3v.cfg
ESP-IDF Tools Path (idf.toolsPath) C:\Users\lglin\.espressif
Git Path (idf.gitPath) C:\Users\lglin\.espressif\tools\idf-git\2.30.1\cmd\git.exe
-------------------------------------------------------- Configurations access -------------------------------------------------------------
Access to ESP-ADF Path (idf.espAdfPath) false
Access to ESP-IDF Path (idf.espIdfPath) true
Access to ESP-MDF Path (idf.espMdfPath) false
Access to ESP-IDF Custom extra paths
Access to C:\Users\lglin\.espressif\tools\xtensa-esp32-elf\esp-2021r1-8.4.0\xtensa-esp32-elf\bin: true
Access to C:\Users\lglin\.espressif\tools\xtensa-esp32s2-elf\esp-2021r1-8.4.0\xtensa-esp32s2-elf\bin: true
Access to C:\Users\lglin\.espressif\tools\xtensa-esp32s3-elf\esp-2021r1-8.4.0\xtensa-esp32s3-elf\bin: true
Access to C:\Users\lglin\.espressif\tools\riscv32-esp-elf\esp-2021r1-8.4.0\riscv32-esp-elf\bin: true
Access to C:\Users\lglin\.espressif\tools\esp32ulp-elf\2.28.51-esp-20191205\esp32ulp-elf-binutils\bin: true
Access to C:\Users\lglin\.espressif\tools\esp32s2ulp-elf\2.28.51-esp-20191205\esp32s2ulp-elf-binutils\bin: true
Access to C:\Users\lglin\.espressif\tools\cmake\3.16.4\bin: true
Access to C:\Users\lglin\.espressif\tools\openocd-esp32\v0.10.0-esp32-20210401\openocd-esp32\bin: true
Access to C:\Users\lglin\.espressif\tools\ninja\1.10.2: true
Access to C:\Users\lglin\.espressif\tools\idf-exe\1.0.1: true
Access to C:\Users\lglin\.espressif\tools\ccache\3.7: true
Access to C:\Users\lglin\.espressif\tools\dfu-util\0.9\dfu-util-0.9-win64: true
Access to Virtual env Python Path (idf.pythonBinPath) true
Access to CMake in environment PATH undefined
Access to Ninja in environment PATH undefined
Access to ESP-IDF Tools Path (idf.toolsPath) true
----------------------------------------------------------- Executables Versions -----------------------------------------------------------
Git version 2.30.1.windows.1
ESP-IDF version 4.3.1
Python version 3.8.7
Python's pip version 20.3.3
-------------------------------------------------- Python packages in idf.pythonBinPath ----------------------------------------------------
bitstring version: 3.1.9
Brotli version: 1.0.9
certifi version: 2021.5.30
cffi version: 1.14.6
charset-normalizer version: 2.0.6
click version: 8.0.1
colorama version: 0.4.4
construct version: 2.10.54
contextlib2 version: 21.6.0
cryptography version: 3.4.8
ecdsa version: 0.17.0
esp-windows-curses version: 0.1
Flask version: 0.12.5
Flask-Compress version: 1.10.1
Flask-SocketIO version: 2.9.6
future version: 0.18.2
gcovr version: 5.0
gdbgui version: 0.13.2.0
gevent version: 1.5.0
greenlet version: 1.1.1
idf-component-manager version: 0.3.0b0
idna version: 3.2
itsdangerous version: 2.0.1
Jinja2 version: 3.0.1
kconfiglib version: 13.7.1
lxml version: 4.6.3
MarkupSafe version: 2.0.1
pip version: 20.3.3
psutil version: 5.8.0
pycparser version: 2.20
pyelftools version: 0.27
pygdbmi version: 0.9.0.2
Pygments version: 2.10.0
pyparsing version: 2.3.1
pyserial version: 3.5
python-engineio version: 3.14.2
python-socketio version: 4.6.1
pywin32 version: 301
PyYAML version: 5.4.1
reedsolo version: 1.5.4
requests version: 2.26.0
requests-toolbelt version: 0.9.1
schema version: 0.7.4
semantic-version version: 2.8.5
setuptools version: 58.0.4
six version: 1.16.0
tqdm version: 4.62.2
urllib3 version: 1.26.6
websocket-client version: 1.2.1
Werkzeug version: 0.16.1
wheel version: 0.36.2
windows-curses version: 2.2.0
xmlrunner version: 1.7.7
---------------------------------------------------- Check ESP-IDF python requirements.txt -------------------------------------------------
Check ESP-IDF Python packages Python requirements from C:\Users\lglin\esp\esp-idf\requirements.txt are satisfied.
---------------------------------------------------- Check extension requirements.txt ------------------------------------------------------
Check Extension Python packages Python requirements from c:\Users\lglin\.vscode\extensions\espressif.esp-idf-extension-1.2.0\requirements.txt are satisfied.
---------------------------------------------------- Check ESP-IDF debug adapter requirements.txt ------------------------------------------
Check Debug AdapterPython packages Python requirements from c:\Users\lglin\.vscode\extensions\espressif.esp-idf-extension-1.2.0\esp_debug_adapter\requirements.txt are satisfied.
---------------------------------------------------- Visual Studio Code launch.json --------------------------------------------------------
"version": "0.2.0",
"configurations": [
"type": "espidf",
"name": "Launch",
"request": "launch"
---------------------------------------------------- Visual Studio Code c_cpp_properties.json ----------------------------------------------
"configurations": [
"name": "ESP-IDF",
"compilerPath": "C:\\Users\\lglin\\.espressif\\tools\\xtensa-esp32-elf\\esp-2021r1-8.4.0\\xtensa-esp32-elf\\bin\\xtensa-esp32-elf-gcc.exe",
"cStandard": "c11",
"cppStandard": "c++17",
"includePath": [
"${config:idf.espIdfPath}/components/**",
"${config:idf.espIdfPathWin}/components/**",
"${config:idf.espAdfPath}/components/**",
"${config:idf.espAdfPathWin}/components/**",
"${workspaceFolder}/**"
"browse": {
"path": [
"${config:idf.espIdfPath}/components",
"${config:idf.espIdfPathWin}/components",
"${workspaceFolder}"
"limitSymbolsToIncludedHeaders": false
"compileCommands": "C:/HOSTEDPROJECTS/ESP-IDF/MDCB/BUILD/COMPILE_COMMANDS.JSON"
"version": 4
Just cleaning up posts.. solved.
Users browsing this forum: No registered users and 8 guests
