BT address type changes
flonas
Postby flonas » Tue Sep 14, 2021 1:40 pm
I am currently developing an app for ESP32 using NimBLE, that will pair and bond with an Android and iOS application. I am using "just works" pairing method.
I am setting the address of the ES32 to BLE_OWN_ADDR_RANDOM so that it will work with the iOS app. However, I see that the address types of both phone and ES32 are set to zero (public):
I (133324) BT_PERIPHERAL: connection established; status=0
I (133325) BT_PERIPHERAL: Connection established
I (133326) BT_PERIPHERAL: handle=0 our_ota_addr_type=1 our_ota_addr=6c:f5:1c:c8:40:5a
I (133337) BT_PERIPHERAL: our_id_addr_type=0 our_id_addr=b8:f0:09:8f:7b:9e
I (133348) BT_PERIPHERAL: peer_ota_addr_type=0 peer_ota_addr=78:e3:de:26:e3:91
I (133359) BT_PERIPHERAL: peer_id_addr_type=0 peer_id_addr=78:e3:de:26:e3:91
I (133360) BT_PERIPHERAL: conn_itvl=24 conn_latency=0 supervision_timeout=72 encrypted=0 authenticated=0 bonded=0
Also, sometimes it changes between public and random:
I (26610) BT_PERIPHERAL: BLE_GAP_EVENT_REPEAT_PAIRING
I (49114) BT_PERIPHERAL: encryption change event; status=0
I (49115) BT_PERIPHERAL: handle=0 our_ota_addr_type=1 our_ota_addr=6c:f5:1c:c8:40:5a
I (49126) BT_PERIPHERAL: our_id_addr_type=1 our_id_addr=6c:f5:1c:c8:40:5a
I (49127) BT_PERIPHERAL: peer_ota_addr_type=1 peer_ota_addr=5a:5a:40:4c:0f:2b
I (49138) BT_PERIPHERAL: peer_id_addr_type=1 peer_id_addr=5a:5a:40:4c:0f:2b
I (49149) BT_PERIPHERAL: conn_itvl=24 conn_latency=0 supervision_timeout=72 encrypted=1 authenticated=0 bonded=1
I (49163) BT_PERIPHERAL: event->type = 10
I (62253) BT_PERIPHERAL: subscribe event; conn_handle=0 attr_handle=11 reason=2 prevn=0 curn=0 previ=1 curi=0
I (62255) BT_PERIPHERAL: disconnect; reason=531
I (62266) BT_PERIPHERAL: handle=0 our_ota_addr_type=1 our_ota_addr=6c:f5:1c:c8:40:5a
I (62277) BT_PERIPHERAL: our_id_addr_type=0 our_id_addr=b8:f0:09:8f:7b:9e
I (62278) BT_PERIPHERAL: peer_ota_addr_type=0 peer_ota_addr=78:e3:de:26:e3:91
I (62288) BT_PERIPHERAL: peer_id_addr_type=0 peer_id_addr=78:e3:de:26:e3:91
I (62300) BT_PERIPHERAL: conn_itvl=24 conn_latency=0 supervision_timeout=72 encrypted=1 authenticated=0 bonded=1
This behavior seems to affect pairing on the iOS side, since I have to manually forget the previous bonding, in order to be able to bond again. Otherwise, the "Peer removed pairing information" error appears.
Any suggestion would be really helpful.
Florin
imdahisaria
Re: BT address type changes
Postby imdahisaria » Wed Jun 22, 2022 6:55 am
Hi Florin,
I am facing the same issue you have described. Were you able to find the solution ? Your help would be highly appreciated.
Thank you
RD
irahul
Postby irahul » Wed Jun 22, 2022 10:50 am
For ESP32, it doesn't support controller based privacy. Host based privacy support was enabled for ESP32. Can you check if enabling host based privacy macro "BLE_HOST_BASED_PRIVACY" helps ?
Users browsing this forum: Majestic-12 [Bot], MicroController and 59 guests
