Hi:
Trying to turn on Bluetooth classic in esp32 using AT commands. Want to set the thing up to connect and establish SPP connection. Application is for a propeller chip, and it has no operating system per-se. Ideally if there is a driver out there written in SPIN that would be great, but a step by step AT call sequence is what I need.
Any help greatly appreciated.
Wes.
Starting and using Bluetooth SPP with AT commands
Re: Starting and using Bluetooth SPP with AT commands
BLE SPP or classic BT SPP?
BLE SPP: https://docs.espressif.com/projects/esp ... am-UARTBLE
Classic BT: https://docs.espressif.com/projects/esp ... tooth.html
For BLE SPP, you can refer to https://docs.espressif.com/projects/esp ... mples.html
For Classic BT, you can refer to https://docs.espressif.com/projects/esp ... mples.html
