how to set esp32 i2s to 24bit?
ride_dirt
Postby ride_dirt » Tue Aug 31, 2021 1:09 pm
Hi I'm working on an a2dp project and having trouble setting the i2s bits on the esp32 to 24 bit. The example I am using(pipeline_a2dp_source_stream) has it set to 16 and I cant find where to change it. My codec needs 24 bit
Thank you
ims67-fdc
Re: how to set esp32 i2s to 24bit?
Postby ims67-fdc » Thu Oct 28, 2021 4:27 pm
Have you tried to set
i2s_cfg.i2s_config.bits_per_sample = I2S_BITS_PER_SAMPLE_24BIT;
after calling
i2s_stream_cfg_t i2s_cfg = I2S_STREAM_CFG_DEFAULT();
You should also check if the I2S input stream format is 24 bit/sample.
Users browsing this forum: No registered users and 22 guests
