Hi
We have a device using ESP32. This device is connected to a WebSocket server using a WebSocket client. Sometimes it need to use the esp_http_client to get a file from a server.
We found a problem in specific circonstances:
When we are connected to the WebSocket server and we open the esp_http_client and read the begin of a remote file (70 bytes), if the esp_http_client connexion stay open for a long without more reads then at some point (6 or 7 minutes) we loose the websocket connection and the esp32 is not able to reconnect.
With Wiresharks we can see that the esp_http_client connexion received 5744 bytes (size of TCP_WINDOW), but we only read 70 bytes. So the remaining bytes stay in TCP_WINDOW lwip buffer.
We have a lot of "TCP ZERO WINDOW" traces, but it's normal because we don't read bytes coming from the http connexion and they stay in TCP_WINDOW buffer. (this is for the test)
Questions:
- The TCP_WINDOW buffer in LWIP is per sockets or global ?
- Is it a problem to keep data in TCP_WINDOW buffer and not reading it for a while without closing the connexion ? Does it makes troubles in LWiP ?
- Do you have an idea why this esp_http_client connexion freeze the WebSocket connexion ? What can cause this ?
Problem when the connection stay open (esp_http_client)
Users browsing this forum: Baidu [Spider], Bing [Bot], ESP_igrr, Gaston1980 and 100 guests
