UART_FIFO_OVF happens each 2 seconds when enabling pattern interrupt
nicolasmm
Postby nicolasmm » Sat Aug 28, 2021 3:18 am
Hello everyone,
I'm currently trying to develop an UART application in the esp32-wrover. But when I enable the pattern interrupt, I get the UART_FIFO_OVF event multiple times, repeating at least each 2 seconds. I have tried to increase the `rx_buffer_size` to 20KB when calling `uart_driver_install`, this reduces the issue, but it stills happens each 15 seconds.
I was able to reproduce this issue using the nmea parser example, but in `esp_handle_uart_pattern` instead of calling `gps_decode` it prints the line, as shown below. Likewise, I have tested this in the v4.0-stable and in v4.4-dev, and both have the same issue. I would ignore this issue but sometimes after the UART_FIFO_OVF error, the next line is incomplete. Also, I have seen that this issue is also mentioned here https://www.esp32.com/viewtopic.php?f=1 ... low#p81256.
static void esp_handle_uart_pattern(esp_gps_t *esp_gps)
    int pos = uart_pattern_pop_pos(esp_gps->uart_port);
    if (pos != -1) {
        /* read one line(include '\n') */
        int read_len = uart_read_bytes(esp_gps->uart_port, esp_gps->buffer, pos + 1, 100 / portTICK_PERIOD_MS);
        /* make sure the line is a standard string */
        esp_gps->buffer[read_len] = '\0';
        /* Send new line to handle */
        // if (gps_decode(esp_gps, read_len + 1) != ESP_OK) {
            // ESP_LOGW(GPS_TAG, "GPS decode line failed");
        ESP_LOGW(GPS_TAG, "line %s", esp_gps->buffer);
        ESP_LOGW(GPS_TAG, "Pattern Queue Size too small");
        uart_flush_input(esp_gps->uart_port);
The log looks like this,
I (29) boot: ESP-IDF v4.4-dev-2740-gf65c8249af-dirty 2nd stage bootloader
I (29) boot: compile time 02:13:19
I (30) boot: chip revision: 3
I (34) boot_comm: chip revision: 3, min. bootloader chip revision: 0
I (41) boot.esp32: SPI Speed      : 40MHz
I (46) boot.esp32: SPI Mode       : DIO
I (50) boot.esp32: SPI Flash Size : 2MB
I (55) boot: Enabling RNG early entropy source...
I (60) boot: Partition Table:
I (64) boot: ## Label            Usage          Type ST Offset   Length
I (71) boot:  0 nvs              WiFi data        01 02 00009000 00006000
I (79) boot:  1 phy_init         RF data          01 01 0000f000 00001000
I (86) boot:  2 factory          factory app      00 00 00010000 00100000
I (94) boot: End of partition table
I (98) boot_comm: chip revision: 3, min. application chip revision: 0
I (105) esp_image: segment 0: paddr=00010020 vaddr=3f400020 size=09814h ( 38932) map
I (128) esp_image: segment 1: paddr=0001983c vaddr=3ffb0000 size=023a4h (  9124) load
I (131) esp_image: segment 2: paddr=0001bbe8 vaddr=40080000 size=04430h ( 17456) load
I (141) esp_image: segment 3: paddr=00020020 vaddr=400d0020 size=18628h ( 99880) map
I (178) esp_image: segment 4: paddr=00038650 vaddr=40084430 size=07c10h ( 31760) load
I (191) esp_image: segment 5: paddr=00040268 vaddr=50000000 size=00010h (    16) load
I (198) boot: Loaded app from partition at offset 0x10000
I (198) boot: Disabling RNG early entropy source...
I (211) cpu_start: Pro cpu up.
I (212) cpu_start: Starting app cpu, entry point is 0x400810b8
0x400810b8: call_start_cpu1 at /opt/esp/idf/components/esp_system/port/cpu_start.c:156
I (0) cpu_start: App cpu up.
I (226) cpu_start: Pro cpu start user code
I (226) cpu_start: cpu freq: 160000000
I (226) cpu_start: Application information:
I (230) cpu_start: Project name:     nmea_parser
I (236) cpu_start: App version:      v4.4-dev-2740-gf65c8249af-dirty
I (243) cpu_start: Compile time:     Aug 28 2021 02:21:48
I (249) cpu_start: ELF file SHA256:  78277a9c8fc75fa5...
I (255) cpu_start: ESP-IDF:          v4.4-dev-2740-gf65c8249af-dirty
I (262) heap_init: Initializing. RAM available for dynamic allocation:
I (269) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (275) heap_init: At 3FFB2C88 len 0002D378 (180 KiB): DRAM
I (281) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
I (288) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (294) heap_init: At 4008C040 len 00013FC0 (79 KiB): IRAM
I (301) spi_flash: detected chip: gd
I (305) spi_flash: flash io: dio
W (308) spi_flash: Detected size(16384k) larger than the size in the binary image header(2048k). Using the size in the binary image header.
I (323) cpu_start: Starting scheduler on PRO CPU.
I (333) uart: queue free spaces: 16
I (343) nmea_parser: NMEA Parser init OK
W (353) nmea_parser: line FF FF 7D 80 7D FF FF FF
W (403) nmea_parser: line
80 7D FF FF FF FF FF FF
W (503) nmea_parser: line
FF 7D 7D FF FF FF FF FF
W (553) nmea_parser: line
FF FF FF FF FF FF 80 7D
W (653) nmea_parser: line
W (703) nmea_parser: line
W (803) nmea_parser: line
W (853) nmea_parser: line
W (953) nmea_parser: line
W (1003) nmea_parser: line
W (1103) nmea_parser: line
FF 7D FF FF FF FF FF FF
W (1153) nmea_parser: line
7D FF FF 7D FF FF 7D FF
W (1253) nmea_parser: line
W (1303) nmea_parser: line
W (1353) nmea_parser: line
W (1403) nmea_parser: line
W (1453) nmea_parser: line
W (1503) nmea_parser: line
W (1553) nmea_parser: line
W (1603) nmea_parser: line
W (1653) nmea_parser: line
W (1703) nmea_parser: line
W (1753) nmea_parser: line
W (1803) nmea_parser: line
W (1853) nmea_parser: line
W (1903) nmea_parser: line
W (1953) nmea_parser: line
W (2003) nmea_parser: line
W (2053) nmea_parser: HW FIFO Overflow
W (2103) nmea_parser: line  7D FF FF FF
W (2153) nmea_parser: line
W (2203) nmea_parser: line
W (2253) nmea_parser: line
W (2303) nmea_parser: line
W (2353) nmea_parser: line
W (2403) nmea_parser: line
W (2453) nmea_parser: line
W (2503) nmea_parser: line
W (2553) nmea_parser: line
W (2603) nmea_parser: line
W (2653) nmea_parser: line
W (2703) nmea_parser: line
W (2753) nmea_parser: line
W (2803) nmea_parser: line
W (2853) nmea_parser: line
W (2903) nmea_parser: line
W (2953) nmea_parser: line
W (3003) nmea_parser: line
W (3053) nmea_parser: line
W (3103) nmea_parser: line
W (3153) nmea_parser: line
W (3203) nmea_parser: line
W (3253) nmea_parser: line
W (3303) nmea_parser: line
W (3353) nmea_parser: line
W (3403) nmea_parser: line
W (3453) nmea_parser: line
W (3503) nmea_parser: line
W (3553) nmea_parser: line
W (3603) nmea_parser: HW FIFO Overflow
W (3653) nmea_parser: line FF 7D 7D FF FF FF FF FF
W (3703) nmea_parser: line
W (3753) nmea_parser: line
W (3803) nmea_parser: line
W (3853) nmea_parser: line
W (3903) nmea_parser: line
W (3953) nmea_parser: line
W (4003) nmea_parser: line
W (4053) nmea_parser: line
W (4103) nmea_parser: line
W (4153) nmea_parser: line
W (4203) nmea_parser: line
W (4253) nmea_parser: line
7D 78 80 7D FF FF FF FF
W (4303) nmea_parser: line
7D FF FF 40 25 4B FF FF
W (4353) nmea_parser: line
5E 5A 01 00 5E 5A 01 00
W (4403) nmea_parser: line
FF FF FF FF E0 01 FF FF
W (4453) nmea_parser: line
03 FF 00 00 00 00 00 00
W (4503) nmea_parser: line
W (4553) nmea_parser: line
W (4603) nmea_parser: line
W (4653) nmea_parser: line
W (4703) nmea_parser: line
W (4753) nmea_parser: line
W (4803) nmea_parser: line
W (4853) nmea_parser: line
W (4903) nmea_parser: line
W (4953) nmea_parser: line
W (5003) nmea_parser: line
W (5053) nmea_parser: line
W (5103) nmea_parser: line
W (5153) nmea_parser: HW FIFO Overflow
W (5203) nmea_parser: line FF 7D 7D FF FF FF FF FF
W (5253) nmea_parser: line
W (5303) nmea_parser: line
W (5353) nmea_parser: line
W (5403) nmea_parser: line
W (5453) nmea_parser: line
W (5503) nmea_parser: line
W (5553) nmea_parser: line
W (5603) nmea_parser: line
W (5653) nmea_parser: line
W (5703) nmea_parser: line
W (5753) nmea_parser: line
W (5803) nmea_parser: line
Users browsing this forum: Bing [Bot] and 61 guests
