Wrap log_x in a function
sorokolokarim
Postby sorokolokarim » Fri Aug 13, 2021 12:02 am
Hi masters. I am a beginner in programming and I ask for your help to help me solve a problem that has been tiring me for several days. I would like to provide the arguments of the log_x through a function. But I can't do it.
Example:
void foo(const char* test, ...)
log_x(test, ...);
int x = 5;
foo("help: %d", x); // expected: [x][fileName][line]foo() : help: 5
Thanks you for your help.
ESP_Sprite
Re: Wrap log_x in a function
Postby ESP_Sprite » Fri Aug 13, 2021 2:59 am
This might give you some ideas on how to do this. It depends on the existence of some vlog_x function, not sure if you have that.
sorokolokarim
Postby sorokolokarim » Fri Aug 13, 2021 9:12 pm
The answer is certainly on a higher level than mine. But through it I will try to find my solution. Otherwise I will come back. Thank you😊
Users browsing this forum: No registered users and 115 guests
