Hello
I have a problem using the esp32 module
I am using esp32 cam module and I am trying to connect to wifi
I am trying to use the wpa2 enterprise method rather than the general wifi connection method.
So I downloaded an example from the espressif git hub and used it.
I tried to connect to the company internal network by modifying the code in the example, but I couldn't connect.
I can't find the reason.
help please
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:1216
ho 0 tail 12 room 4
load:0x40078000,len:10944
load:0x40080400,len:6388
entry 0x400806b4
Connecting to network: USEED_OFFICE
.....E (4615) wpa: Response build fail, return.
/*|WORKING EXAMPLE FOR HTTPS CONNECTION |*/
/*|Author: Bc. Martin Chlebovec |*/
/*|Technical University of Košice |*/
/*|TESTED BOARDS: Devkit v1 DOIT, Devkitc v4 |*/
/*|CORE: 0.9x, 1.0.0, 1.0.1 tested, working (newer not tested)|*/
/*|Supported methods: PEAP + MsCHAPv2, EAP-TTLS + MsCHAPv2 |*/
#include <WiFi.h>
#include <WiFiClientSecure.h>
#include "esp_wpa2.h"
#include <Wire.h>
#define EAP_ANONYMOUS_IDENTITY "anonymous@example.com" //anonymous identity
#define EAP_IDENTITY "useed1" //user identity
#define EAP_PASSWORD "12345" //eduroam user password
const char* ssid = "USEED_OFFICE"; // eduroam SSID
const char* host = "arduino.php5.sk"; //external server domain for HTTPS connection
int counter = 0;
const char* test_root_ca = \
"-----BEGIN CERTIFICATE-----\n" \
"MIIEsTCCA5mgAwIBAgIQCKWiRs1LXIyD1wK0u6tTSTANBgkqhkiG9w0BAQsFADBh\n" \
"MQswCQYDVQQGEwJVUzEVMBMGA1UEChMMRGlnaUNlcnQgSW5jMRkwFwYDVQQLExB3\n" \
"d3cuZGlnaWNlcnQuY29tMSAwHgYDVQQDExdEaWdpQ2VydCBHbG9iYWwgUm9vdCBD\n" \
"QTAeFw0xNzExMDYxMjIzMzNaFw0yNzExMDYxMjIzMzNaMF4xCzAJBgNVBAYTAlVT\n" \
"MRUwEwYDVQQKEwxEaWdpQ2VydCBJbmMxGTAXBgNVBAsTEHd3dy5kaWdpY2VydC5j\n" \
"b20xHTAbBgNVBAMTFFJhcGlkU1NMIFJTQSBDQSAyMDE4MIIBIjANBgkqhkiG9w0B\n" \
"AQEFAAOCAQ8AMIIBCgKCAQEA5S2oihEo9nnpezoziDtx4WWLLCll/e0t1EYemE5n\n" \
"+MgP5viaHLy+VpHP+ndX5D18INIuuAV8wFq26KF5U0WNIZiQp6mLtIWjUeWDPA28\n" \
"OeyhTlj9TLk2beytbtFU6ypbpWUltmvY5V8ngspC7nFRNCjpfnDED2kRyJzO8yoK\n" \
"MFz4J4JE8N7NA1uJwUEFMUvHLs0scLoPZkKcewIRm1RV2AxmFQxJkdf7YN9Pckki\n" \
"f2Xgm3b48BZn0zf0qXsSeGu84ua9gwzjzI7tbTBjayTpT+/XpWuBVv6fvarI6bik\n" \
"KB859OSGQuw73XXgeuFwEPHTIRoUtkzu3/EQ+LtwznkkdQIDAQABo4IBZjCCAWIw\n" \
"HQYDVR0OBBYEFFPKF1n8a8ADIS8aruSqqByCVtp1MB8GA1UdIwQYMBaAFAPeUDVW\n" \
"0Uy7ZvCj4hsbw5eyPdFVMA4GA1UdDwEB/wQEAwIBhjAdBgNVHSUEFjAUBggrBgEF\n" \
"BQcDAQYIKwYBBQUHAwIwEgYDVR0TAQH/BAgwBgEB/wIBADA0BggrBgEFBQcBAQQo\n" \
"MCYwJAYIKwYBBQUHMAGGGGh0dHA6Ly9vY3NwLmRpZ2ljZXJ0LmNvbTBCBgNVHR8E\n" \
"OzA5MDegNaAzhjFodHRwOi8vY3JsMy5kaWdpY2VydC5jb20vRGlnaUNlcnRHbG9i\n" \
"YWxSb290Q0EuY3JsMGMGA1UdIARcMFowNwYJYIZIAYb9bAECMCowKAYIKwYBBQUH\n" \
"AgEWHGh0dHBzOi8vd3d3LmRpZ2ljZXJ0LmNvbS9DUFMwCwYJYIZIAYb9bAEBMAgG\n" \
"BmeBDAECATAIBgZngQwBAgIwDQYJKoZIhvcNAQELBQADggEBAH4jx/LKNW5ZklFc\n" \
"YWs8Ejbm0nyzKeZC2KOVYR7P8gevKyslWm4Xo4BSzKr235FsJ4aFt6yAiv1eY0tZ\n" \
"/ZN18bOGSGStoEc/JE4ocIzr8P5Mg11kRYHbmgYnr1Rxeki5mSeb39DGxTpJD4kG\n" \
"hs5lXNoo4conUiiJwKaqH7vh2baryd8pMISag83JUqyVGc2tWPpO0329/CWq2kry\n" \
"qv66OSMjwulUz0dXf4OHQasR7CNfIr+4KScc6ABlQ5RDF86PGeE6kdwSQkFiB/cQ\n" \
"ysNyq0jEDQTkfa2pjmuWtMCNbBnhFXBYejfubIhaUbEv2FOQB3dCav+FPg5eEveX\n" \
"TVyMnGo=\n" \
"-----END CERTIFICATE-----\n";
// You can use x.509 client certificates if you want
//const char* test_client_key = ""; //to verify the client
//const char* test_client_cert = ""; //to verify the client
WiFiClientSecure client;
delay(10);
Serial.println();
Serial.print("Connecting to network: ");
Serial.println(ssid);
WiFi.disconnect(true); //disconnect form wifi to set new wifi connection
WiFi.mode(WIFI_STA); //init wifi mode
//esp_wifi_sta_wpa2_ent_set_identity((uint8_t *)EAP_ANONYMOUS_IDENTITY, strlen(EAP_ANONYMOUS_IDENTITY)); //provide identity
esp_wifi_sta_wpa2_ent_set_username((uint8_t *)EAP_IDENTITY, strlen(EAP_IDENTITY)); //provide username
esp_wifi_sta_wpa2_ent_set_password((uint8_t *)EAP_PASSWORD, strlen(EAP_PASSWORD)); //provide password
esp_wpa2_config_t config = WPA2_CONFIG_INIT_DEFAULT(); //set config settings to default
esp_wifi_sta_wpa2_ent_enable(&config); //set config settings to enable function
WiFi.begin(ssid); //connect to wifi
delay(500);
Serial.print(".");
counter++;
if (counter >= 60) { //after 30 seconds timeout - reset board (on unsucessful connection)
ESP.restart();
client.setCACert(test_root_ca);
//client.setCertificate(test_client_cert); // for client verification - certificate
//client.setPrivateKey(test_client_key); // for client verification - private key
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address set: ");
Serial.println(WiFi.localIP()); //print LAN IP
if (WiFi.status() == WL_CONNECTED) { //if we are connected to eduroam network
counter = 0; //reset counter
Serial.println("Wifi is still connected with IP: ");
Serial.println(WiFi.localIP()); //inform user about his IP address
} else if (WiFi.status() != WL_CONNECTED) { //if we lost connection, retry
WiFi.begin(ssid);
while (WiFi.status() != WL_CONNECTED) { //during lost connection, print dots
delay(500);
Serial.print(".");
counter++;
if (counter >= 60) { //30 seconds timeout - reset board
ESP.restart();
Serial.print("Connecting to website: ");
Serial.println(host);
if (client.connect(host, 443)) {
String url = "/rele/rele1.txt";
client.print(String("GET ") + url + " HTTP/1.1\r\n" + "Host: " + host + "\r\n" + "User-Agent: ESP32\r\n" + "Connection: close\r\n\r\n");
while (client.connected()) {
String header = client.readStringUntil('\n');
Serial.println(header);
if (header == "\r") {
String line = client.readStringUntil('\n');
Serial.println(line);
Serial.println("Connection unsucessful");
delay(5000);
not connect to wifi wap2 enterprise
Jump to
- English Forum
- Explore
- News
- General Discussion
- FAQ
- Documentation
- Documentation
- Sample Code
- Discussion Forum
- Hardware
- ESP-IDF
- ESP-BOX
- ESP-ADF
- ESP-MDF
- ESP-WHO
- ESP-SkaiNet
- ESP32 Arduino
- IDEs for ESP-IDF
- ESP-AT
- ESP IoT Solution
- ESP RainMaker
- Rust
- ESP8266
- Report Bugs
- Showcase
- Chinese Forum 中文社区
- 活动区
- 乐鑫活动专区
- 讨论区
- 全国大学生物联网设计竞赛乐鑫答疑专区
- ESP-IDF 中文讨论版
- 《ESP32-C3 物联网工程开发实战》书籍讨论版
- 中文文档讨论版
- ESP-AT 中文讨论版
- ESP-BOX 中文讨论版
- ESP IoT Solution 中文讨论版
- ESP-ADF 中文讨论版
- ESP Mesh 中文讨论版
- ESP Cloud 中文讨论版
- ESP-WHO 中文讨论版
- ESP-SkaiNet 中文讨论版
- ESP 生产支持讨论版
- 硬件问题讨论
- 项目展示
Users browsing this forum: No registered users and 124 guests
- All times are UTC
- Top
- Delete cookies
About Us
