In arduino IDE, when config the GPIO15 to MCPWM capture mode, the PWM signal pulldown to very low level .
#define GPIO_CAP0_IN 15 //Set GPIO 15 as CAP0
If comment this line: mcpwm_gpio_init(MCPWM_UNIT_0, MCPWM_CAP_0, GPIO_CAP0_IN);
the PWM signal is normal.
this is the source code :
/* MCPWM basic config example
* This example will show you how to use each submodule of MCPWM unit.
* The example can't be used without modifying the code first.
* Edit the macros at the top of mcpwm_example_basic_config.c to enable/disable the submodules which are used in the example.
#include <stdio.h>
#include "freertos/task.h"
#include "freertos/queue.h"
#include "soc/rtc.h"
#include "soc/mcpwm_periph.h"
#include <Arduino.h>
#include <string.h>
#include "esp_attr.h"
#include "soc/mcpwm_struct.h"
#include "driver/mcpwm.h"
#include "driver/timer.h"
#include "math.h"
#define GPIO_OUTPUT_IO_21 21
#define GPIO_OUTPUT_IO_22 22
#define GPIO_OUTPUT_IO_23 23
#define GPIO_OUTPUT_PIN_SEL ((1ULL<<GPIO_OUTPUT_IO_21) | (1ULL<<GPIO_OUTPUT_IO_22) | (1ULL<<GPIO_OUTPUT_IO_23))
#define MCPWM_EN_CARRIER 0 //Make this 1 to test carrier submodule of mcpwm, set high frequency carrier parameters
#define MCPWM_EN_DEADTIME 0 //Make this 1 to test deadtime submodule of mcpwm, set deadtime value and deadtime mode
#define MCPWM_EN_FAULT 0 //Make this 1 to test fault submodule of mcpwm, set action on MCPWM signal on fault occurence like overcurrent, overvoltage, etc
#define MCPWM_EN_SYNC 0 //Make this 1 to test sync submodule of mcpwm, sync timer signals
#define MCPWM_EN_CAPTURE 1 //Make this 1 to test capture submodule of mcpwm, measure time between rising/falling edge of captured signal
#define MCPWM_GPIO_INIT 1 //select which function to use to initialize gpio signals
#define CAP_SIG_NUM 3 //Three capture signals
//#define CAP_SIG_NUM 1 //Three capture signals
#define CAP0_INT_EN BIT(27) //Capture 0 interrupt bit
#define CAP1_INT_EN BIT(28) //Capture 1 interrupt bit
#define CAP2_INT_EN BIT(29) //Capture 2 interrupt bit
//#define GPIO_PWM0A_OUT 19 //Set GPIO 19 as PWM0A
//#define GPIO_PWM0B_OUT 18 //Set GPIO 18 as PWM0B
//#define GPIO_PWM1A_OUT 17 //Set GPIO 17 as PWM1A
//#define GPIO_PWM1B_OUT 16 //Set GPIO 16 as PWM1B
//#define GPIO_PWM2A_OUT 15 //Set GPIO 15 as PWM2A
//#define GPIO_PWM2B_OUT 14 //Set GPIO 14 as PWM2B
//#define GPIO_CAP0_IN (gpio_num_t)15 //Set GPIO 15 as CAP0
//#define GPIO_CAP1_IN 25 //Set GPIO 25 as CAP1
//#define GPIO_CAP2_IN 26 //Set GPIO 26 as CAP2
//#define GPIO_SYNC0_IN 2 //Set GPIO 02 as SYNC0
//#define GPIO_SYNC1_IN 4 //Set GPIO 04 as SYNC1
//#define GPIO_SYNC2_IN 5 //Set GPIO 05 as SYNC2
//#define GPIO_FAULT0_IN 32 //Set GPIO 32 as FAULT0
//#define GPIO_FAULT1_IN 34 //Set GPIO 34 as FAULT1
//#define GPIO_FAULT2_IN 34 //Set GPIO 34 as FAULT2
typedef struct {
uint32_t capture_signal;
mcpwm_capture_signal_t sel_cap_signal;
} capture;
uint32_t *current_cap_value = NULL;
uint32_t *previous_cap_value = NULL;
xQueueHandle cap_queue;
#if MCPWM_EN_CAPTURE
static mcpwm_dev_t *MCPWM[2] = {&MCPWM0, &MCPWM1};
#endif
uint8_t measure_state = 0;
static void mcpwm_example_gpio_initialize(void)
printf("initializing mcpwm gpio...\n");
#if MCPWM_GPIO_INIT
mcpwm_gpio_init(MCPWM_UNIT_0, MCPWM0A, GPIO_PWM0A_OUT);
mcpwm_gpio_init(MCPWM_UNIT_0, MCPWM0B, GPIO_PWM0B_OUT);
mcpwm_gpio_init(MCPWM_UNIT_0, MCPWM1A, GPIO_PWM1A_OUT);
mcpwm_gpio_init(MCPWM_UNIT_0, MCPWM1B, GPIO_PWM1B_OUT);
mcpwm_gpio_init(MCPWM_UNIT_0, MCPWM2A, GPIO_PWM2A_OUT);
mcpwm_gpio_init(MCPWM_UNIT_0, MCPWM2B, GPIO_PWM2B_OUT);
mcpwm_gpio_init(MCPWM_UNIT_0, MCPWM_CAP_1, GPIO_CAP1_IN);
mcpwm_gpio_init(MCPWM_UNIT_0, MCPWM_CAP_2, GPIO_CAP2_IN);
mcpwm_gpio_init(MCPWM_UNIT_0, MCPWM_SYNC_0, GPIO_SYNC0_IN);
mcpwm_gpio_init(MCPWM_UNIT_0, MCPWM_SYNC_1, GPIO_SYNC1_IN);
mcpwm_gpio_init(MCPWM_UNIT_0, MCPWM_SYNC_2, GPIO_SYNC2_IN);
mcpwm_gpio_init(MCPWM_UNIT_0, MCPWM_FAULT_0, GPIO_FAULT0_IN);
mcpwm_gpio_init(MCPWM_UNIT_0, MCPWM_FAULT_1, GPIO_FAULT1_IN);
mcpwm_gpio_init(MCPWM_UNIT_0, MCPWM_FAULT_2, GPIO_FAULT2_IN);
#else
mcpwm_pin_config_t pin_config = {
.mcpwm0a_out_num = GPIO_PWM0A_OUT,
.mcpwm0b_out_num = GPIO_PWM0B_OUT,
.mcpwm1a_out_num = GPIO_PWM1A_OUT,
.mcpwm1b_out_num = GPIO_PWM1B_OUT,
.mcpwm2a_out_num = GPIO_PWM2A_OUT,
.mcpwm2b_out_num = GPIO_PWM2B_OUT,
.mcpwm_sync0_in_num = GPIO_SYNC0_IN,
.mcpwm_sync1_in_num = GPIO_SYNC1_IN,
.mcpwm_sync2_in_num = GPIO_SYNC2_IN,
.mcpwm_fault0_in_num = GPIO_FAULT0_IN,
.mcpwm_fault1_in_num = GPIO_FAULT1_IN,
.mcpwm_fault2_in_num = GPIO_FAULT2_IN,
.mcpwm_cap0_in_num = GPIO_CAP0_IN,
.mcpwm_cap1_in_num = GPIO_CAP1_IN,
.mcpwm_cap2_in_num = GPIO_CAP2_IN
mcpwm_set_pin(MCPWM_UNIT_0, &pin_config);
#endif
//gpio_pulldown_en(GPIO_CAP0_IN); //Enable pull down on CAP0 signal
//gpio_pullup_en(GPIO_CAP0_IN); //Enable pul up on CAP0 signal
gpio_pulldown_en(GPIO_CAP1_IN); //Enable pull down on CAP1 signal
gpio_pulldown_en(GPIO_CAP2_IN); //Enable pull down on CAP2 signal
gpio_pulldown_en(GPIO_SYNC0_IN); //Enable pull down on SYNC0 signal
gpio_pulldown_en(GPIO_SYNC1_IN); //Enable pull down on SYNC1 signal
gpio_pulldown_en(GPIO_SYNC2_IN); //Enable pull down on SYNC2 signal
gpio_pulldown_en(GPIO_FAULT0_IN); //Enable pull down on FAULT0 signal
gpio_pulldown_en(GPIO_FAULT1_IN); //Enable pull down on FAULT1 signal
gpio_pulldown_en(GPIO_FAULT2_IN); //Enable pull down on FAULT2 signal
* @brief Set gpio 12 as our test signal that generates high-low waveform continuously, connect this gpio to capture pin.
static void gpio_test_signal(void *arg)
printf("intializing test signal...\n");
gpio_config_t gp;
gp.intr_type = GPIO_INTR_DISABLE;
gp.mode = GPIO_MODE_OUTPUT;
gp.pin_bit_mask = GPIO_SEL_12;
gpio_config(&gp);
while (1) {
//here the period of test signal is 20ms
gpio_set_level(GPIO_NUM_12, 1); //Set high
vTaskDelay(10); //delay of 10ms
gpio_set_level(GPIO_NUM_12, 0); //Set low
* @brief When interrupt occurs, we receive the counter value and display the time between two rising edge
static void disp_captured_signal(void *arg)
capture evt;
while (1) {
xQueueReceive(cap_queue, &evt, portMAX_DELAY);
if (evt.sel_cap_signal == MCPWM_SELECT_CAP0) {
printf("CAP0 : %d us\n", evt.capture_signal);
if (evt.sel_cap_signal == MCPWM_SELECT_CAP1) {
printf("CAP1 : %d us\n", evt.capture_signal);
if (evt.sel_cap_signal == MCPWM_SELECT_CAP2) {
printf("CAP2 : %d us\n", evt.capture_signal);
* @brief this is ISR handler function, here we check for interrupt that triggers rising edge on CAP0 signal and according take action
static void IRAM_ATTR isr_handler(void *arg)
uint32_t mcpwm_intr_status;
capture evt;
mcpwm_intr_status = MCPWM[MCPWM_UNIT_0]->int_st.val; //Read interrupt status
//calculate the interval in the ISR,
//so that the interval will be always correct even when cap_queue is not handled in time and overflow.
if (mcpwm_intr_status & CAP0_INT_EN) { //Check for interrupt on rising edge on CAP0 signal
current_cap_value[0] = mcpwm_capture_signal_get_value(MCPWM_UNIT_0, MCPWM_SELECT_CAP0); //get capture signal counter value
evt.capture_signal = (current_cap_value[0] - previous_cap_value[0]) / (rtc_clk_apb_freq_get() / 1000000);
previous_cap_value[0] = current_cap_value[0];
evt.sel_cap_signal = MCPWM_SELECT_CAP0;
if(measure_state == 0){
mcpwm_capture_enable(MCPWM_UNIT_0, MCPWM_SELECT_CAP0, MCPWM_NEG_EDGE, 0); //capture signal on rising edge, prescale = 0 i.e. 800,000,000 counts is equal to one second
measure_state = 1;
xQueueSendFromISR(cap_queue, &evt, NULL);
else if(measure_state == 1){
mcpwm_capture_enable(MCPWM_UNIT_0, MCPWM_SELECT_CAP0, MCPWM_POS_EDGE, 0); //capture signal on rising edge, prescale = 0 i.e. 800,000,000 counts is equal to one second
measure_state = 0;
//xQueueSendFromISR(cap_queue, &evt, NULL);
if (mcpwm_intr_status & CAP1_INT_EN) { //Check for interrupt on rising edge on CAP0 signal
current_cap_value[1] = mcpwm_capture_signal_get_value(MCPWM_UNIT_0, MCPWM_SELECT_CAP1); //get capture signal counter value
evt.capture_signal = (current_cap_value[1] - previous_cap_value[1]) / (rtc_clk_apb_freq_get() / 1000000);
previous_cap_value[1] = current_cap_value[1];
evt.sel_cap_signal = MCPWM_SELECT_CAP1;
if (mcpwm_intr_status & CAP2_INT_EN) { //Check for interrupt on rising edge on CAP0 signal
current_cap_value[2] = mcpwm_capture_signal_get_value(MCPWM_UNIT_0, MCPWM_SELECT_CAP2); //get capture signal counter value
evt.capture_signal = (current_cap_value[2] - previous_cap_value[2]) / (rtc_clk_apb_freq_get() / 1000000);
previous_cap_value[2] = current_cap_value[2];
evt.sel_cap_signal = MCPWM_SELECT_CAP2;
MCPWM[MCPWM_UNIT_0]->int_clr.val = mcpwm_intr_status;
#endif
* @brief Configure whole MCPWM module
static void mcpwm_example_config(void *arg)
//1. mcpwm gpio initialization
mcpwm_example_gpio_initialize();
//2. initialize mcpwm configuration
printf("Configuring Initial Parameters of mcpwm...\n");
mcpwm_config_t pwm_config;
pwm_config.frequency = 1000; //frequency = 1000Hz
pwm_config.cmpr_a = 60.0; //duty cycle of PWMxA = 60.0%
pwm_config.cmpr_b = 50.0; //duty cycle of PWMxb = 50.0%
pwm_config.counter_mode = MCPWM_UP_COUNTER;
pwm_config.duty_mode = MCPWM_DUTY_MODE_0;
mcpwm_init(MCPWM_UNIT_0, MCPWM_TIMER_0, &pwm_config); //Configure PWM0A & PWM0B with above settings
pwm_config.frequency = 500; //frequency = 500Hz
pwm_config.cmpr_a = 45.9; //duty cycle of PWMxA = 45.9%
pwm_config.cmpr_b = 7.0; //duty cycle of PWMxb = 07.0%
mcpwm_init(MCPWM_UNIT_0, MCPWM_TIMER_1, &pwm_config); //Configure PWM1A & PWM1B with above settings
pwm_config.frequency = 400; //frequency = 400Hz
pwm_config.cmpr_a = 23.2; //duty cycle of PWMxA = 23.2%
pwm_config.cmpr_b = 97.0; //duty cycle of PWMxb = 97.0%
pwm_config.counter_mode = MCPWM_UP_DOWN_COUNTER; //frequency is half when up down count mode is set i.e. SYMMETRIC PWM
pwm_config.duty_mode = MCPWM_DUTY_MODE_1;
mcpwm_init(MCPWM_UNIT_0, MCPWM_TIMER_2, &pwm_config); //Configure PWM2A & PWM2B with above settings
#if MCPWM_EN_CARRIER
//3. carrier configuration
//comment if you don't want to use carrier mode
//in carrier mode very high frequency carrier signal is generated at mcpwm high level signal
mcpwm_carrier_config_t chop_config;
chop_config.carrier_period = 6; //carrier period = (6 + 1)*800ns
chop_config.carrier_duty = 3; //carrier duty = (3)*12.5%
chop_config.carrier_os_mode = MCPWM_ONESHOT_MODE_EN; //If one shot mode is enabled then set pulse width, if disabled no need to set pulse width
chop_config.pulse_width_in_os = 3; //first pulse width = (3 + 1)*carrier_period
chop_config.carrier_ivt_mode = MCPWM_CARRIER_OUT_IVT_EN; //output signal inversion enable
mcpwm_carrier_init(MCPWM_UNIT_0, MCPWM_TIMER_2, &chop_config); //Enable carrier on PWM2A and PWM2B with above settings
//use mcpwm_carrier_disable function to disable carrier on mcpwm timer on which it was enabled
#endif
#if MCPWM_EN_DEADTIME
//4. deadtime configuration
//comment if you don't want to use deadtime submodule
//add rising edge delay or falling edge delay. There are 8 different types, each explained in mcpwm_deadtime_type_t in mcpwm.h
mcpwm_deadtime_enable(MCPWM_UNIT_0, MCPWM_TIMER_2, MCPWM_BYPASS_FED, 1000, 1000); //Enable deadtime on PWM2A and PWM2B with red = (1000)*100ns on PWM2A
mcpwm_deadtime_enable(MCPWM_UNIT_0, MCPWM_TIMER_1, MCPWM_BYPASS_RED, 300, 2000); //Enable deadtime on PWM1A and PWM1B with fed = (2000)*100ns on PWM1B
mcpwm_deadtime_enable(MCPWM_UNIT_0, MCPWM_TIMER_0, MCPWM_ACTIVE_RED_FED_FROM_PWMXA, 656, 67); //Enable deadtime on PWM0A and PWM0B with red = (656)*100ns & fed = (67)*100ns on PWM0A and PWM0B generated from PWM0A
//use mcpwm_deadtime_disable function to disable deadtime on mcpwm timer on which it was enabled
#endif
#if MCPWM_EN_FAULT
//5. enable fault condition
//comment if you don't want to use fault submodule, also u can comment the fault gpio signals
//whenever fault occurs you can configure mcpwm signal to either force low, force high or toggle.
//in cycmode, as soon as fault condition is over, the mcpwm signal is resumed, whereas in oneshot mode you need to reset.
mcpwm_fault_init(MCPWM_UNIT_0, MCPWM_HIGH_LEVEL_TGR, MCPWM_SELECT_F0); //Enable FAULT, when high level occurs on FAULT0 signal
mcpwm_fault_init(MCPWM_UNIT_0, MCPWM_HIGH_LEVEL_TGR, MCPWM_SELECT_F1); //Enable FAULT, when high level occurs on FAULT1 signal
mcpwm_fault_init(MCPWM_UNIT_0, MCPWM_HIGH_LEVEL_TGR, MCPWM_SELECT_F2); //Enable FAULT, when high level occurs on FAULT2 signal
mcpwm_fault_set_oneshot_mode(MCPWM_UNIT_0, MCPWM_TIMER_1, MCPWM_SELECT_F0, MCPWM_FORCE_MCPWMXA_HIGH, MCPWM_FORCE_MCPWMXB_LOW); //Action taken on PWM1A and PWM1B, when FAULT0 occurs
mcpwm_fault_set_oneshot_mode(MCPWM_UNIT_0, MCPWM_TIMER_1, MCPWM_SELECT_F1, MCPWM_FORCE_MCPWMXA_LOW, MCPWM_FORCE_MCPWMXB_HIGH); //Action taken on PWM1A and PWM1B, when FAULT1 occurs
mcpwm_fault_set_oneshot_mode(MCPWM_UNIT_0, MCPWM_TIMER_0, MCPWM_SELECT_F2, MCPWM_FORCE_MCPWMXA_HIGH, MCPWM_FORCE_MCPWMXB_LOW); //Action taken on PWM0A and PWM0B, when FAULT2 occurs
mcpwm_fault_set_oneshot_mode(MCPWM_UNIT_0, MCPWM_TIMER_0, MCPWM_SELECT_F1, MCPWM_FORCE_MCPWMXA_LOW, MCPWM_FORCE_MCPWMXB_HIGH); //Action taken on PWM0A and PWM0B, when FAULT1 occurs
#endif
#if MCPWM_EN_SYNC
//6. Syncronization configuration
//comment if you don't want to use sync submodule, also u can comment the sync gpio signals
//here synchronization occurs on PWM1A and PWM1B
mcpwm_sync_enable(MCPWM_UNIT_0, MCPWM_TIMER_1, MCPWM_SELECT_SYNC0, 200); //Load counter value with 20% of period counter of mcpwm timer 1 when sync 0 occurs
#endif
//7. Capture configuration
//comment if you don't want to use capture submodule, also u can comment the capture gpio signals
//configure CAP0, CAP1 and CAP2 signal to start capture counter on rising edge
//we generate a gpio_test_signal of 20ms on GPIO 12 and connect it to one of the capture signal, the disp_captured_function displays the time between rising edge
//In general practice you can connect Capture to external signal, measure time between rising edge or falling edge and take action accordingly
mcpwm_capture_enable(MCPWM_UNIT_0, MCPWM_SELECT_CAP2, MCPWM_POS_EDGE, 0); //capture signal on rising edge, prescale = 0 i.e. 800,000,000 counts is equal to one second
mcpwm_capture_enable(MCPWM_UNIT_0, MCPWM_SELECT_CAP1, MCPWM_POS_EDGE, 0); //capture signal on rising edge, prescale = 0 i.e. 800,000,000 counts is equal to one second
//enable interrupt, so each this a rising edge occurs interrupt is triggered
MCPWM[MCPWM_UNIT_0]->int_ena.val = CAP0_INT_EN | CAP1_INT_EN | CAP2_INT_EN; //Enable interrupt on CAP0, CAP1 and CAP2 signal
mcpwm_isr_register(MCPWM_UNIT_0, isr_handler, NULL, ESP_INTR_FLAG_IRAM, NULL); //Set ISR Handler
#endif
vTaskDelete(NULL);
void setup()
gpio_config_t io_conf;
//disable interrupt
io_conf.intr_type = GPIO_INTR_DISABLE;
//set as output mode
io_conf.mode = GPIO_MODE_OUTPUT;
//bit mask of the pins that you want to set,e.g.GPIO18/19
io_conf.pin_bit_mask = GPIO_OUTPUT_PIN_SEL;
//disable pull-down mode
io_conf.pull_down_en = 0;
//disable pull-up mode
io_conf.pull_up_en = 0;
//configure GPIO with the given settings
gpio_config(&io_conf);
gpio_set_level(GPIO_OUTPUT_IO_21, 0);
gpio_set_level(GPIO_OUTPUT_IO_22, 0);
gpio_set_level(GPIO_OUTPUT_IO_23, 0);
pinMode(21, OUTPUT);
pinMode(22, OUTPUT);
pinMode(23, OUTPUT);
digitalWrite(23,LOW); // SEL_I2C_A
digitalWrite(22,LOW); // SEL_I2C_B
digitalWrite(21,LOW); // SEL_I2C_C
pinMode(15, INPUT_PULLUP); // PWM
printf("Testing MCPWM...\n");
cap_queue = xQueueCreate(1, sizeof(capture)); //comment if you don't want to use capture module
current_cap_value = (uint32_t *)malloc(CAP_SIG_NUM*sizeof(uint32_t)); //comment if you don't want to use capture module
previous_cap_value = (uint32_t *)malloc(CAP_SIG_NUM*sizeof(uint32_t)); //comment if you don't want to use capture module
xTaskCreate(disp_captured_signal, "mcpwm_config", 4096, NULL, 5, NULL); //comment if you don't want to use capture module
xTaskCreate(gpio_test_signal, "gpio_test_signal", 4096, NULL, 5, NULL); //comment if you don't want to use capture module
xTaskCreate(mcpwm_example_config, "mcpwm_example_config", 4096, NULL, 5, NULL);
while(1);
But in ESP-IDF, it works OK, the source code:
#include <stdio.h>
#include "string.h"
#include "driver/gpio.h"
#define MCPWM_GPIO_INIT 0 //select which function to use to initialize gpio signals
//#define CAP_SIG_NUM 3 //Three capture signals
//#define GPIO_CAP0_IN 23 //Set GPIO 23 as CAP0
typedef struct {
} capture;
#endif
#if MCPWM_GPIO_INIT
#else
#endif
gpio_config_t gp;
gpio_config(&gp);
while (1) {
capture evt;
while (1) {
static void IRAM_ATTR isr_handler(void)
capture evt;
measure_state = 1;
measure_state = 0;
#endif
#endif
#endif
#if MCPWM_EN_FAULT
#endif
#if MCPWM_EN_SYNC
#endif
#endif
vTaskDelete(NULL);
void app_main(void)
//disable interrupt
When config GPIO15 to MCPWM Capture mode, the PWM signal pulldown to very low level
Users browsing this forum: No registered users and 66 guests
