I was making some initial tests with flash encryption in DEVELOPMENT MODE (no secure boot). When I finished, I just disabled flash encryption in menuconfig and then tried to flash again a new firmware version. Unfortunately this is the oputput I get from by board:
flash read err, 1000
ets_main.c 371
ets Jun 8 2016 00:22:57
ets_main.c 371
I have read several posts but I do not know exactly how to recover my boards and be able to get my plain text image running again with flash encryption disabled. I have also checked the efuses and these are their values:
Security fuses:
FLASH_CRYPT_CNT Flash encryption mode counter = 1 R/W (0x1)
FLASH_CRYPT_CONFIG Flash encryption config (key tweak bits) = 15 R/W (0xf)
CONSOLE_DEBUG_DISABLE Disable ROM BASIC interpreter fallback = 1 R/W (0x1)
ABS_DONE_0 secure boot enabled for bootloader = 0 R/W (0x0)
ABS_DONE_1 secure boot abstract 1 locked = 0 R/W (0x0)
JTAG_DISABLE Disable JTAG = 1 R/W (0x1)
DISABLE_DL_ENCRYPT Disable flash encryption in UART bootloader = 0 R/W (0x0)
DISABLE_DL_DECRYPT Disable flash decryption in UART bootloader = 1 R/W (0x1)
DISABLE_DL_CACHE Disable flash cache in UART bootloader = 1 R/W (0x1)
BLK1 Flash encryption key
What can I do? Thanks!
Flashing plain text image after enabling flash encryption
Re: Flashing plain text image after enabling flash encryption
Either disable encryption (on the chip, not in the project) using espefuse.py or flash using the encrypt option
Thanks WiFive, yes, that is exactly what I was looking for (disable encryption on the chip) but unfortunately "burn_efuse" with value 0 for DISABLE_DL_ENCRYPT and DISABLE_DL_DECRYPT return "New value is not accepted for this efuse (will always burn 0->1)".WiFive wrote: Either disable encryption (on the chip, not in the project) using espefuse.py or flash using the encrypt option
Could you please elaborate a little bit more your explanation?
To disable encryption you change FLASH_CRYPT_CNT
I forgot to mention it but I also tried to set FLASH_CRYPT_CNT to 0 but this is the output, so I cancelled the operation:
espefuse.py -p COM6 burn_efuse FLASH_CRYPT_CNT 0
espefuse.py v2.8
Connecting....
WARNING: New value contains some bits that cannot be cleared (value will be 0x1)
Burning efuse FLASH_CRYPT_CNT (Flash encryption mode counter) 0x1 -> 0x1. This is an irreversible operation.
Type 'BURN' (all capitals) to continue.
espefuse.py v2.8
Connecting....
You have to set it to 3. If you don't supply a value it should automatically increment it.
It worked! thanks
Users browsing this forum: No registered users and 106 guests
