EspProg problem
edwi92
EspProg problem
Postby edwi92 » Thu Jul 01, 2021 1:28 pm
Hi everyone,
I am trying to run esp-prog debugging on my ESP32-solo-1 chip using VSCode. Unfortunately I can't get it running, but if I switch to esp-wroom-32 it works fine.
Can anybody give me some ideas what should I do? Are there any differences between esp32-solo-1 and esp-wroom-32?
VSCode scripts:
launch.json
// ======================== launch.json ========================
	// Use IntelliSense to learn about possible attributes.
	// Hover to view descriptions of existing attributes.
	// For more information, visit: https://go.microsoft.com/fwlink/?linkid=830387
	"version": "0.2.0",
	"configurations": [
		"type": "gdb",
		"request": "launch",
		"name": "Debug ESP32",
		"target": "${workspaceFolder}/build/WiFi_Devices.elf",
		"cwd": "${workspaceFolder}",
		"gdbpath": "%userprofile%/.espressif/tools/xtensa-esp32-elf/esp-2020r3-8.4.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-gdb", // Path of the toolchain
		"autorun": [
		  "target remote :3333", // Connect to OpenOCD
		  "mon reset halt", // Reset the chip and keep the CPUs halted
		  "set remote hardware-watchpoint-limit 2", // Restrict GDB to using two hardware watchpoints supported by ESP32
		  "flushregs", // Force GDB to get new state from the target
		  "thb app_main", // Insert a temporary hardware breakpoint at the main function
		  "c" // Resume the program. It will then stop at breakpoint inserted at app_main
		"preLaunchTask": "OpenOCD"
tasks.json
// ======================== tasks.json ========================
  // See https://go.microsoft.com/fwlink/?LinkId=733558
  // for the documentation about the tasks.json format
  "version": "2.0.0",
  "tasks": [{
      "label": "Configure",
      "type": "shell",
      "command": ". $HOME/esp/esp-idf/export.sh && idf.py menuconfig",
      "windows": { "command": "%userprofile%\\esp\\esp-idf\\export.bat && idf.py menuconfig" }
      "label": "Build",
      "group": "build",
      "type": "shell",
      "command": ". $HOME/esp/esp-idf/export.sh && idf.py build",
      "windows": { "command": "%userprofile%\\esp\\esp-idf\\export.bat && idf.py build" },
      "problemMatcher": {
        "owner": "cpp",
        "fileLocation": ["relative", "${workspaceFolder}/build"],
        "pattern": {
          "regexp": "^(.*):(\\d+):(\\d+):\\s+(warning|error):\\s+(.*)$",
          "file": 1,
          "line": 2,
          "column": 3,
          "severity": 4,
          "message": 5
      "label": "Get size",
      "group": "build",
      "type": "shell",
      "command": ". $HOME/esp/esp-idf/export.sh && idf.py size",
      "windows": { "command": "%userprofile%\\esp\\esp-idf\\export.bat && idf.py size" },
      "problemMatcher": {
        "owner": "cpp",
        "pattern": {
          "file": 1,
          "line": 2,
          "column": 3,
          "severity": 4,
          "message": 5
      "label": "Clean",
      "group": "build",
      "type": "shell",
      "command": ". $HOME/esp/esp-idf/export.sh && idf.py clean",
      "windows": { "command": "%userprofile%\\esp\\esp-idf\\export.bat && idf.py clean" }
      "label": "Clean (full)",
      "group": "build",
      "type": "shell",
      "command": ". $HOME/esp/esp-idf/export.sh && idf.py fullclean",
      "windows": { "command": "%userprofile%\\esp\\esp-idf\\export.bat && idf.py fullclean" }
      "label": "Flash",
      "group": "test",
      "type": "shell",
      "command": ". $HOME/esp/esp-idf/export.sh && idf.py flash",
      "windows": { "command": "%userprofile%\\esp\\esp-idf\\export.bat && idf.py flash" },
      "problemMatcher": {
        "owner": "cpp",
        "pattern": {
          "file": 1,
          "line": 2,
          "column": 3,
          "severity": 4,
          "message": 5
      "label": "Erase flash",
      "group": "build",
      "type": "shell",
      "command": ". $HOME/esp/esp-idf/export.sh && idf.py erase_flash",
      "windows": { "command": "%userprofile%\\esp\\esp-idf\\export.bat && idf.py erase_flash" }
      "label": "Monitor",
      "group": "test",
      "type": "shell",
      "command": ". $HOME/esp/esp-idf/export.sh && idf.py monitor",
      "windows": { "command": "%userprofile%\\esp\\esp-idf\\export.bat && idf.py monitor" },
      "isBackground": true,
      //"dependsOn": ["Flash"]
      "label": "OpenOCD",
      "type": "shell",
      "command": ". $HOME/esp/esp-idf/export.sh && openocd -f interface/ftdi/esp32_devkitj_v1.cfg -f board/esp32-solo-1.cfg",
      "windows": { "command": "%userprofile%\\esp\\esp-idf\\export.bat && openocd -f interface/ftdi/esp32_devkitj_v1.cfg -f board/esp32-solo-1.cfg" },
      "problemMatcher": {
        "pattern": {
          "regexp": "^(Info |Warn ):(.*)$", // Ignore errors
          "severity": 1,
          "message": 2
        "background": {
          "activeOnStart": true,
          "beginsPattern": ".",
          "endsPattern": "Info : Listening on port \\d+ for gdb connections"
ns1668
Re: EspProg problem
Postby ns1668 » Fri Jul 02, 2021 10:05 am
The SOLO only has 1 CPU core, the WROOM has 2 CPU cores.
Does your code actually run on the Solo (ignoring the debugger for now)?
edwi92
Re: EspProg problem
Postby edwi92 » Sat Jul 03, 2021 1:15 pm
Yes, the firmware is the same and it works on SOLO.
Users browsing this forum: Baidu [Spider] and 83 guests
