ESP32 says I haven't wired the AHT20 sensor
george_i
Postby george_i » Fri Jun 11, 2021 9:17 am
I have a ESP32 WROVER B board and I try to connect a sensor to it, but although I think I followed the instructions, something is not right.
This is the pinout of the board.
esp32 pinout.jpg (329.18 KiB) Viewed 2603 times
This is the Adafruit AHT20 sensor:
How I wired:
- AHT20 pin SCL -> ESP32 pin 21
- AHT20 pin SDA -> ESP32 pin 22
- AHT20 pin VIN-> ESP32 pin 5V
- AHT20 pin GND-> ESP32 pin GND
This is the code I tried:
#include <Adafruit_AHTX0.h>
Adafruit_AHTX0 aht;
  Serial.println("Adafruit AHT10/AHT20 demo!");
  if (! aht.begin()) {
    Serial.println("Could not find AHT? Check wiring");
    while (1) delay(10);
  Serial.println("AHT10 or AHT20 found");
  sensors_event_t humidity, temp;
  aht.getEvent(&humidity, &temp);// populate temp and humidity objects with fresh data
  Serial.print("Temperature: "); Serial.print(temp.temperature); Serial.println(" degrees C");
  Serial.print("Humidity: "); Serial.print(humidity.relative_humidity); Serial.println("% rH");
  delay(500);
When I run the code, I always get this message on the Serial Monitor:
Users browsing this forum: No registered users and 45 guests
