esp32c3 revisions
citoyx
esp32c3 revisions
Postby citoyx » Thu May 20, 2021 3:33 pm
Good afternoon,
After two months delay, i just received my esp32c3 devkitC 02v1.1
Sadly after trying to flash blink exemple i got this message:
E (38) boot_comm: This chip is revision 2 but the application is configured for minimum revision 3. Can't run.
I understand there is a workaround with modifying some files, but what is the difference between rev2 and rev3 ? does it have an impact on code ? will there be some structural change between revisions ?
and most important, where can i get latest revision chip devkit ?
***addons***
Just to let you know, and in case someone face the same issue. Just idf.py menuconfig -> component config -> esp32c3 specific -> Minimum supported esp32-c3 revision : choose 2 (or whatever your revision is).
here is the output of blink :
  1. Serial port COM22
  2. Connecting....
  3. Detecting chip type... ESP32-C3
  4. Running idf_monitor in directory d:\work\esp\examples\get-started\blink
  5. Executing "C:\Users\plonky\.espressif\python_env\idf4.4_py3.8_env\Scripts\python.exe D:\work\esp\tools/idf_monitor.py -p COM22 -b 115200 --toolchain-prefix riscv32-esp-elf- --target esp32c3 --decode-panic backtrace d:\work\esp\examples\get-started\blink\build\blink.elf -m 'C:\Users\plonky\.espressif\python_env\idf4.4_py3.8_env\Scripts\python.exe' 'D:\work\esp\tools\idf.py'"...
  6. --- WARNING: GDB cannot open serial ports accessed as COMx
  7. --- Using \\.\COM22 instead...
  8. --- idf_monitor on \\.\COM22 115200 ---
  9. --- Quit: Ctrl+] | Menu: Ctrl+T | Help: Ctrl+T followed by Ctrl+H ---
  10. ESP-ROM:esp32c3-20200918
  11. Build:Sep 18 2020
  12. rst:0x1 (POWERON),boot:0xc (SPI_FAST_FLASH_BOOT)
  13. SPIWP:0xee
  14. mode:DIO, clock div:1
  15. load:0x3fcd6100,len:0x1654
  16. load:0x403ce000,len:0x8c0
  17. load:0x403d0000,len:0x2928
  18. entry 0x403ce000
  19. I (32) boot: ESP-IDF v4.4-dev-1404-gc13afea63 2nd stage bootloader
  20. I (32) boot: compile time 17:40:37
  21. I (32) boot: chip revision: 2
  22. I (35) boot.esp32c3: SPI Speed      : 80MHz
  23. I (40) boot.esp32c3: SPI Mode       : DIO
  24. I (45) boot.esp32c3: SPI Flash Size : 2MB
  25. I (50) boot: Enabling RNG early entropy source...
  26. I (55) boot: Partition Table:
  27. I (59) boot: ## Label            Usage          Type ST Offset   Length
  28. I (66) boot:  0 nvs              WiFi data        01 02 00009000 00006000
  29. I (73) boot:  1 phy_init         RF data          01 01 0000f000 00001000
  30. I (81) boot:  2 factory          factory app      00 00 00010000 00100000
  31. I (88) boot: End of partition table
  32. I (92) esp_image: segment 0: paddr=00010020 vaddr=3c020020 size=07640h ( 30272) map
  33. I (105) esp_image: segment 1: paddr=00017668 vaddr=3fc8ae00 size=0145ch (  5212) load
  34. I (110) esp_image: segment 2: paddr=00018acc vaddr=40380000 size=0754ch ( 30028) load
  35. I (123) esp_image: segment 3: paddr=00020020 vaddr=42000020 size=178b0h ( 96432) map
  36. I (141) esp_image: segment 4: paddr=000378d8 vaddr=4038754c size=03724h ( 14116) load
  37. I (144) esp_image: segment 5: paddr=0003b004 vaddr=50000000 size=00010h (    16) load
  38. I (150) boot: Loaded app from partition at offset 0x10000
  39. I (153) boot: Disabling RNG early entropy source...
  40. I (169) cpu_start: Pro cpu up.
  41. I (177) cpu_start: Pro cpu start user code
  42. I (177) cpu_start: cpu freq: 160000000
  43. I (177) cpu_start: Application information:
  44. I (180) cpu_start: Project name:     blink
  45. I (185) cpu_start: App version:      v4.4-dev-1404-gc13afea63
  46. I (191) cpu_start: Compile time:     May 20 2021 17:40:32
  47. I (197) cpu_start: ELF file SHA256:  78cbbe885cdab963...
  48. I (203) cpu_start: ESP-IDF:          v4.4-dev-1404-gc13afea63
  49. I (210) heap_init: Initializing. RAM available for dynamic allocation:
  50. I (217) heap_init: At 3FC8D0E0 len 00032F20 (203 KiB): DRAM
  51. I (223) heap_init: At 3FCC0000 len 0001F260 (124 KiB): STACK/DRAM
  52. I (230) heap_init: At 50000010 len 00001FF0 (7 KiB): RTCRAM
  53. I (237) spi_flash: detected chip: generic
  54. I (241) spi_flash: flash io: dio
  55. W (245) spi_flash: Detected size(4096k) larger than the size in the binary image header(2048k). Using the size in the binary image header.
  56. I (258) sleep: Configure to isolate all GPIO pins in sleep state
  57. I (265) sleep: Enable automatic switching of GPIO sleep configuration
  58. I (272) cpu_start: Starting scheduler.
  59. I (276) example: Example configured to blink addressable LED!
  60. I (276) example: Turning the LED OFF!
  61. I (1286) example: Turning the LED ON!
  62. I (2286) example: Turning the LED OFF!
  63. I (3286) example: Turning the LED ON!
  64. I (4286) example: Turning the LED OFF!
  65. I (5286) example: Turning the LED ON!
  66. I (6286) example: Turning the LED OFF!
  67. I (7286) example: Turning the LED ON!
  68. I (8286) example: Turning the LED OFF!
  69. I (9286) example: Turning the LED ON!
ESP_Sprite
Re: esp32c3 revisions
Postby ESP_Sprite » Fri May 21, 2021 5:43 am
There's some minor changes in the radio/MAC logic between eco2 and eco3, and USB-to-JTAG-serial doesn't work in ECO2. No structural changes otherwise.
Any mass market devkit you get at this point should have ECO3 on it. ECO2 and earlier was only given out in sample quantities.
chegewara
Postby chegewara » Fri May 21, 2021 7:54 am
I have bought esp32 C3 from mouser. My order was delayed about 5 weeks due to shortages and production, but thats not the point. My order was sent about 6 weeks ago, so not that long time ago and it was not sample. All 5 devkit boards are with eco2, at least esp-idf reports it is revision 2.
citoyx
Postby citoyx » Fri May 21, 2021 8:03 am
Yeah my order from mouser was made 23th of march.
4xESP32-C3-DevKitC-02 and 4xESP32-C3-DevKitM-1
So far i received devkit 02 last Wednesday an all are sample (rainmaker version) rev2.
devkitm-1 is delayed to mid june again with resupply status.
WHERE can i buy mass market version ?
chegewara
Postby chegewara » Fri May 21, 2021 8:06 am
Dont take this wrong, i do not complain, i knew exactly what i am buying and i am happy with that. Even without USB/JTAG i can work with new chip, test BLE5 or other API compatibility, which is good, but i am just a programmer.
DoctorDan
Postby DoctorDan » Thu Jul 08, 2021 4:32 am
Well, I do want to complain. I am new to these products. I also ordered esp32-c3 from mouser. The units were shipped with notes on the esp32-c3 idf. It describes the commands that should be run to test the installation (blink)
I followed these instructions step-by-step and got
E (36) boot_comm: This chip is revision 2 but the application is configured for minimum revision 3. Can't run.
This is pretty unacceptable. As a newcomer I have no idea if this error can be corrected or how to do that but it certainly does not appear that the merchandise that I received is what appears on my order. If the C3 modules are/were not ready the shipping should have been postponed until the correct items became available.
I don't know what to do next but I am one very unhappy camper.
Thank you,
de
chegewara
Postby chegewara » Thu Jul 08, 2021 10:39 am
@DoctorDan, dont worry, you can still use it and have a lot of fun. All you have to do is to change 1 option in menuconfig.
idf.py menuconfig
Then search for revision keyword and change it from version 3 to version 2.
DoctorDan
Postby DoctorDan » Thu Jul 08, 2021 7:17 pm
Thanks, I'll take a look
PoClab
Postby PoClab » Fri Dec 24, 2021 12:36 pm
Seems like I have 1-st revision of ESP32-C3 that works not as expected. I am interested in how I can understand by marking on-chip that I am buying revision higher than 3?
axellin
Postby axellin » Sat Dec 25, 2021 11:20 am
idf.py menuconfig
This is no longer true, you will hit link error if rev < 3.
https://github.com/espressif/esp-idf/is ... -978774224
Users browsing this forum: Majestic-12 [Bot] and 144 guests
