ESP doesn't boot when its RX0 and TX0 are connected
GeorgeFlorian1
Postby GeorgeFlorian1 » Wed May 05, 2021 2:00 pm
Hello.
I have an ESP32 that works in AP Mode.
When its RX0 (GPIO3) and TX0 (GPIO1) pins are connected to a CubePilot, I can't connect to the ESP. If I remove the connection I can connect to the ESP.
I think that the pins are somehow pulled HIGH or LOW and the ESP32 doesn't work properly.
What other pins can I use ? The ESP is a Wroom-32.
I also have a Wrover-B at hand.
Last edited by GeorgeFlorian1 on Mon May 10, 2021 9:16 am, edited 1 time in total.
lbernstone
Re: ESP doesn't work in AP mode when its RX0 and TX0 are connected
Postby lbernstone » Wed May 05, 2021 5:12 pm
Don't connect 5V circuits to the esp32. You will need to use a level shifter.
GeorgeFlorian1
Postby GeorgeFlorian1 » Thu May 06, 2021 9:53 am
Reading through CubePilot documentation it seems like the ports operate at 3V3
https://docs.cubepilot.org/user-guides/ ... e-overview
Screenshot from 2021-05-06 13-05-01.png (149.96 KiB) Viewed 4505 times
Users browsing this forum: No registered users and 48 guests
