ESP32 in connection with MCP23017
Kymmenen
Postby Kymmenen » Sat May 01, 2021 4:23 pm
I want to use the ESP32 in conneection with the MCP23017 port expansion via the I2C Bus.
From the internet I got some input for the connections which has to be used:
Vdd - 3.3V
Vss - GND
SCL - GPIO 22 and 3.3V via 2.1k pullup
SDA - GPIO 21 and 3.3V via 2.1k pullup
A0 - GND
A1 - GND
A2 - GND
Reset - 3.3V
I hope these connections are correct.
The problem now is that I do not get any output from the MCP23107.
Therefore I found a I2C scanner, to maybe identify the problem, on this website:
https://randomnerdtutorials.com/esp32-i ... duino-ide/
Running the scanner code I always get the result: No I2C devices found.
Measuring the voltage at SCL always results in constant 3.3V while using the scanner.
I hope somebody can help me to let the things work.
Thank you very much in advance!
Kymmenen
Users browsing this forum: No registered users and 46 guests
