I am trying to make ESP32-CAM to stream images over ethernet using ENC28J60 with SPI interface. So far I can only make it to work reliable with 8MHz clock on SPI bus. I am using arduino SPIClass interface with transactions and manual control over CS pin. If I try to use 20MHz or 10MHz clock I have data corrupted when sending data. Does HSPI have some limitations (on this board or in general) or I am missing something?
PS This moderation thing is really annoying, you a question to ask but you have to wait days until your message approved. Looks like you do not need too many participans...
Cannot make HSPI work faster than 8MHz clock
Re: Cannot make HSPI work faster than 8MHz clock
I found this topic https://www.esp32.com/viewtopic.php?t=4 ... 0impedance. which says:
So is it hardware limitation on HSPI interface?My result:
in case use HSPI & VSPI mapped like this:
HSPI_CLK = 14 or 25 GPIO
HSPI_MOSI = 13 or 26 GPIO
HSPI_MISO = 12 or 32 GPIO
HSPI_CS = 15 or 33 GPIO
VSPI_CLK = 18 or 21 GPIO
VSPI_MOSI = 23 or 22 GPIO
VSPI_MISO = 19 or 19 GPIO
VSPI_CS = 05 or 23 GPIO
the maximum speed of CLK is 9 MHz.
Fwiw, only the first 3 posts need to be approved. Approval usually happens within a day; you just happened to post during a Chinese holiday.
Users browsing this forum: No registered users and 55 guests
