vscode extension 1.0.3 "breaks" compiler
orbitcoms
Postby orbitcoms » Wed Apr 28, 2021 5:59 am
Extension v1.0.3 installed itself in VScode and none of my projects compile without reinstalling esp-df all over again
Err output below.
CMake Error at C:/esp/esp-idf/tools/cmake/project.cmake:205 (message):
C:\esp\tools\.espressif\python_env\idf4.2_py3.9_env\Scripts\python.exe:
Error while finding module specification for
'idf_component_manager.prepare_components' (ModuleNotFoundError: No module
named 'idf_component_manager')
C:/esp/esp-idf/tools/cmake/project.cmake:292 (__project_init)
CMakeLists.txt:9 (project)
See also "D:/Firmware/Cab/CAB_ROLEC_ESP_PCB0325_G/build/CMakeFiles/CMakeOutput.log".
The terminal process "C:\WINDOWS\System32\cmd.exe /d /c cmake -G Ninja .." terminated with exit code: 1
chegewara
Re: vscode extension 1.0.3 "breaks" compiler
Postby chegewara » Wed Apr 28, 2021 6:06 am
Why you duplicate your own posts?
viewtopic.php?f=13&t=20630
orbitcoms
Postby orbitcoms » Wed Apr 28, 2021 6:23 am
I could not find the vscode extension forum so posted in the general forum but later found the specific forum.
Can you help or just commenting about policy at the moment?
Zingemneire
Postby Zingemneire » Wed Apr 28, 2021 7:51 am
I don't know why it does that but I can confirm that it does.
This morning I opened my project that I had been working on yesterday and without making any change to it I simply tried to build it and it failed as described by "orbitcoms".
After reading about version 1.0.3 I checked my version of the Espressif IDF exntension and sure enough it was version 1.0.3.
I reverted back to version 1.0.2 and everything works perfectly again so there is no need to reinstall ESP-IDF.
ESP_Minatel
Postby ESP_Minatel » Wed Apr 28, 2021 8:24 am
This post is duplicated as our friend chegewara mentioned.
I'll lock this post and we can continue this discussion at: viewtopic.php?f=13&t=20630
Users browsing this forum: No registered users and 11 guests
