Getting current transmit status of the UART driver
xgaroux
Postby xgaroux » Fri Apr 23, 2021 3:37 pm
Hi! I'm trying to figure out if there is a way to get current transmit status of UART driver?
I found a function in the HAL that fully matches my question:
#define uart_hal_is_tx_idle(hal)  uart_ll_is_tx_idle((hal)->dev)
But it use only in block waiting for the transmission ends and internal ISR routine. May be there are some macros or any other API I missed? Is there a way to use it without breaking library hierarchy and jumping to HAL from my code?
Also I can't understand using of this API - FIFO space threshold or transmission timeout reached:
uart_intr_config(), uart_enable_tx_intr()
I can configurate this interrupts, but no functions to use this interrupts or callbacks for it. How work with it? In case when I don't register a custom lower level interrupt handler using
uart_isr_register()
Thanks in advance, Michael.
fevang
Re: Getting current transmit status of the UART driver
Postby fevang » Wed Apr 28, 2021 12:13 am
You might be able to call
 * @brief Wait until UART TX FIFO is empty.
 * @param uart_num      UART port number, the max port number is (UART_NUM_MAX -1).
 * @param ticks_to_wait Timeout, count in RTOS ticks
 * @return
 *     - ESP_OK   Success
 *     - ESP_FAIL Parameter error
 *     - ESP_ERR_TIMEOUT  Timeout
esp_err_t uart_wait_tx_done(uart_port_t uart_num, TickType_t ticks_to_wait);
with ticks_to_wait = 0, and check the return value.
If it returns ESP_ERR_TIMEOUT, then you know a transmission is happening.
For example
if(uart_wait_tx_done(UART_NUM_1, 0) == ESP_ERR_TIMEOUT){
	// Transaction is currently taking place
xgaroux
Postby xgaroux » Mon May 10, 2021 6:19 pm
fevang wrote: You might be able to call
 * @return
 *     - ESP_OK   Success
Thank you for your reply! I missed such a simple opportunity to solve my problem with transmit status.
But the second part of my question (FIFO space threshold API) is still not clear...
Users browsing this forum: Bing [Bot] and 139 guests
