Is there a direct way to find the IDF version of ESP arduino?
zliudr
Postby zliudr » Wed Apr 21, 2021 3:48 am
I had to find an actual ESP32 dev board and load a sketch to print out the version. There must be an easy way to find out?
I have ESP Arduino 1.0.5 and this is the short sketch I loaded and it turns out to be a really old V3.3. Is 1.0.6 using IDF V4.X?
  Serial.print("ESP-IDF major");
  Serial.println(ESP_IDF_VERSION_MAJOR);
  Serial.print("ESP-IDF minor");
  Serial.println(ESP_IDF_VERSION_MINOR);
ets Jun  8 2016 00:22:57
configsip: 0, SPIWP:0xee
mode:DIO, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:1216
ho 0 tail 12 room 4
load:0x40078000,len:10944
load:0x40080400,len:6388
entry 0x400806b4
ESP-IDF major3
ESP-IDF minor3
ESP_Minatel
Re: Is there a direct way to find the IDF version of ESP arduino?
Postby ESP_Minatel » Wed Apr 21, 2021 7:56 am
The version 2.0.0 (beta) is running with the ESP-IDF 4.4.
5502879a v2.0.0 Add support for ESP32S2 and update ESP-IDF to 4.4 (#4996)
https://github.com/espressif/arduino-esp32/releases
Users browsing this forum: No registered users and 48 guests
