NVS encryption key / initialisation problem
hereiam
Postby hereiam » Mon Apr 19, 2021 9:35 pm
Hello, i use this developpement tools :
esp32 v1
idf 4.2
I have secure boot and flash encrypt mode which works fine.
The program starts correctly.
I have tested several solutions for over a week and still get stuck.
TEST 1
when i put "encrypts" in the partition table for NVS i have a bootloop:
nvs,      data, nvs, ,  0x6000,
otadata,  data, ota,     ,        0x2000,
phy_init, data, phy,     ,        0x1000,
certs,    data, spiffs,  ,        0x10000,
fact_cfg, data, spiffs,  ,        0x8000,
user_cfg, data, spiffs,  ,        0x8000,
storage,  data, spiffs,  ,        0x10000,
ota_0,    app,  ota_0,  ,0x280000,
# ota_0,    app,  ota_0,  ,0x180000,
# ota_1,    app,  ota_1,   ,        0x180000,
nvs_key,  data, nvs_keys,         , 0x1000, encrypted
 (55) boot: Partition Table:
 (59) boot: ## Label            Usage          Type ST Offset   Length
 (66) boot:  0 nvs              WiFi data        01 02 00009000 00006000
 (74) boot:  1 otadata          OTA data         01 00 0000f000 00002000
 (81) boot:  2 phy_init         RF data          01 01 00011000 00001000
 (89) boot:  3 certs            Unknown data     01 82 00012000 00010000
 (96) boot:  4 fact_cfg         Unknown data     01 82 00022000 00008000
 (103) boot:  5 user_cfg         Unknown data     01 82 0002a000 00008000
 (111) boot:  6 storage          Unknown data     01 82 00032000 00010000
 (119) boot:  7 ota_0            OTA app          00 10 00050000 00280000
 (126) boot:  8 nvs_key          NVS keys         01 04 002d0000 00001000
default code:
(1020) flash_encrypt: Flash encryption mode is DEVELOPMENT (not secure)
(1022) spi_flash: detected chip: generic
(1023) spi_flash: flash io: dio
 (1027) cpu_start: Starting scheduler on PRO CPU.
(0) cpu_start: Starting scheduler on APP CPU.
abort() was called at PC 0x4012b07a on core 0
offending part of the program :
   esp_err_t err = nvs_flash_init();
 if (err == ESP_ERR_NVS_NO_FREE_PAGES || err == ESP_ERR_NVS_NEW_VERSION_FOUND) {
        // NVS partition was truncated and needs to be erased
        // Retry nvs_flash_init
    ESP_ERROR_CHECK( err );
TEST 2 :
identical partition table
I modified the program by adding this :
		esp_err_t nvs_secure_initialize() {
    static const char *nvs_tag = "nvs";
    esp_err_t err = ESP_OK;
    // 1. find partition with nvs_keys
    const esp_partition_t *partition = esp_partition_find_first(ESP_PARTITION_TYPE_DATA,
        ESP_PARTITION_SUBTYPE_DATA_NVS_KEYS,
        "nvs_key");
    if (partition == NULL) {
        ESP_LOGE(nvs_tag, "Could not locate nvs_key partition. Aborting.");
        return ESP_FAIL;
    // 2. read nvs_keys from key partition
    nvs_sec_cfg_t cfg;
    if (ESP_OK != (err = nvs_flash_read_security_cfg(partition, &cfg))) {
        ESP_LOGE(nvs_tag, "Failed to read nvs keys (rc=0x%x)", err);
        return err;
    // 3. initialize nvs partition
    if (ESP_OK != (err = nvs_flash_secure_init(&cfg))) {
        ESP_LOGE(nvs_tag, "failed to initialize nvs partition (err=0x%x). Aborting.", err);
        return err;
    return err;
and in the main :
   esp_err_t err = nvs_secure_initialize();
    if (err != ESP_OK) {
        ESP_LOGE("main", "Failed to initialize nvs (rc=0x%x). Halting.", err);
        while(1) { vTaskDelay(100); }
without changing the partition table I have another error:
E (1042) nvs: Failed to read nvs keys (rc=0x1117)
E (1052) main: Failed to initialize nvs (rc=0x1117). Halting.
I test to flash the keys of nvs like this:
 python nvs_partition_gen.py generate nvs.csv nvs.bin 0x11000
 python nvs_partition_gen.py encrypt nvs.csv encrypted_nvs.bin 0x11000 --keygen --keyfile nvs_keys.bin
 esptool.py -p com13 --before default_reset --after no_reset write_flash 0x11000 encrypted_nvs.bin
 esptool.py -p com13 --before default_reset --after no_reset write_flash 0x2d0000 nvs_keys.bin
my test nvs.csv :
# NVS csv file
key,type,encoding,value
fctryNamespace,namespace,,
serial_number,data,string,AE12A21D3D4F
mac_addr,data,string,0F:0B:01:0D:0E:0F
I dont know if my nvs.csv example is good.
Maybe I'm wrong in the offset?
Thanks for your help
WiFive
Re: NVS encryption key / initialisation problem
Postby WiFive » Tue Apr 20, 2021 5:50 am
You have to encrypt nvs_keys.bin if you already turned on flash encryption.
According to your log your phy_init partition is at 0x11000
hereiam
Postby hereiam » Tue Apr 20, 2021 10:04 am
Hello, thank you for your response,
i've encrypted the nvs_key.bin with these command :
  espsecure.py encrypt_flash_data --keyfile my_flash_encryption_key.bin --address 0x2d0000 -o encrypted_nvs_6.bin nvs_keys.bin
  esptool.py --port com13 --baud 460800 write_flash 0x2d0000 encrypted_nvs_6.bin
and the esp32 still in bootloop
(1041) cpu_start: Starting scheduler on PRO CPU.
I've two qquestions about security :
Who can tell me if the secure boot is enable and the flash ecrypt is enable too, can someone successfully "hack" the esp32 without the NVS encryption?
I read in some Espressif documentation that once memory encryption is enabled, it is not useful to enable NVS encryption unless I misunderstood.
Users browsing this forum: Bing [Bot] and 152 guests
