esp32_datasheet_en.pdf - only the last revision 1.4 from May 26 2017 has some problem with encoding or I don't know what, but any attemp to search any common word gives me " ...No matches were found"
If I mark and copy some word(s) from the text and paste it in the Adobe Reader's search box they appears as junk or even if I paste in notepad or even here: ......... The last one supposed to be 'May 26, 2017' and was copied from the first page
Ooops I pasted it here, but cant post it as the forum software doesn't allow it "Your message contains the following unsupported characters" - anyway it were 10 emty squares not the ..........
Bug in the last revision 1.4 of the data sheet from May 26 2017
Re: Bug in the last revision 1.4 of the data sheet from May 26 2017
Yes, we're aware of this and will have this fixed ASAP.
Ok, but the new revision of the datasheet V1.5(2017.06.09 ) came out and it is the same mess as before Only few areas: some embedded pictures, diagrams and a table are searchable - most of the text is still not searchable and if I mark any words from there and copy them either in the Adobe reader's Search box or to any external editor - and is all junk(empty squares)
On it, thanks for reporting. We're looking into a way we can prevent this from happening again, but we're not there yet as you rightfully noticed.
Users browsing this forum: No registered users and 22 guests
