Why SSD1306 OLED display get scrambled text when printing messages from tasks pinned to Core0 in RTOS?
Pcborges
Postby Pcborges » Mon Apr 12, 2021 11:32 am
ESP32 with RTOS, test app with 2 independent tasks. Each prints a message to OLED display. Why text gets frequently scrambled? Mutex have been used to share display resource.
I found that if I put Task01 to run on the same core as Task02 (core 1) it works perfectly. And if I put both to run on core 0 the mess becomes a lot worse.
The problem has clearly something to do when the task running on core 0 tries to write to the display even protected by Mutex.
#define DEBUG_ESP              //comment out to deactivate debug console verbose
#ifdef DEBUG_ESP
  #define pDBGln(x) Serial.println(x)
  #define pDBG(x)   Serial.print(x)
#else
  #define pDBG(...)
  #define pDBGln(...)
#endif
//create handle for the mutex. It will be used to reference mutex
SemaphoreHandle_t  xMutex;
//*********************************SSD1306 OLED Display
#define I2C_SDA              14
#define I2C_SCL              15
#include <Wire.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
#define OLED_RESET     4 // Reset pin # (or -1 if sharing Arduino reset pin)
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, -1);
  // create mutex and assign it a already create handler
  xMutex = xSemaphoreCreateMutex();
  Wire.begin(I2C_SDA,I2C_SCL);
   // SSD1306_SWITCHCAPVCC = generate display voltage from 3.3V internally
  if(!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) {
    pDBGln("SSD1306 allocation failed - Halt");
    for(;;); // Don't proceed, loop forever
  }else{
    // Show initial display buffer contents on the screen --
    // the library initializes this with an Adafruit splash screen.
    display.setTextSize(1);
    display.setTextColor(SSD1306_WHITE);
    display.setCursor(0, 0);
    display.clearDisplay();
    xTaskCreatePinnedToCore(
        task01,             /* Function to implement the task */
        "task01",           /* Name of the task */
        10000,              /* Stack size in words */
        NULL,               /* Task input parameter */
        1,                  /* Priority of the task */
        NULL,               /* Task handle. */
        0);                 /* Core where the task should run */
        task02,             /* Function to implement the task */
        "task02",           /* Name of the task */
        1);                 /* Core where the task should run */
void loop() {}
void task01( void * parameter ){
  while(1){
    printToDisplay("Task01..............");
    vTaskDelay(1500);
void task02( void * parameter ){
  while(1){
    printToDisplay("Task02..............");
    vTaskDelay(2500);
void printToDisplay(String text){
  bool myMutex;
  while(1){
    // take mutex
    myMutex = xSemaphoreTake(xMutex, portMAX_DELAY);
    if(myMutex){
      static byte   lineCounter = 0;
      static String displayText[8];
      if(lineCounter>7){
        for(int i=0;i<7;i++){
          displayText[i] = displayText[i+1];
        displayText[7] = text;
        for(int i=0;i<8;i++){
          display.println(displayText[i]);
      }else{
        displayText[lineCounter] = text;
        display.println(displayText[lineCounter]);
        if(lineCounter<8){lineCounter++;}
      display.display();
      // release mutex
      xSemaphoreGive(xMutex);
The code below uses no RTOS and works perfectly: (my project requires RTOS)
#ifdef DEBUG_ESP
#else
  #define pDBG(...)
  #define pDBGln(...)
#endif
#define I2C_SDA              14
#define I2C_SCL              15
#include <Wire.h>
  }else{
  pDBGln("Start Display Test...");
  task01();
  task02();
void task01(){
  delay(500);
void task02(){
  delay(500);
  if(lineCounter>7){
  }else{
  display.display();
ESP_Sprite
Re: Why SSD1306 OLED display get scrambled text when printing messages from tasks pinned to Core0 in RTOS?
Postby ESP_Sprite » Tue Apr 13, 2021 5:37 am
The only thing I can think of is that display.display() is still doing things even after the call itself returns; as the mutex is unlocked after, perhaps the 2nd thread overwrites some information it uses. You'd need to take a good, hard look at the lib code to see if that's true, though.
Users browsing this forum: No registered users and 38 guests
