Help with socket
Rengav
Help with socket
Postby Rengav » Mon Apr 12, 2021 12:50 am
Hi guys,
I'm trying connect esp32 with java aplication way socket, but i have a problem, it's works only one time, after the first time show connection failed. for work i need restar server application (java), below my code esp32 and java. thanks
#include <WiFi.h>
#include <WiFiMulti.h>
WiFiMulti WiFiMulti;
void setup()
    delay(10);
    // We start by connecting to a WiFi network
    WiFiMulti.addAP("ssid", pass");
    Serial.println();
    Serial.println();
    Serial.print("Waiting for WiFi... ");
    while(WiFiMulti.run() != WL_CONNECTED) {
        Serial.print(".");
        delay(500);
    Serial.println("");
    Serial.println("WiFi connected");
    Serial.println("IP address: ");
    delay(500);
void loop()
//    const uint16_t port = 80;
//    const char * host = "192.168.1.1"; // ip or dns
    const char * host = "192.168.0.114"; // ip or dns
    Serial.print("Connecting to ");
    Serial.println(host);
    // Use WiFiClient class to create TCP connections
    WiFiClient client;
    if (!client.connect(host, port)) {
        Serial.println("Connection failed.");
        Serial.println("Waiting 5 seconds before retrying...");
        delay(5000);
        return;
    // This will send a request to the server
    //uncomment this line to send an arbitrary string to the server
    //client.print("Send this data to the server");
    //uncomment this line to send a basic document request to the server
    client.print("GET /index.html HTTP/1.1\n\n");
  int maxloops = 0;
  //wait for the server's reply to become available
  while (!client.available() && maxloops < 1000)
    maxloops++;
    delay(1); //delay 1 msec
  if (client.available() > 0)
    //read back one line from the server
    String line = client.readStringUntil('\r');
    Serial.println(line);
  else
    Serial.println("client.available() timed out ");
    Serial.println("Closing connection.");
    client.stop();
    Serial.println("Waiting 5 seconds before restarting...");
    delay(5000);
java code
import java.io.BufferedWriter;
import java.io.IOException;
import java.io.InputStreamReader;
import java.io.OutputStreamWriter;
import java.net.ServerSocket;
import java.net.Socket;
import java.util.logging.Level;
import java.util.logging.Logger;
public class Server {
    public static void main(String args[]) {
        try {
                ServerSocket server = new ServerSocket(80);
                System.out.println("Server ok on port 80");
                Socket cliente = server.accept();
                System.out.println("Client connected from IP " + cliente.getInetAddress().getHostAddress());
                InputStreamReader inputStreamReader = new InputStreamReader(cliente.getInputStream());
                OutputStreamWriter outputStreamWriter = new OutputStreamWriter(cliente.getOutputStream());
                BufferedReader bfr = new BufferedReader(inputStreamReader);
                BufferedWriter bfw = new BufferedWriter(outputStreamWriter);
                while (true) {
                    String str = bfr.readLine();
                    if (str != null) {
                        System.err.println("client say: " + str);
                        bfw.write("received");
                        bfw.newLine();
                        bfw.flush();
                        if (str.equalsIgnoreCase("buy")) {
        } catch (IOException ex) {
            Logger.getLogger(Server.class.getName()).log(Level.SEVERE, null, ex);
Users browsing this forum: No registered users and 66 guests
