ESP32 thing is not connecting to WIFI, even with external power
raldtech
Postby raldtech » Fri Mar 19, 2021 5:40 am
I have a ESP32 thing from sparkfun and not matter what I do the device is not connecting to WIFI. I already used some examples provided here but nothing also I used and external power supply and nothing.
this is my code
#include <WiFi.h>
// WiFi network name and password:
const char * networkName = "starfire 5";
const char * networkPswd = "xxxxxxxxx";
// Internet domain to request from:
const char * hostDomain = "example.com";
const int hostPort = 80;
const int BUTTON_PIN = 0;
const int LED_PIN = 5;
void setup()
  // Initilize hardware:
  pinMode(BUTTON_PIN, INPUT_PULLUP);
  pinMode(LED_PIN, OUTPUT);
  // Connect to the WiFi network (see function below loop)
  connectToWiFi(networkName, networkPswd);
  digitalWrite(LED_PIN, LOW); // LED off
  Serial.print("Press button 0 to connect to ");
  Serial.println(hostDomain);
void loop()
  if (digitalRead(BUTTON_PIN) == LOW)
  { // Check if button has been pressed
    while (digitalRead(BUTTON_PIN) == LOW)
      ; // Wait for button to be released
    digitalWrite(LED_PIN, HIGH); // Turn on LED
    requestURL(hostDomain, hostPort); // Connect to server
    digitalWrite(LED_PIN, LOW); // Turn off LED
void connectToWiFi(const char * ssid, const char * pwd)
  int ledState = 0;
  printLine();
  Serial.println("Connecting to WiFi network: " + String(ssid));
  WiFi.begin(ssid, pwd);
  while (WiFi.status() != WL_CONNECTED)
    WiFi.begin(ssid, pwd); //<---- idea provide by a forum's member did not work.
    // Blink LED while we're connecting:
    digitalWrite(LED_PIN, ledState);
    ledState = (ledState + 1) % 2; // Flip ledState
    delay(500);
    Serial.print(".");
  Serial.println();
  Serial.println("WiFi connected!");
  Serial.print("IP address: ");
void requestURL(const char * host, uint8_t port)
  printLine();
  Serial.println("Connecting to domain: " + String(host));
  // Use WiFiClient class to create TCP connections
  WiFiClient client;
  if (!client.connect(host, port))
    Serial.println("connection failed");
    return;
  Serial.println("Connected!");
  printLine();
  // This will send the request to the server
  client.print((String)"GET / HTTP/1.1\r\n" +
               "Host: " + String(host) + "\r\n" +
               "Connection: close\r\n\r\n");
  unsigned long timeout = millis();
  while (client.available() == 0)
    if (millis() - timeout > 5000)
      Serial.println(">>> Client Timeout !");
      client.stop();
      return;
  // Read all the lines of the reply from server and print them to Serial
  while (client.available())
    String line = client.readStringUntil('\r');
    Serial.print(line);
  Serial.println();
  Serial.println("closing connection");
  client.stop();
void printLine()
  Serial.println();
  for (int i=0; i<30; i++)
    Serial.print("-");
  Serial.println();
it is the same example that comes into the sparkfun's page, I tried with this one and also with other one, no one is connecting.
any idea? some error can you see?
thanks.
Users browsing this forum: No registered users and 83 guests
