I am not sure what do you next to find out why my ESP is resetting.
I get output below when running the code.
CORRUPT HEAP: Bad head at 0x3ffbb6a8. Expected 0xabba1234 got 0x3ffbddec
abort() was called at PC 0x400829d2 on core 0
0x400829d2: lock_acquire_generic at C:/esp/esp-idf/components/newlib/locks.c:142
Backtrace:0x40085baf:0x3ffbaff0 0x4008624d:0x3ffbb010 0x4008a2ae:0x3ffbb030 0x400829d2:0x3ffbb0a0 0x40082af5:0x3ffbb0d0 0x400f520d:0x3ffbb0f0 0x400f0ee5:0x3ffbb3b0 0x400f0de8:0x3ffbb400 0x40089fd5:0x3ffbb430
0x40081462:0x3ffbb450 0x4008a2d9:0x3ffbb470 0x400d4dd8:0x3ffbb490 0x40086255:0x3ffbb4b0
0x40085baf: panic_abort at C:/esp/esp-idf/components/esp_system/panic.c:330
0x4008624d: esp_system_abort at C:/esp/esp-idf/components/esp_system/system_api.c:106
0x4008a2ae: abort at C:/esp/esp-idf/components/newlib/abort.c:46
0x40082af5: _lock_acquire_recursive at C:/esp/esp-idf/components/newlib/locks.c:170
Help needed with heap corruption
Re: Help needed with heap corruption
These problems can happen when you overwrite a local variable usually through a pointer (e.g. you write more bytes in an array than its length).
Users browsing this forum: Bing [Bot], chegewara and 90 guests
