VS Code Path Problem
lukehoersten
Postby lukehoersten » Mon Mar 08, 2021 1:38 am
I've had this working with the normal CLI install.sh and export.sh scripts and now am trying to get it working with VS Code with no luck. The following are my settings and the resulting CMake error output.
settings.json
  "C_Cpp.clang_format_style": "Visual Studio",
  "editor.formatOnSave": true,
  "[cpp]": {
    "editor.quickSuggestions": true
  "[c]": {
  "C_Cpp.intelliSenseEngine": "Tag Parser",
  "files.associations": {
    "stdio.h": "c"
  "idf.espIdfPath": "/Users/luke/Dev/code/esp32/esp-idf",
  "idf.customExtraPaths": "/Users/luke/Dev/code/esp32/esp-idf/components/esptool_py/esptool:/Users/luke/Dev/code/esp32/esp-idf/components/espcoredump:/Users/luke/Dev/code/esp32/esp-idf/components/partition_table:/Users/luke/Dev/code/esp32/esp-idf/components/app_update:/Users/luke/.espressif/tools/xtensa-esp32-elf/esp-2020r3-8.4.0/xtensa-esp32-elf/bin:/Users/luke/.espressif/tools/xtensa-esp32s2-elf/esp-2020r3-8.4.0/xtensa-esp32s2-elf/bin:/Users/luke/.espressif/tools/esp32ulp-elf/2.28.51-esp-20191205/esp32ulp-elf-binutils/bin:/Users/luke/.espressif/tools/esp32s2ulp-elf/2.28.51-esp-20191205/esp32s2ulp-elf-binutils/bin:/Users/luke/.espressif/tools/openocd-esp32/v0.10.0-esp32-20200709/openocd-esp32/bin:/Users/luke/.espressif/python_env/idf4.2_py3.9_env/bin:/Users/luke/Dev/code/esp32/esp-idf/tools:/usr/local/sbin:/usr/local/opt/python@3.9/libexec/bin:/Users/luke/Library/Python/3.9/bin:/usr/local/bin:/usr/bin:/bin:/usr/sbin:/sbin",
  "idf.pythonBinPath": "/Users/luke/.espressif/python_env/idf4.2_py3.9_env/bin/python",
  "idf.customExtraVars": "{\"OPENOCD_SCRIPTS\":\"/Users/luke/.espressif/tools/openocd-esp32/v0.10.0-esp32-20200420/openocd-esp32/share/openocd/scripts\"}",
  "idf.openOcdConfigs": [
    "interface/ftdi/esp32_devkitj_v1.cfg",
    "board/esp32-wrover.cfg"
  "idf.adapterTargetName": "esp32",
  "idf.port": "/dev/cu.usbserial-31301",
  "git.ignoreLimitWarning": true
Build error output
[main] Building folder: esp-homekit-door
[main] Configuring folder: esp-homekit-door
[proc] Executing command: /usr/local/bin/cmake --no-warn-unused-cli -DCMAKE_EXPORT_COMPILE_COMMANDS:BOOL=TRUE -DCMAKE_BUILD_TYPE:STRING=Debug -H/Users/luke/Dev/code/esp32/projects/esp-homekit-door -B/Users/luke/Dev/code/esp32/projects/esp-homekit-door/build -G Ninja
[cmake] Not searching for unused variables given on the command line.
[cmake] -- Found Git: /usr/local/bin/git (found version "2.30.1")
[cmake] -- Unexpected file in components directory: /Users/luke/Dev/code/esp32/esp-idf/components/.DS_Store
[cmake] -- IDF_TARGET not set, using default target: esp32
[cmake] -- The C compiler identification is unknown
[cmake] -- The CXX compiler identification is unknown
[cmake] -- The ASM compiler identification is unknown
[cmake] -- Found assembler: xtensa-esp32-elf-gcc
[cmake] CMake Error at /Users/luke/Dev/code/esp32/esp-idf/tools/cmake/project.cmake:307 (__project):
[cmake]   The CMAKE_C_COMPILER:
[cmake]
[cmake]     xtensa-esp32-elf-gcc
[cmake]
[cmake]   is not a full path and was not found in the PATH.
[cmake]
[cmake]   Tell CMake where to find the compiler by setting either the environment
[cmake]   variable "CC" or the CMake cache entry CMAKE_C_COMPILER to the full path to
[cmake]   the compiler, or to the compiler name if it is in the PATH.
[cmake] Call Stack (most recent call first):
[cmake]   CMakeLists.txt:12 (project)
[cmake]
[cmake]
[cmake]   The CMAKE_CXX_COMPILER:
[cmake]
[cmake]     xtensa-esp32-elf-g++
[cmake]
[cmake]
[cmake]   variable "CXX" or the CMake cache entry CMAKE_CXX_COMPILER to the full path
[cmake]   to the compiler, or to the compiler name if it is in the PATH.
[cmake]
[cmake]
[cmake]   The CMAKE_ASM_COMPILER:
[cmake]
[cmake]
[cmake]
[cmake]   variable "ASM" or the CMake cache entry CMAKE_ASM_COMPILER to the full path
[cmake]
[cmake]
[cmake] -- Warning: Did not find file Compiler/-ASM
[cmake] -- Configuring incomplete, errors occurred!
[cmake] See also "/Users/luke/Dev/code/esp32/projects/esp-homekit-door/build/CMakeFiles/CMakeOutput.log".
[cmake] See also "/Users/luke/Dev/code/esp32/projects/esp-homekit-door/build/CMakeFiles/CMakeError.log".
ESP_bignacio
Re: VS Code Path Problem
Postby ESP_bignacio » Mon Mar 08, 2021 6:59 am
How are you building ?
Are you using the extension commands to build ? Press menu View -> Command Palette -> type ESP-IDF: Build your project
Please review Vscode extension commands
lukehoersten
Postby lukehoersten » Mon Mar 08, 2021 1:30 pm
The extension's build was broken for me until I followed the fix here:
https://github.com/espressif/vscode-esp ... issues/339
Now I'm still not able to get the esp-homekit-sdk linked but the build process actually finds the compilers and works.
Should this not be enough?:
Makefile
HOMEKIT_PATH ?= $(abspath $(IDF_PATH)/../../esp-homekit-sdk)
COMMON_COMPONENT_PATH ?= $(HOMEKIT_PATH)/examples/common
PROJECT_NAME := esp-homekit-door
EXTRA_COMPONENT_DIRS += $(HOMEKIT_PATH)/components
EXTRA_COMPONENT_DIRS += $(HOMEKIT_PATH)/components/homekit
EXTRA_COMPONENT_DIRS += $(COMMON_COMPONENT_PATH)
include $(IDF_PATH)/make/project.mk
CMakeLists.txt
cmake_minimum_required(VERSION 3.5)
if(DEFINED ENV{HOMEKIT_PATH})
  set(HOMEKIT_PATH $ENV{HOMEKIT_PATH})
else()
  set(HOMEKIT_PATH ${CMAKE_CURRENT_LIST_DIR}/../..)
endif(DEFINED ENV{HOMEKIT_PATH})
set(EXTRA_COMPONENT_DIRS ${HOMEKIT_PATH}/components ${HOMEKIT_PATH}/components/homekit ${CMAKE_CURRENT_LIST_DIR}/../common)
project(esp-homekit-door)
ESP_bignacio
Postby ESP_bignacio » Mon Mar 08, 2021 2:17 pm
Hi @ lukehoersten sorry about the build issue.
With regards to your problem, means you can't add the HomeKit_path to your build ? Where are you defining the HOMEKIT_PATH variable ? is it a global system environment variable or extension specific env variable ?
Is there any error in the build output ?
lukehoersten
Postby lukehoersten » Mon Mar 08, 2021 2:30 pm
It's defined in the Makefile:
HOMEKIT_PATH ?= $(abspath $(IDF_PATH)/../esp-homekit-sdk)
lukehoersten
Postby lukehoersten » Mon Mar 08, 2021 11:33 pm
Got it working. Once I fixed the ESP specific build, I had to regenerate my CMAKE from my Makefile now it all works. Thanks for you help!
Yomiquesh
Postby Yomiquesh » Thu Apr 08, 2021 5:43 pm
How did you solved the problem, can you be more especific?
I have a similar problem.
Thanks.
Users browsing this forum: No registered users and 26 guests
