Hello fellow forum-ers.
I have stumbled upon a setback in my project and I am asking for some assistance.
In the past I had thought of a project that involved an Arduino and a fingerprint sensor, for which adafruit provided an basic sdk library, which I used in order to handle all of the functions of the sensor.
When I heard about the capabilities of esp32, I thought of migrating the project,removingg the Arduino from the picture and utilising esp32 as the controller of the sensor. Unfortunately, I have not found a library(header files and c files) that I could use in order to control the sensor.
Is there a way to migrate the code from the library that adafruit has released in to an freertos device?
I believe that such a project might bring unwanted complexity since the header files of the library utilise arduino.h files. I believe that these files do not exist in the compilation of esp-idf... Correct?
Is there anyway that I could avoid re-writing the library in order to replace all of the Apis used in the Arduino namespace?
Code migration from an Arduino library.
Re: Code migration from an Arduino library.
You can add the Arduino SDK into your ESP-IDF project as a component. link.
Please correct me if i am wrong, what you propose is to reference the arduino SDK in my project, leave the library as it is and init the ESP32 module by running a task that communicates with the sensor, while letting FreeRTOS doing its magic with time/processing management of the underlying OS?ESP_Sprite wrote: ↑Mon Mar 08, 2021 1:52 amYou can add the Arduino SDK into your ESP-IDF project as a component. link.
What might be the negatives of this approach?
Yes. Note that Arduino on the ESP32 also uses ESP-IDF/FreeRTOS under the hood; the difference in an Arduino and an ESP-IDF-with-Arduino-component setup are not much different than the different build systems are.
Users browsing this forum: teletypeguy and 109 guests
