Still Windows JTAG debugging issues
espdorian
Postby espdorian » Mon Feb 22, 2021 9:15 pm
After speding days attempting to get JTAG debugging working (VSCODE), I decided to give Eclipse a try.
With Eclipse experiencing similar issues, device is detected via JTAG and that's were it ends.
I am using the Lyra-T board. Can there be any hardware related issue causing debug problems, while JTAG device detection always seems to work reliable ?
Somehow for many people JTAG debugging seems to be a problem, so what can be wrong here ?
Any suggestions are welcome.
Open On-Chip Debugger v0.10.0-esp32-20200709 (2020-07-09-08:54)
Licensed under GNU GPL v2
For bug reports, read
adapter speed: 20000 kHz
Warn : Interface already configured, ignoring
Info : Configured 2 cores
Started by GNU MCU Eclipse
Error: libusb_open() failed with LIBUSB_ERROR_NOT_SUPPORTED
Info : ftdi: if you experience problems at higher adapter clocks, try the command "ftdi_tdo_sample_edge falling"
Info : clock speed 20000 kHz
Info : Target halted. CPU0: PC=0x40090910 (active)
Info : Target halted. CPU1: PC=0x40000400
Error: No symbols for FreeRTOS
.. then nothing
ESP_bignacio
Re: Still Windows JTAG debugging issues
Postby ESP_bignacio » Wed Mar 03, 2021 10:07 am
Hi @espdorian I'm sorry to hear about the vscode debug problems. We are working on some tutorial documentation to set this up. I will tag you when released to see if it helps somehow or you can also post a GitHub Issue so we can explore what the problem is.
With regards to Eclipse, have you review our eclipse plugin debugging debug step ?
Users browsing this forum: No registered users and 18 guests
