Difference in programming WROVER and WROOM
I have used ESP-IDF for programming WROOM based boards for some time now. Just want to confirm before ordering WROVER modules (which I have never used before), Is there any difference in programming WROVER and WROOM using ESP-IDF?
Re: Difference in programming WROVER and WROOM
The WROVER has 8 MB of PSRAM added. If you're not using that, and you're not using the pins which connect to the PSRAM chip, you're good.
Thanks dastoned.
That's it? Sounds good. And Which pins connect to the PSRAM chip? I will keep miles away from thoseyou're not using the pins which connect to the PSRAM chip, you're good
Have a look at the datasheets in https://docs.espressif.com/projects/esp ... ver-series
From Datasheet:
I can't see these pins exposed in modules.External connections can be made to any GPIO except for GPIOs in the range 6-11, 16, or 17. GPIOs 6-11 are connected
to the module’s integrated SPI flash and PSRAM. GPIOs 16 and 17 are connected to the module’s integrated PSRAM
To answer your original question: On the software side, there's no difference; when you enable PSRAM, ESP-IDF will automagically handle the extra memory for you. There's obviously some differences in execution speed wrt internal vs external memory, and the psram chip eats up two extra GPIOs, but aside from small things like that, there's no difference.
Users browsing this forum: nopnop2002, Zigzag and 100 guests
