ESP32 SD writes but doesn't append
skendhajd
Postby skendhajd » Sat Feb 13, 2021 12:16 pm
I've got a microSD module adapter from the far east, and so far so good, and although it can create files using writeFile, it does not append messages. It returns true, i.e: message appended successfully but when you read the file on the computer or when ESP32 reads on reboot, it's blank.
This is how I call the function:
  1. char* sdFileName = "/v.ea";
  2. if (appendFile(SD, sdFileName, "Heyy")) {
  3. //success
  4. } else {
  5. //failed
  6. }
I've even tried the writeFile function with
file.seek(EOF)
but no luck. When calling appendFile for the first time, this appears:
  1. [W][sd_diskio.cpp:149] sdCommand(): token error [17] 0x17
  2. Appending succesfully.
When the appendFile is called for the second time, this appears in serial monitor:
  2. [W][sd_diskio.cpp:149] sdCommand(): token error [17] 0x5
  3. [W][sd_diskio.cpp:149] sdCommand(): token error [17] 0x5
  4. [E][vfs_api.cpp:265] VFSFileImpl(): fopen(/sd/v.ea) failed
  5. Appending failed.
I am using two SPI devices: MFRC522, and before calling SD's functions, I do a
digitalWrite(SD_SS, LOW)
to "enable" the SD functions till it completes its operations and returns back to
HIGH
to disable it.
I've also tried both FAT32 and FAT, no success.
The example in SD(esp32) works fine - writing, appending, deleting, renaming, etc. all work well.
Thanks in advance.
UPDATE: seems like
rfid.init();
is causing the problem. When I remove it, the appending works fine. As I said, I'm using two SPI with a 330Ohm resistor between MISO and microSD adapter module. Though, before SD functions, I use this function:
  1. void activate_SD() {
  2.   rfid.PCD_SoftPowerDown();
  3.   digitalWrite(MFRC522_SSPin, HIGH);
  4.   digitalWrite(SDMOD_SS, LOW);
  5.   if (DEBUG == 1) {
  6.     Serial.println("SD is active.");
  7.   }
  8. }
Then after SD operations are completed, I use this:
  1. void activate_RFID() {
  2.   rfid.PCD_SoftPowerUp();
  3.   rfid.PCD_Init();
  4.   digitalWrite(SDMOD_SS, HIGH);
  5.   digitalWrite(MFRC522_SSPin, LOW);
  6.   if (DEBUG == 1) {
  7.     Serial.println("RFID is active.");
  8.   }
  9. }
But it doesn't help.
Users browsing this forum: No registered users and 75 guests
